Tough Questions - Drawing Contours and Contour Labeling Lisp Needed
AutoCAD 2007
I have a quite a few tough questions/requests and I am currently looking for some lisps to solve them. I have been doing some searching online to find the lisps I need, and although I have been able to find some stuff, I still have some things that I can't seem to find exactly what I am looking for. I would like to take the opportunity ahead of time to thank every who views my
questions and for any help that is given.
1.) Wondering what is the easiest way to cad draw contours on a site plan, is the polyline tool the best thing to use?
2.) I am looking for a lisp that can label contours with their elevation in a specific way. What I need is a lisp that uses the "current" textstyle selected for text size of label. The lisp starts off asking the user to click a point to select a starting point of contour label and then asks for a second point to specify the text labels angle. Then the lisp asks the elevation of the contour to be entered. Now for the tough part, I need the lisp to then place the contour label above the contour in a rectangle created with the "TCIRCLE" command with an offset factor of .20 with the two bottom points of the rectangle lining up with the contour (which is based on the two points clicked in the beginning of the lisp). I have included a cad drawing file for an example of what I am looking for.
3.) I am also looking for the exact same lisp above for question two, but instead of having to enter an elevation by manually typing it in, the lisp asks you to select the contour line and it takes the "Z" elevation assigned to the contour line you select.
Who is up for the challenge?
