Author Topic: Tough Questions - Override "Z" Elevation Lisp  (Read 4166 times)
johnshar123xx
« on: November 30, 2009, 02:24:19 PM »
AutoCAD 2007
I have a quite a few tough questions/requests and I am currently looking for some lisps to solve them.  I have been doing some searching online to find the lisps I need, and although I have been able to find some stuff, I still have some things that I can't seem to find exactly what I am looking for.  I would like to take the opportunity ahead of time to thank every who views my questions and for any help that is given.
Wondering if anyone knows of an override that will allow you to temporarily turn off "Z" elevations set to lines in your drawing.
For example, lets say you have contour lines in a site plan that have "Z" elevations set to them.  If you try to get a 2d distance from line to line, the distance command factors in the "Z" elevation giving you an inaccurate distance reading.
Another example, when you want to draw a 2D line and you snap your line to a contour line that has a "Z" elevation set to it, the line in essence snaps to the "Z" elevation of the line making it 3D as opposed to 2D.
Does anyone know of a variable or a lisp that will allow you to temporarily override the "Z" elevations in a drawing?
Re: Tough Questions - Override "Z" Elevation Lisp
« Reply #1 on: November 30, 2009, 02:29:29 PM »
Well.. FLATTEN.. but thats the point of no return...  :wink:
Matt__W
  • I like my water diluted.
« Reply #2 on: November 30, 2009, 02:34:24 PM »
Just thinking out loud....
You can write a LSP that allows the user to select two points (I.E. your different contour lines) and then from those two points extract their X & Y values.  Then create a list for the first point using the X & Y value extracted in addition to adding 0 for the Z elevation.  Do the same for point 2, then draw a line from point 1 to point 2.
I haven't done LSP in quite some time now, but I've got some code kicking around (unless someone beats me to it).
Autodesk Expert Elite
Maverick®
« Reply #3 on: November 30, 2009, 02:37:51 PM »
Wow.  "Tough questions" here, on Cadtutor, and on Augi.  That oughta get 'er done.
Matt__W
« Reply #4 on: November 30, 2009, 02:38:57 PM »
I think it's called "covering your bases".   :wink:
« Reply #5 on: November 30, 2009, 02:47:33 PM »
Like this?
(defun c:2DDist (/ 2dp x1 lst x2 d)
  (defun 2dp (p) (list (car p) (cadr p) 0.))
  (if (setq x1 (getpoint "\nSelect First Point: "))
      (setq lst (cons (2dp x1) lst) d 0.)
      (while (setq x2 (getpoint (car lst) "\nSelect Next Point: "))
        (setq lst (cons (2dp x2) lst) d (+ d (distance (car lst) (cadr lst)))))
      (princ (strcat "\n<< 2D Distance: " (rtos d 2 3) " >>"))))
  (princ))
Chris
« Reply #6 on: November 30, 2009, 03:20:37 PM »
yeah, but the questions here are different than the ones at AUGI
Christopher T. Cowgill, P.E.
AEC Collection 2020 (C3D)
Win 10
« Reply #7 on: November 30, 2009, 03:24:47 PM »
Still.. they are identical to those at CADTutor...  :wink:
« Reply #8 on: November 30, 2009, 03:34:04 PM »
Another way. 8-)
(defun c:2DDist (/ x1 x2 d)
      (while (setq x2 (getpoint x1 "\nSelect Next Point: "))
        (setq d   (sqrt (+ (expt (- (car x2) (car x1))2) (expt (- (cadr x2) (cadr x1))2) )))
VovKa
  • Ukraine
« Reply #9 on: November 30, 2009, 04:04:31 PM »
(initget 64)
(getdist)
« Reply #10 on: November 30, 2009, 04:19:45 PM »
« Reply #11 on: November 30, 2009, 04:20:46 PM »
Couldn't resist:
(defun c:2DDist (/ 2dp x1 lst x2 d gr)
      (setq lst (cons (2dp x1) lst) d 0. gr lst)
              gr  (append gr (if (< 1 (length gr)) (list (last gr) (car lst)) (list (car lst)))))
        (and (< 1 (length gr)) (grvecs (cons -3 gr))))
  (princ))
« Reply #12 on: November 30, 2009, 04:24:29 PM »
Perhaps better programming:
        (apply 'grvecs
           (list
             (cons '-3
               (apply 'append
                 (mapcar 'list (reverse (cdr lst)) (cdr (reverse lst))))))))
  (princ))
CHulse
« Reply #13 on: November 30, 2009, 07:14:45 PM »
What about OSNAPZ?
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
Matt__W
« Reply #14 on: December 01, 2009, 08:07:40 AM »
What about OSNAPZ?
Why do you have to make it so easy?   :-D
I forgot about that one!  Is that just for the verticals or does it work in Vanilla, too?
