Author Topic: -={Challenge}=- a way through a labyrinth  (Read 23936 times)
Re: -={Challenge}=- a way through a labyrinth
« Reply #15 on: November 20, 2009, 11:56:35 AM »
I will dig thru my routines...I remember a routine that would draw up, create a puzzle labyrinth.
Maybe it could help in solving it.
I found it. By Bill Fane, Maze.lsp
It is an old routine and needs a lot of cleanup.
(try) to try it out.
(sol) for the solution.
need to convert all english command... :realmad:
Not hard.  Open in Notepad, and use the replace option ( ctr + h ), and replace ' command " ' with ' command "_. '.  Just check what is being replaced, because some of it shouldn't be, so go one at a time.  Should get most, if not all.
Andrea
« Reply #16 on: November 20, 2009, 12:13:06 PM »
you thing ???
what about all sub-command ??
eg:
(command "_zoom" "_E")
or ..(command "_-PLOT" .... ? ? ? )
so that can't be done without doing it 1 by 1
Keep smile...
« Reply #17 on: November 20, 2009, 12:16:05 PM »
Andrea,
what do you get with this?
( ( 1 1 1 1 1 0 2 0)
  ( 0 0 1 0 1 1 1 0)
  (-1 0 1 0 0 0 1 1)
  ( 1 0 0 0 1 0 0 1)
  ( 1 1 0 0 1 0 0 1)
  ( 0 1 0 1 1 1 1 1)
  ( 0 1 1 1 0 0 1 0)
  ( 0 1 0 0 0 0 1 0) )
« Reply #18 on: November 20, 2009, 12:45:33 PM »
you thing ???
eg:
Ah.... true...
Didn't think about the sub command parts.  Guess it would take more work then.  :wink:
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #19 on: November 20, 2009, 03:13:37 PM »
Wow!  :-o
I am sorry, I can look a code only tomorrow.
I hope, you perfectly will spend time with this task!
« Reply #20 on: November 20, 2009, 03:15:27 PM »
I'm trying to come up with a recursive version, but I suck at recursive programing, so this is a double challenge for me.  I think I can do it though.
« Reply #21 on: November 20, 2009, 03:21:48 PM »
I'm just not sure of the output - at the minute mine just outputs "coordinates" in the list...
« Reply #22 on: November 20, 2009, 03:30:07 PM »
That is how I was going to do my Lee.
« Reply #23 on: November 20, 2009, 04:50:29 PM »
My Version 2:
(defun labyrinth (lst / get_nth doups A CHK CHKN CLST I ITM J
                                       L LST OLST OP OPN X Y rLst)
  ;; by Lee McDonnell
  (setq oLst '((1 0) (0 -1) (-1 0) (0 1)))
  (defun get_nth (u v op)
    (setq u (+ (car op) u) v (+ (cadr op) v))
    (nth u (nth v lst)))
  (defun doups (lst / x result)
    (while (setq x (car lst))
      (if (vl-position x (setq lst (cdr lst)))
        (setq lst (vl-remove x lst))
        (setq result (cons x result))))
    (reverse result))
  ;; Find Coordinates of Start Position
  (setq l lst i 0 j 0)
  (while
      (setq x (caar l))
      (cond (  (not x) (setq i nil j nil))
            (  (= 2 x) nil)
            (  (< 1 (length (car l)))
               (setq l (cons (cdar l) (cdr l)) i (1+ i)))
            (  (setq l (cdr l) j (1+ j) i 0)))))
  ;; "Wall the Labyrinth"
  (setq lst (mapcar
              (function
                (lambda (x)
                  (append '(0) x '(0)))) lst))
  (repeat (length (car lst))
    (setq a (cons 0 a)))
  (setq lst (append (list a) lst (list a)) i (1+ i) j (1+ j))
  ;; Get the first Operator
  (foreach x '((1 0) (0 -1) (-1 0) (0 1))
      (if (not (zerop (nth (+ (car x) i)
                           (nth (+ (cadr x) j) lst))))
        (setq opn (vl-position x oLst))))
  (setq chkn (if (zerop opn) 3 (1- opn)))
  (while
      (setq op (nth opn oLst)   chk (nth chkn oLst)
            x  (get_nth i j op)   y (get_nth i j chk))
      (setq cLst (cons (list (1- i) (1- j)) cLst))
      (cond (  (and (= 1 x) (zerop y))
               (mapcar 'set '(i j) (mapcar '+ (list i j) (nth opn oLst))))
            (  (and (or (= 0 x) (= 1 x)) (= 1 y))
               (setq chkn (if (= 0 chkn) 3 (1- chkn))
                     opn  (if (= 0 opn)  3 (1- opn)))
            (  (and (= 0 x) (or (= -1 y) (= 0 y)))
               (setq chkn (if (= 3 chkn) 0 (1+ chkn))
                     opn  (if (= 3 opn)  0 (1+ opn))))
            (  (= -1 x)
               (mapcar 'set '(i j) (mapcar '+ (list i j) (nth opn oLst))) nil))))
  (setq cLst (vl-sort (doups (cons (list (1- i) (1- j)) cLst))
               (function
                 (lambda (a b)
                   (if (= (car a) (car b))
                     (< (cadr a) (cadr b))
                     (< (car a) (car b)))))))
  (foreach x cLst
    (print x)
    (entmake (list (cons 0 "POINT") (cons 10 (list (car x) (- (cadr x)))))))
  (princ))
{ Missing Corners }   :-(
« Reply #24 on: November 20, 2009, 07:02:24 PM »
Final Offering... still not perfect..
(defun labyrinth (lst / get_nth doups cube A CHK CHKN CLST I
                        ITM J L LST OLST OP OPN X Y rLst u v)
  ;; by Lee McDonnell
  (setvar "PDMODE" 34)
  (setvar "PDSIZE" 0.4)
    (reverse result))
  (defun cube (pt / pi/4)
    (setq pi/4 (/ pi 4.) d (/ (sqrt 2.) 2.))
    (entmake
      (append (list (cons 0 "LWPOLYLINE")
                    (cons 100 "AcDbEntity")
                    (cons 100 "AcDbPolyline")
                    (cons 90 4)
                    (cons 70 1)
                    (cons 62 3)
                    (cons 10 (polar pt pi/4 d))
                    (cons 10 (polar pt (* 3 pi/4) d))
                    (cons 10 (polar pt (* 5 pi/4) d))
                    (cons 10 (polar pt (* 7 pi/4) d))))))
  (while
      (setq x (caar l))
            (  (= 2 x) nil)
  (setq lst (mapcar
              (function
                (lambda (x)
  (setq u 1)
  (foreach x lst
    (setq u (1- u) v -1)
    (foreach y x
      (setq v (1+ v))
      (if (zerop y)
        (cube (list v u 0.)))))
  (while
            (  (= -1 x)
               (function
                 (lambda (a b)
    (while (cadr cLst)
      (if (< 1 (abs (- (apply '+ (car cLst)) (apply '+ (cadr cLst)))))
        (cond (  (= 1 (nth (+ 2 (caar cLst)) (nth (1+ (cadar cLst)) lst)))
                 (setq rLst (cons (list (1+ (caar cLst)) (cadar cLst)) rLst)))
              (  (setq rLst (cons (list (caar cLst) (1+ (cadar cLst))) rLst)))))
      (setq rLst (cons (car cLst) rLst) cLst (cdr cLst)))
  (setq cLst (append cLst rLst))
  (foreach x cLst
    (print x)
    (entmake (list (cons 0 "POINT") (cons 10 (list (1+ (car x)) (- (1+ (cadr x))))) (cons 62 2))))
  (princ))
« Reply #25 on: November 21, 2009, 08:22:31 AM »
How about this .. ?
The code is base (loosely) on the Bellman's flood algorithm.
Argument:
Matrix of a labyrinth
0 = a wall
1 = a corridor
2 = start of a labyrinth
-1 = the end of a labyrinth
(setq l '((1 1 1)
          (1 0 -1)
          (2 0 1)
          (1 0 1)
(kdub_labyrinth l)
(setq l '((1 1 1)
          (1 0 -1)
          (2 0 1)
          (1 1 1)
(kdub_labyrinth l)
(setq l '((1 1 1) (1 0 -1) (2 1 1) (1 1 1)))
(kdub_labyrinth l)
(setq l '((1 1 1 1 1 0 2 0)
          (0 0 1 0 1 1 1 0)
          (-1 0 1 0 0 0 1 1)
          (1 0 0 0 1 0 0 1)
          (1 1 0 0 1 0 0 1)
          (0 1 0 1 1 1 1 1)
          (0 1 1 1 0 0 1 0)
          (0 1 0 0 0 0 1 0)
(kdub_labyrinth l)
(setq l '((2 0 1 1 1 1 1 1 1 0)
          (1 0 1 0 0 0 1 0 1 1)
          (1 0 1 0 1 0 1 0 0 0)
          (1 0 1 1 1 0 1 1 0 1)
          (1 1 1 1 0 0 0 1 0 1)
          (1 0 0 0 0 1 0 1 1 1)
          (1 1 1 1 0 1 0 1 0 1)
          (0 0 1 0 0 1 0 0 0 1)
          (1 0 1 1 0 1 1 1 0 1)
          (1 1 1 1 1 1 0 1 0 -1)
(kdub_labyrinth l)
« Last Edit: November 21, 2009, 08:33:37 AM by Kerry Brown »
« Reply #26 on: November 21, 2009, 08:38:00 AM »
Here's some info .. pretty basic, but gives the idea http://micromouse.cannock.ac.uk/maze/fastfloodsolver.htm
It's still a bit rough, but I <think> it will handle most data patterns.
Nice problem Evgeniy :) ... took a little longer than I'd anticipated.  :|
Regards
;; CodeHimBelonga kdub@theSwamp (20091121)
(defun kdub_labyrinth (l /
                         BP1
                         CELL
                         CELLCOUNT
                         COL
                         FRONTIERMAP
                         HEIGHT
                         INDEX
                         INGATE
                         LST
                         OFFSETMAP
                         OUTGATE
                         P0
                         P1
                         PPT
                         PREVIOUSCELL
                         ROW
                         ROWWALL
                         ROWWIDTH
                         SINGLEARRAY
                         TRIPMAP
                         XCELL
                         _checkfrontier
                         _replace_nth
                         _DrawGate
                         _DrawCube
  ;; LIBRARY
  (defun _checkfrontier (cell offset / )
    (if (and (not (minusp (setq index (+ cell offset))))
             (= 1 (nth index FrontierMap))
      (progn                                 ; if the cell is an unvisited corridor cell
        (setq FrontierMap  (_replace_nth FrontierMap previousCell index)
              previousCell index
              OffsetMap    (_replace_nth OffsetMap index (- offset))
;;;        (princ (strcat "\n   Frontier Cell :" (itoa index)))
;;;        (princ (strcat "\n  FrontierMap: "
;;;                       (vl-princ-to-string FrontierMap)
;;;        (princ (strcat "\n  OffsetMap  : "
;;;                       (vl-princ-to-string OffsetMap)
;;;                       "\n"
  (defun _replace_nth (lst i itm)
    (if lst
      (if (> i 0)
        (cons (car lst) (_replace_nth (cdr lst) (1- i) itm))
        (cons itm (cdr lst))
  (defun _DrawGate (PT ST /)
    (entmakex (list (cons 0 "TEXT")
                    (cons 100 "AcDbText")
                    (cons 1 ST)
                    (cons 10 (polar PT 2.35619 0.7071))
                    ;;(cons 11 (polar PT 5.49779 0.7071))
                    (cons 11 PT)
                    '(40 . 0.5)
                    '(41 . 1.0)
                    '(50 . 0.0)
                    '(51 . 0.0)
                    '(71 . 1)
                    '(72 . 1)
                    '(73 . 2)
  (defun _DrawCube (PT /)
    (command "._rectang"
             "_non"
             "_non"
  (repeat (+ 2 (length (car l))) (setq rowWall (cons 0 rowWall)))
  (setq lst         (append (list rowWall)
                            (mapcar (function (lambda (x) (append '(0) x '(0)))) l)
                            (list rowWall)
        height      (length lst)
        rowWidth    (length (car lst))
        SingleArray (apply 'append lst)
        cellcount   (length SingleArray)
        InGate      (vl-position 2 SingleArray) ; zero based
        OutGate     (vl-position -1 SingleArray) ; zero based
  (setq FrontierMap  (_replace_nth SingleArray InGate 1)
        FrontierMap  (_replace_nth FrontierMap OutGate 1)
        OffsetMap    FrontierMap
        cell         OutGate
        previousCell Cell
  (while (/= cell InGate)
    ;; (princ (strcat "\nCell :" (itoa cell)))
    ;; Find the Cells Neighbours
    (_checkfrontier cell 1)
    (_checkfrontier cell -1)
    (_checkfrontier cell rowWidth)
    (_checkfrontier cell (- rowWidth))
    (setq cell (nth cell FrontierMap))
  (setq xcell (+ cell (nth cell OffsetMap)))
  (while (/= xcell OutGate)
    (setq TripMap (cons xcell TripMap)
          xcell   (+ xcell (nth xcell OffsetMap))
  (setq P0 (getpoint)
        P1 P0
  (foreach n lst
    (foreach x n
      (if (= x 0)
        (_Drawcube P1)
      (setq p1 (list (+ (car p1) 1.0) (cadr p1) (caddr p1)))
    (setq p1 (list (car P0) (- (cadr p1) 1.0) (caddr p1)))
  (_DrawGate (polar (polar P0 (* PI 1.5) (/ InGate rowWidth))
                    0.0
                    (rem InGate rowWidth)
             "S"
  (_DrawGate (polar (polar P0 (* PI 1.5) (/ OutGate rowWidth))
                    0.0
                    (rem OutGate rowWidth)
             "E"
  (setvar "PDSIZE" 0.25)
  (foreach x TripMap
    (setq row (/ x rowWidth)
          col (rem x rowWidth)
          ppt (polar (polar P0 (* PI 1.5) (/ x rowWidth))
                     0.0
                     (rem x rowWidth)
    (entmake (list (cons 0 "POINT") (cons 10 ppt) (cons 62 2)))
« Last Edit: November 21, 2009, 09:00:17 AM by Kerry Brown »
« Reply #27 on: November 21, 2009, 08:56:48 AM »
a couple of variations ...
          (1 0 1 0 0 1 0 1 1 1)
          (0 0 1 1 1 1 0 0 0 1)
(kdub_labyrinth l)
          (0 0 1 1 1 1 0 1 0 1)
(kdub_labyrinth l)
« Reply #28 on: November 21, 2009, 09:15:17 AM »
and it seems to handle voids in the pattern as expected.
added:
lorraine saw this on my screen and asked if I was playing PacMan  :lol:  :-P
(setq l '((1 1 -1 0 2 1 1 0)
          (0 1 1 0 1 1 1 0)
          (1 1 0 1 0 0 1 1)
          (1 0 0 1 1 0 0 1)
          (1 1 0 0 1 0 0 1)
          (0 1 0 1 0 1 1 1)
          (0 1 1 1 1 1 1 0)
          (0 1 0 0 0 0 1 0)
(kdub_labyrinth l)
« Last Edit: November 21, 2009, 09:24:34 AM by Kerry Brown »
« Reply #29 on: November 21, 2009, 10:30:15 AM »
Very nice Kerry!  :lol:
This uses the "Dead-End Filling" algorithm... { but doesn't like voids...   :-( }
(defun labyrinth (lst / x@ij getsum cube A B D I J NLST U V X flag)
  ;; by Lee McDonnell
  (defun x@ij (x i j l / a b)
    (setq a -1)
    (mapcar
      (function
        (lambda (u)
          (setq b -1 a (1+ a))
          (mapcar
            (function
              (lambda (v)
                (setq b (1+ b))
                (if (and (= i b) (= j a)) x v))) u))) l))
  (defun getSum (i j l / rl)
    (setq rl (list (nth (1+ i) (nth j l))
                   (nth i (nth (1- j) l))
                   (nth (1- i) (nth j l))
                   (nth i (nth (1+ j) l))))
    (setq rl (subst 1 -1 rl) rl (subst 1 2 rl))
    (apply '+ rl))
    (entmake
                    (cons 90 4)
                    (cons 70 1)
                    (cons 62 3)
  (setq nlst (mapcar
               (function
                 (lambda (x)
  (repeat (length (car nlst))
  (setq nlst (append (list a) nlst (list a)))
  (setq u 1 flag t)
  (foreach x nlst
    (foreach y x
      (setq v (1+ v))
      (if (zerop y)
  (while flag
    (setq j 0 flag nil)
    (foreach x lst
      (setq i 0 j (1+ j))
      (foreach y x
        (setq i (1+ i))
        (if (and (= 1 (nth i (nth j nlst)))
                 (not (vl-position (nth i (nth j nLst)) '(-1 2))))
          (if (= 1 (getSum i j nlst))
              (cube (list i (- j) 0))
              (setq flag t nlst (x@ij 0 i j nlst))))))))
  (setq u 1)
  (foreach x nlst
    (foreach y x
      (setq v (1+ v))
      (if (= 1 y)
        (entmake (list (cons 0 "POINT") (cons 10 (list v u)) (cons 62 2))))))
  (princ))
« Last Edit: November 21, 2009, 11:00:34 AM by Lee Mac »
