Author Topic: Lightweight alternative to Civil3D?  (Read 5387 times)
dgorsman
« on: November 16, 2009, 03:24:06 PM »
We only need to do a little surface modelling along with some rough cut and fill calculations, so the cost of Civil3D isn't worth it to us - we wouldn't be using, what, 90% of its capabilities?  Can anybody recommend a lightweight program that can create a triangulated surface model from surveyed points (X,Y,Z,description format) along with some basic modification and volume calculations?
I *think* I can do this in-house- already researched the algorithms - but I'm not sure that would be cost effective.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Willie
  • Going nowhere slowly
Re: Lightweight alternative to Civil3D?
« Reply #1 on: November 16, 2009, 05:44:42 PM »
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8  64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
Scott
« Reply #2 on: November 17, 2009, 11:36:23 PM »
If you have an older version of autocad, try www.ezysurf.com
dgorsman
« Reply #3 on: November 18, 2009, 11:25:16 AM »
Thanks guys, I'll have a look into those.
try {GreatPower;}
   finally
      {MasterBasics;}
