Author Topic: -={Challenge}=- a way through a labyrinth  (Read 22120 times)
ElpanovEvgeniy
  • Moscow (Russia)
« on: November 20, 2009, 06:23:09 AM »
It is necessary to write the program finding pass through a labyrinth.
Argument:
Matrix of a labyrinth
0 = a wall
1 = a corridor
2 = start of a labyrinth
-1 = the end of a labyrinth
It is necessary to find pass through a labyrinth.
(setq l '((2 0 1 1 1 1 1 1 1 0)
          (1 0 1 0 0 0 1 0 1 1)
          (1 0 1 0 1 0 1 0 0 0)
          (1 0 1 1 1 0 1 1 0 1)
          (1 1 1 1 0 0 0 1 0 1)
          (1 0 0 0 0 1 0 1 1 1)
          (1 1 1 1 0 1 0 1 0 1)
          (0 0 1 0 0 1 0 0 0 1)
          (1 0 1 1 0 1 1 1 0 1)
          (1 1 1 1 1 1 0 1 0 -1)
(labyrinth l)
Last Edit: Has corrected the list with a labyrinth.
« Last Edit: November 20, 2009, 06:53:30 AM by ElpanovEvgeniy »
Re: -={Challenge}=- a way through a labyrinth
« Reply #1 on: November 20, 2009, 07:59:35 AM »
Interesting challenge!
Andrea
« Reply #2 on: November 20, 2009, 08:50:47 AM »
my contribution.... :lol:
(defun c:lab (/ p1 bpx lr)
  (setq p1 (getpoint))
  (setq bp1 p1)
  (labyrinth l p1)
(command "._rectang" "_non" bpx "_non" lr)
(defun labyrinth (lst p1)
  (foreach n lst
    (foreach x n
      (if (= x 0)
        (cube 0 p1)
      (if (= x 2)
        (cube 2 p1)
      (if (= x -1)
        (cube -1 p1)
      (setq p1 (list (+ (car p1) 1.0) (cadr p1) (caddr p1)))
    (setq p1 (list (car bp1) (- (cadr p1) 1.0) (caddr p1)))
(defun cube (value point / ul w1 w10 w11 w40 w73 w72)
  (setq ul (polar point 2.35619 0.7071)
        lr (polar point 5.49779 0.7071)
  (if (not bpx)(setq bpx ul))
  (if (eq value 0)
    (command "._rectang" "_non" ul "_non" lr)
  (if (eq value 2)
    (setq w1  "Start"
          w10 ul
          w11 ul
          w73 1
          w72 2
  (if (eq value -1)
    (setq w1  "End"
          w10 lr
          w11 lr
          w73 3
          w72 0
(if (and w1 w10 w11 w73 w72)
  (setq ltext (entmakex (list (cons 0 "TEXT")
                              (cons 100 "AcDbEntity")
                              (cons 100 "AcDbText")
                              (cons 1 w1)
                              (cons 10 w10)
                              (cons 11 w11)
                              (cons 40 0.5)
                              (cons 73 w73)
                              (cons 72 w72)
« Last Edit: November 20, 2009, 11:39:14 AM by Andrea »
Keep smile...
« Reply #3 on: November 20, 2009, 08:55:10 AM »
haha, nice idea Andrea - but the user still has to trace his/her way through....  ;-)
Andrea
« Reply #4 on: November 20, 2009, 09:01:33 AM »
Yep..   8-)
I just having fun playing with this..   ;-)
« Last Edit: November 20, 2009, 09:43:27 AM by Andrea »
Keep smile...
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #5 on: November 20, 2009, 09:13:32 AM »
Hi Andrea!
The good start. :)
It is necessary to erase only superfluous rectang...
I hasten to warn, and if there are some ways?
For example
((2 1 1)
 (1 0 1)
 (1 1 -1))
« Reply #6 on: November 20, 2009, 10:01:11 AM »
Tried implementing the "Right-Hand" Algorithm... and failed.
But will post what I have.. at the moment, I get an endless loop.
<Removed Erroneous code>
« Last Edit: November 20, 2009, 10:25:09 AM by Lee Mac »
SEANT
« Reply #7 on: November 20, 2009, 10:17:06 AM »
The layout of this maze certainly seems to reward the Left Hand (vs. Right Hand) rule. :-)
Sean Tessier
AutoCAD 2016 Mechanical
« Reply #8 on: November 20, 2009, 10:22:57 AM »
Both left and right should yield good results for an arbitrary maze... I thought,.
Anyway, this works (I think!)
(defun labyrinth (lst / get_nth A CHK CHKN I J L LST OLST OP OPN X Y)
  ;; by Lee McDonnell
  (setq oLst '((1 0) (0 -1) (-1 0) (0 1)))
  (defun get_nth (u v op)
    (setq u (+ (car op) u) v (+ (cadr op) v))
    (nth u (nth v lst)))
  ;; Find Coordinates of Start Position
  (setq l lst i 0 j 0)
  (while
      (setq x (caar l))
      (cond (  (not x) (setq i nil j nil))
            (  (= 2 x) nil)
            (  (< 1 (length (car l)))
               (setq l (cons (cdar l) (cdr l)) i (1+ i)))
            (  (setq l (cdr l) j (1+ j) i 0)))))
  ;; "Wall the Labyrinth"
  (setq lst (mapcar
              (function
                (lambda (x)
                  (append '(0) x '(0)))) lst))
  (repeat (length (car lst))
    (setq a (cons 0 a)))
  (setq lst (append (list a) lst (list a)) i (1+ i) j (1+ j))
  ;; Get the first Operator
  (foreach x '((1 0) (0 -1) (-1 0) (0 1))
      (if (not (zerop (nth (+ (car x) i)
                           (nth (+ (cadr x) j) lst))))
        (setq opn (vl-position x oLst))))
  (setq chkn (if (zerop opn) 3 (1- opn)))
  (while
      (setq op (nth opn oLst) chk (nth chkn oLst))
      ;; get Target square
      (setq x (get_nth i j op)
            ;; Get Right hand check
            y (get_nth i j chk))
      (print (list (1- i) (1- j)))
      (cond (  (and (= 1 x) (zerop y))
               (mapcar 'set '(i j) (mapcar '+ (list i j) (nth opn oLst))))
            (  (and (or (= 0 x) (= 1 x)) (= 1 y))
               (setq chkn (if (= 0 chkn) 3 (1- chkn))
                     opn  (if (= 0 opn)  3 (1- opn)))
            (  (and (= 0 x) (or (= -1 y) (= 0 y)))
               (setq chkn (if (= 3 chkn) 0 (1+ chkn))
                     opn  (if (= 3 opn)  0 (1+ opn))))
            (  (= -1 x) nil))))   ;; exit
  (princ))
« Last Edit: November 20, 2009, 10:26:33 AM by Lee Mac »
SEANT
« Reply #9 on: November 20, 2009, 10:30:19 AM »
I also think that’s true.   This particular layout, though, would be navigated a bit quicker with the left hand.
Sean Tessier
VovKa
  • Ukraine
« Reply #10 on: November 20, 2009, 10:47:04 AM »
Evgeniy loves keeping people busy for the whole weekend :)
Andrea
« Reply #11 on: November 20, 2009, 11:07:40 AM »
well....my way to finish the week !  ;-)
(defun c:lab (/ p1)
  (setq bpx nil)
  (setq bp1 p1)
  (setq walllist nil)
  (labyrinth l p1)
  (foreach n lst
    (foreach x n
      (if (= x 0)
        (cube 0 p1)
      (if (= x 2)
        (cube 2 p1)
      (if (= x -1)
        (cube -1 p1)
  (if (not bpx)
    (setq bpx ul)
  (setq bp2 point)
  (if (eq value 0)
    (progn (command "._rectang" "_non" ul "_non" lr)
           (setq walllist (append walllist (list point)))
  (if (eq value 2)
    (setq w1  "Start"
          w10 ul
          w11 ul
          w73 1
          w72 2
  (if (eq value -1)
    (setq w1  "End"
          w10 lr
          w11 lr
          w73 3
          w72 0
                                (cons 1 w1)
                                (cons 10 w10)
                                (cons 11 w11)
                                (cons 40 0.5)
                                (cons 73 w73)
                                (cons 72 w72)
(defun c:findway ()
  (setq nlstx nil
        nlst nil
        nextpoints nil
  (way (list bp1) walllist)
  (foreach j nlstx (command "_point" j))
(defun way (nlst blst)
  (setq rnlst (car (reverse nlst)))
  (setq nextpoints (list (list (car rnlst) (1+ (cadr rnlst)) (caddr rnlst))
                         (list (car rnlst) (1- (cadr rnlst)) (caddr rnlst))
                         (list (1+ (car rnlst)) (cadr rnlst) (caddr rnlst))
                         (list (1- (car rnlst)) (cadr rnlst) (caddr rnlst))
  (foreach n nextpoints
    (if (eq (vl-princ-to-string n) (vl-princ-to-string bp2))
      (setq nlstx (append nlst (list bp2)))
    (if (and (> (car n) (car bpx))
             (< (car n) (car lr))
             (> (cadr n) (cadr lr))
             (< (cadr n) (cadr bpx))
             (not (member n blst))
             (not (member n nlst))
      (way (append nlst (list n)) walllist)
« Last Edit: November 20, 2009, 11:39:31 AM by Andrea »
Keep smile...
GDF
« Reply #12 on: November 20, 2009, 11:19:32 AM »
I will dig thru my routines...I remember a routine that would draw up, create a puzzle labyrinth.
Maybe it could help in solving it.
GDF
« Reply #13 on: November 20, 2009, 11:30:57 AM »
I found it. By Bill Fane, Maze.lsp
It is an old routine and needs a lot of cleanup.
(try) to try it out.
(sol) for the solution.
Andrea
« Reply #14 on: November 20, 2009, 11:41:24 AM »
need to convert all english command... :realmad:
Keep smile...
