Author Topic: Weird C3D Stuff  (Read 5317 times)
Weird C3D Stuff
« on: November 25, 2009, 11:09:22 AM »
Anyone care to explain this!! LOL
Matt__W
  • I like my water diluted.
Re: Weird C3D Stuff
« Reply #1 on: November 25, 2009, 11:14:24 AM »
Ummm.... looks like you don't have HIGHLIGHT turned on??  :?
Autodesk Expert Elite
Re: Weird C3D Stuff
« Reply #2 on: November 25, 2009, 11:14:38 AM »
Uh, what exactly are you wanting explained?
Re: Weird C3D Stuff
« Reply #3 on: November 25, 2009, 11:19:20 AM »
I'm not sure what it is, it looks like a parcel area label but the properties say it's a parcel? There is no parcel associated with it. You can't erase it either.
sinc
Re: Weird C3D Stuff
« Reply #4 on: November 25, 2009, 11:25:35 AM »
You're sure you don't have a Parcel named "INSIDE CITY LIMITS" created in one of your Sites?
It looks like a Parcel area label.  And the primary area label for a Parcel cannot be deleted - you can only change its Style to a non-printing version.  To delete the Parcel, you have to delete the linework that forms the Parcel.
But I've also seen weird problems pop up when Parcels are involved, and I've seen bizarre "ghost parcels" and other weirdness in the past that are definitely related to errors in Civil 3D's programming.  You might have encountered one of those.
Re: Weird C3D Stuff
« Reply #5 on: November 25, 2009, 11:35:01 AM »
Technically the Parcel and it's Label are one in the Same.
And as SINC pointed out one must delete all of the segments that comprise the parcel to delete it.
And if there is no linework to delete,  this would be a good time to export all information out of that file and start a new one, BEFORE the corruption spreads.
Re: Weird C3D Stuff
« Reply #6 on: November 25, 2009, 11:48:05 AM »
Careful their SINC, you type any closer to the truth too often, and folks are going to start hating on you for it.   ;-)
Re: Weird C3D Stuff
« Reply #7 on: November 25, 2009, 01:36:00 PM »
I've got a site called "INSIDE CITY LIMITS" with 10 parcels in it. *shrug*
Re: Weird C3D Stuff
« Reply #8 on: November 25, 2009, 01:38:38 PM »
But there isn't any segments associated with it, that I can see anyway.
Great ... just what I needed. NOT!!
Re: Weird C3D Stuff
« Reply #9 on: November 25, 2009, 01:45:14 PM »
Well ... LOL I did a table on all the parcels 'INSIDE' and looky what I found. Does that make sense?
jugglerbri
Re: Weird C3D Stuff
« Reply #10 on: November 25, 2009, 02:25:00 PM »
In Civil 3D, parcels cannot be created, edited, or deleted.  They are defined when parcel segments enclose an area.  Just like you can't edit the length of a line, you can edit the beginning point and the ending point but you can't edit the length, it is defined as the distance between the starting and ending points.  In order to edit a parcel, you must edit the parcel segments that define it.  The thing that often times causes confusion is the name "Site".  In my opinion, this is a horrible name for this concept because civil engineering professionals, when they think of the term "site" they think of the location of the project.  They go on a "site visit".  A site is technically a topology.  Everything in the site interacts with everything else in the site.  Add to that, alignments within a site act as parcel segments.  My guess is you have some alignments in your site that are enclosing an area and defining a parcel.
Re: Weird C3D Stuff
« Reply #11 on: November 25, 2009, 02:37:57 PM »
As it turns out there is another one of these 'labels' for "OUTSIDE CITY LIMITS". I'm assuming this one label is for all the parcels within the site. *shrug*
Re: Weird C3D Stuff
« Reply #12 on: November 25, 2009, 02:39:29 PM »
I don't have any alignments within these sites.
Re: Weird C3D Stuff
« Reply #13 on: November 25, 2009, 02:45:00 PM »
It is a Parcel Area Label.....for the Site "INSIDE CITY LIMITS". A Site is just a special Parcel which contains other parcels, alignments & featurelines. So the Properties shows it as a Parcel, but the fact that the numbering defaults are shown for the properties is a clue that it is really a Site.
Re: Weird C3D Stuff
« Reply #14 on: November 25, 2009, 02:53:41 PM »
How can I turn it off or hide it?
thanks Jeff
