(defun C:99 (/ DIRFILE1 FN1 NAMEFILE1 T1 TEN Z0 Z1)
(setq Ten (getfiled "Select File" (getvar "dwgprefix") "*" 8))
(setq fn1 (strcat (getvar "dwgprefix") Ten))
(setq DirFile1 (vl-filename-directory fn1))
(setq NameFile1 (vl-filename-base fn1))
(setq t1 (strcat DirFile1 (chr 92) "doc.kml"))
(vl-file-copy fn1 (strcat DirFile1 (chr 92) "doc.kml"))
(setq Z0 (strcat DirFile1 (chr 92) "tempppppp111ggfssd.zip"))
(MakeEmptyZip Z0)
(if (/= (findfile t1) nil)
(Add2Zip t1 Z0)
(wait 2.0)
(setq Z1 (strcat DirFile1 (chr 92) NameFile1 "_.kmz"))
(vl-file-copy
Z0
Z1
(if (/= (findfile fn1) nil)
(vl-file-delete fn1)
(vl-file-delete t1)
(if (/= (findfile Z0) nil)
(vl-file-delete Z0)
(Princ)
(defun Add2Zip (srcFile destFile / app folder)
(setq app (vlax-create-object "Shell.Application"))
(setq folder (vlax-invoke app 'NameSpace destFile))
(vlax-invoke folder 'CopyHere srcFile)
(vlax-release-object folder)
(vlax-release-object app)
(defun MakeEmptyZip (destFile / fso fo)
(setq fso (vlax-create-object "Scripting.FileSystemObject"))
(setq fo (vlax-invoke fso 'OpenTextFile destFile '2 'true))
(vlax-invoke fo 'Write (strcat (chr 80) (chr 75) (chr 5) (chr 6)))
(repeat 18 (vlax-invoke fo 'Write (chr 256)))
(vlax-invoke fo 'Close)
(vlax-release-object fo)
(vlax-release-object fso)
;;(wait 0.01)
(defun wait (seconds / stop)
(setq stop (+ (getvar "DATE") (/ seconds 86400.0)))
(while (> stop (getvar "DATE")))
