CAD Forums > Microstation
Levels greyed out
PHX cadie:
Ok have to get off the plot stamp thing thing, gatta emergency:
With certain files on my original CPU the levels from the reference files are greyed out (subdued) and impossible to change the color/symbology. Yet when another person from a different office would open the same file, no problem. When they open files a dialog box would open and they would open with the company workspace. So I traded CPU's and I would get the same dialog box, problem solved........till we get new CPU's :cry:
What would cause the levels of a reference file to be subdued in the level manager?
(these are the levels of a reference file to a sheet file, (model) then is self ref'd into layout)
Thx's!
mjfarrell:
the first thought I have might be user permissions....
or something to do with your LVL Library file/and or location of it
where in the file structure is Projectwise handling user or group login?
PHX cadie:
I do not know, but when I first noticed this, it's on a file from our server not on PW. Then I opened a file on PW, that I knew didn't have any problems and its the same, (levels being subdued).
I should mention in model the levels are not grey'd out only from layout.
mjfarrell:
--- Quote from: PHX cadie on November 20, 2009, 07:24:22 am ---I do not know, but when I first noticed this, it's on a file from our server not on PW. Then I opened a file on PW, that I knew didn't have any problems and its the same, (levels being subdued).
--- End quote ---
this page seems to indicate that is 'normal' behavior....http://communities.bentley.com/forums/thread/88342.aspx
mjfarrell:
it is also suggested that this command will enable you to have control back...
--- Quote ---the following variable provides that functionality
MS_LEVEL_EDIT_NESTED_ATTACHMENT_LEVELS
--- End quote ---
Navigation
[0] Message Index
[#] Next page
Go to full version
