Author Topic: -={Challenge}=- a way through a labyrinth  (Read 23971 times)
Re: -={Challenge}=- a way through a labyrinth
« Reply #30 on: November 21, 2009, 11:02:34 AM »
interesting possible application to using this to program a tool(s) optimum cutting path....
what if the labyrinth were 3D?
crazy good work and interesting to watch the evolution!
Andrea
« Reply #31 on: November 21, 2009, 02:26:16 PM »
here's my new one..
FINDWAY in LABYRINTH ;;
by: Andrea Andreetti nov. 20 2009 ;;
(defun c:lab (/ p1)
  (setq bpx nil)
  (setq p1 (getpoint))
  (setq sp (polar p1 2.35619 0.7071))
  (setq bp1 p1)
  (setq walllist nil)
 (setq l '( ( 1 1 1 1 1 0 2 0)
  ( 0 0 1 0 1 1 1 0)
  (-1 0 1 0 0 0 1 1)
  ( 1 0 0 0 1 0 0 1)
  ( 1 1 0 0 1 0 0 1)
  ( 0 1 0 1 1 1 1 1)
  ( 0 1 1 1 0 0 1 0)
  ( 0 1 0 0 0 0 1 0) )
;;;  (setq l '((2 0 1 1 1 1 1 1 1 0 1 0 0 1 1 1)
;;;            (1 0 1 0 0 0 1 0 1 1 1 1 1 1 1 1)
;;;            (1 0 1 0 1 0 1 0 0 0 1 0 0 0 0 0)
;;;            (1 0 1 1 1 0 1 1 0 1 1 1 1 1 1 1)
;;;            (1 1 1 1 0 0 0 1 0 0 0 0 0 0 0 1)
;;;            (1 0 0 0 0 1 0 1 1 1 0 1 1 0 1 1)
;;;            (1 1 1 1 0 1 0 1 0 1 0 1 1 0 1 0)
;;;            (0 0 1 0 0 1 0 0 0 1 0 1 1 1 1 1)
;;;            (1 0 1 1 0 1 1 1 1 1 1 1 0 0 0 1)
;;;            (1 1 1 1 1 1 0 1 0 0 0 0 0 1 1 -1)
  (labyrinth l p1)
  (command "._rectang" "_non" sp "_non" lr)
(defun labyrinth (lst p1)
  (setq points nil)
  (foreach n lst
    (foreach x n
      (setq points (append points (list p1)))
      (if (= x 0)
        (cube 0 p1)
      (if (= x 2)
          (setq _start p1)
          (cube 2 p1)
      (if (= x -1)
          (setq _end p1)
          (cube -1 p1)
      (setq p1 (list (+ (car p1) 1.0) (cadr p1) (caddr p1)))
    (setq p1 (list (car bp1) (- (cadr p1) 1.0) (caddr p1)))
(defun cube (value point / ul w1 w10 w11 w40 w73 w72)
  (setq ul (polar point 2.35619 0.7071)
        lr (polar point 5.49779 0.7071)
  (if (not bpx)
    (setq bpx ul)
  (setq bp2 point)
  (if (eq value 0)
    (progn (command "._rectang" "_non" ul "_non" lr)
           (setq walllist (append walllist (list point)))
  (if (eq value 2)
    (setq w1  "{\\fArial|b0|i0|c0|p34;\\C1;S}"
          w10 _start
          w11 _start
    (setq Start-T (createMT w1 w10 w11))
  (if (eq value -1)
    (setq w1  "{\\fArial|b0|i0|c0|p34;\\C3;E}"
          w10 _end
          w11 _end
    (setq End-T (createMT w1 w10 w11))
(defun createMT (w1 w10 w11)
  (if (and w1 w10 w11 )
    (entmakex (list (cons 0 "MTEXT")
                                (cons 100 "AcDbEntity")
                                (cons 100 "AcDbMText")
                                (cons 1 w1)
                                (cons 10 w10)
                                (cons 11 w11)
                                (cons 40 0.5)
                                '(50 . 0.0)
                                '(71 . 5)
                                '(72 . 5)
                                '(73 . 1)
(defun c:findway (/ nlstx nlst nextpoints _start _end dn)
  (vla-startundomark
  (setq nlstx nil
        nlst nil
        nextpoints nil
  (setq _startx (cdr (assoc 10 (entget start-t))))
  (setq dn (distance _startx (car points)))
  (setq _start (car points))
  (foreach n (cdr points)
    (if (< (distance _startx n) dn)
      (progn (setq dn (distance _startx n)) (setq _start n))
  (setq _endx (cdr (assoc 10 (entget end-t))))
  (setq dn (distance _endx (car points)))
  (setq _end (car points))
    (if (< (distance _endx n) dn)
      (progn (setq dn (distance _endx n)) (setq _end n))
  (way (list _start) walllist)
  (foreach j nlstx (command "_point" j))
  (vla-endundomark
(defun way (nlst blst)
  (setq rnlst (car (reverse nlst)))
  (setq nextpoints (list (list (car rnlst) (1+ (cadr rnlst)) (caddr rnlst))
                         (list (car rnlst) (1- (cadr rnlst)) (caddr rnlst))
                         (list (1+ (car rnlst)) (cadr rnlst) (caddr rnlst))
                         (list (1- (car rnlst)) (cadr rnlst) (caddr rnlst))
  (foreach n nextpoints
    (if (eq (vl-princ-to-string n) (vl-princ-to-string _end))
      (setq nlstx (append nlst (list _end)))
    (if (and (> (car n) (car sp))
             (< (car n) (car lr))
             (> (cadr n) (cadr lr))
             (< (cadr n) (cadr sp))
             (not (member n blst))
             (not (member n nlst))
      (way (append nlst (list n)) walllist)
Keep smile...
« Reply #32 on: November 21, 2009, 03:31:46 PM »
I just like to watch it  :-P  :evil:
« Reply #33 on: November 21, 2009, 11:54:19 PM »
Very nice Kerry!  :lol:
This uses the "Dead-End Filling" algorithm... { but doesn't like voids...   :-( }
Thanks Lee ..
I had a look at the filling algorithm ... there are actually a few interesting options.
« Reply #34 on: November 21, 2009, 11:59:41 PM »
Andrea,
I didn't run your code .. just had a look at the source.
I think you need to devise a method to eliminate superfluous cells in your path list.
Regards
« Reply #35 on: November 22, 2009, 07:24:12 AM »
Thanks Lee ..
It seems to produce good results for a "simple" maze, but it will fail with loops and voids - I'm trying to figure out a way to detect loops and such, but it seems impossible using my current methods.  :|
wizman
« Reply #36 on: November 22, 2009, 08:30:31 PM »
Good Thread Guys
i remember seeing this on jtb:http://blog.jtbworld.com/2009/02/space-filling-curves-in-theory-and.html
« Reply #37 on: November 22, 2009, 11:36:41 PM »
I don't see the relationship between this and a cutting path optimiser ... care to elucidate ?
3d would be possible but I'd need an incentive :)
« Reply #38 on: November 23, 2009, 12:43:41 PM »
From my perspective a tool path is much like a maze, only the goal is to remove material, and leave some behind; this seems like it would adapt to that purpose.
« Reply #39 on: November 23, 2009, 01:27:48 PM »
Good Thread Guys
Reminds me of:
http://www.theswamp.org/index.php?topic=30966.0
VovKa
  • Ukraine
« Reply #40 on: November 23, 2009, 04:18:56 PM »
let Autodesk Map guys do the job :)
(defun SolveLabyrinth
       (SS StartPoint EndPoint / VariablesID TopologyName TopologyID TraceID Path)
  (setq TopologyName "SolveLabyrinth")
  (if (and (setq VariablesID (tpm_varalloc))
   (tpm_varset VariablesID "CREATE_NODE" 0)
   (tpm_mntbuild VariablesID TopologyName "" 2 nil SS)
   (tpm_varfree VariablesID)
   (setq TopologyID (tpm_acopen TopologyName nil))
   (setq TraceID (tpm_tracealloc TopologyID))
   (tpm_traceshort TraceID
   (tpm_elemfind TopologyID 1 StartPoint)
   (tpm_elemfind TopologyID 1 EndPoint)
    (while (and (tpm_traceshortscan TraceID 3) (tpm_traceshortscan TraceID 3))
      (setq Path
     (cons
       (entget
(cdr (assoc -2 (tpm_elemget TopologyID (tpm_traceshortscan TraceID 0))))
       Path
  (tpm_tracefree TraceID)
  (tpm_acclose TopologyID)
  (tpm_mnterase TopologyName)
  Path
(defun test (lst / SS StartPoint EndPoint lst y x Step)
  (setq Step 10.0
SS   (ssadd)
y    0
  (mapcar (function
    (lambda (r nr)
      (setq x 0)
      (mapcar (function
(lambda (rc rnc nrc / p)
  (setq p (list (* x Step) (* y Step)))
  (if (and (not (zerop (* rc rnc))) (< (1+ x) (length r)))
    (ssadd (entmakex (list (cons 0 "LINE")
   (cons 10 p)
   (list 11 (* (1+ x) Step) (* y Step))
   SS
  (if (and (not (zerop (* rc nrc))) (< (1+ (abs y)) (length lst)))
   (cons 10 p)
   (list 11 (* x Step) (* (1- y) Step))
   SS
  (cond ((= rc 2) (setq StartPoint p))
((= rc -1) (setq EndPoint p))
  (setq x (1+ x))
      r
      (append (cdr r) (list (car r)))
      nr
      (setq y (1- y))
  lst
  (append (cdr lst) (list (car lst)))
  (if (and SS
   (or StartPoint (setq StartPoint (getpoint "\nEntrance: ")))
   (or EndPoint (setq EndPoint (getpoint StartPoint "\nExit: ")))
    (foreach Ent (SolveLabyrinth SS StartPoint EndPoint)
      (vla-put-Color (vlax-ename->vla-object (entmakex Ent)) 3)
(setq l '((2 0 1 1 1 1 1 1 1 0)
          (1 0 1 0 0 0 1 0 1 1)
          (1 0 1 0 1 0 1 0 0 0)
          (1 0 1 1 1 0 1 1 0 1)
          (1 1 1 1 0 0 0 1 0 1)
          (1 0 0 0 0 1 0 1 1 1)
          (1 1 1 1 0 1 0 1 0 1)
          (0 0 1 0 0 1 0 0 0 1)
          (1 0 1 1 0 1 1 1 0 1)
          (1 1 1 1 1 1 0 1 0 -1)
(test l)
