Author Topic: -={ Challenge }=- Matrix Determinant  (Read 14329 times)
« on: November 12, 2009, 08:40:39 AM »
The Challenge:
To create a program that will calculate the determinant of any nxn matrix with entries in the Real space.
The program should take one argument - the matrix - which should be formulated as a list, for example:
2x2 Matrix:
'( (1 2)
   (3 4) )
3x3 Matrix:
'( (1 2 3)
   (3 4 5)
   (5 6 7) )
As a little background on Matrices and Determinants....
A Matrix (not the film) is purely an array of entries which can represent vectors (usually), coefficients of systems of equations, and other such quantities. They are used in a huge range of applications... from solving systems of simultaneous/differential equations... to applying transformations to vectors.
The determinant is also a useful calculation... geometrically, it can be thought of as the area of a parallelogram, the sides of which are the vectors of the matrix. And this can be extended to 3-dimensions with a 3x3 matrix, and thought of as the parallelepiped formed by the 3 vectors contained in the matrix.
The determinant is also a necessary element when calculating the Inverse of a matrix - a necessary component in matrix arithmetic.
Methods for Calculation...
I believe the most common method for calculating the determinant is by Laplace's Formula:
For a matrix of size n. Where, when calculating the determinant along row i, Mij is the determinant of the matrix formed by removing row i and column j from the orignal matrix.
This is the route that I have followed.
But there are many other methods that can be used... many of which are outlined here.
My Offering:
;; Matrix Determinant  -  Lee Mac
;; Args: m - nxn matrix
(defun detm ( m / i j )
    (setq i -1 j 0)
        (   (null (cdr  m)) (caar m))
        (   (null (cddr m)) (- (* (caar m) (cadadr m)) (* (cadar m) (caadr m))))
        (   (apply '+
                (mapcar
                   '(lambda ( c ) (setq j (1+ j))
                        (* c (setq i (- i))
                            (detm
                                (mapcar
                                   '(lambda ( x / k )
                                        (setq k 0)
                                        (vl-remove-if '(lambda ( y ) (= j (setq k (1+ k)))) x)
                                    (cdr m)
                    (car m)
Enjoy!
Lee
« Last Edit: November 12, 2013, 11:58:38 AM by Lee Mac »
Re: -={ Challenge }=- Matrix Determinant
« Reply #1 on: November 12, 2009, 10:49:17 AM »
We're not helping you with your home work.  :evil:
Just kidding, Sorry to say this math exceeds my knowledge and perhaps my understanding.
I need more pictures at the elementary level.
TimSpangler
  • CAD Naked!!
« Reply #2 on: November 12, 2009, 11:22:34 AM »
Yeah..What he said.... :lmao:
ACA 2015 - Windows 7 Pro
gile
  • Marseille, France
« Reply #3 on: November 12, 2009, 01:19:52 PM »
Here's my way (from here)
;; COFACT (gile)
;; Returns the cofactor associated to ij item of a matrix
;; Arguments
;; i = row index (first row = 1)
;; j = column index (first column = 1)
;; m = a matrix
(defun cofact (i j m)
  (* (determ
       (remove-i (1- i) (mapcar '(lambda (x) (remove-i (1- j) x)) m))
     (expt -1 (+ i j))
;; DETERM (gile)
;; Returns the déterminant of a matrix
;; Argument: a matrix
(defun determ (m)
  (if (= 2 (length m))
    (- (* (caar m) (cadadr m)) (* (caadr m) (cadar m)))
    ((lambda (r n)
       (apply '+
              (mapcar '(lambda (x) (* x (cofact 1 (setq n (1+ n)) m))) r)
      (car m)
      0
;; REMOVE-I (gile)
;; Returns the list but item at specified index (first item = 0)
;; Arguments: the index of item to be remove and the list
(defun remove-i (i l)
  (if (or (zerop i) (null l))
    (cdr l)
    (cons (car l) (remove-i (1- i) (cdr l)))
« Last Edit: November 12, 2009, 02:12:04 PM by gile »
Strucmad
« Reply #4 on: November 12, 2009, 04:39:29 PM »
I wish my code skills were more advanced, I would love to play...
why not throw in some 2nd order non-homogeneous DE's with constant coefficients while your at it :-D
or maybe some eigenvalue characteristic polynomials....(I love doing them by hand).
« Reply #5 on: November 13, 2009, 04:44:41 AM »
AcGeMatrix3d::det();  :evil:
« Reply #6 on: November 13, 2009, 07:27:52 AM »
Haha... right up my street.. I loved the DE course I took in my first year  :-)
Haha cheeky  :-P  But nxn?  :wink:
Funny you should say that actually Alan - I do have an assignment for my C-programming module that asks to calculate the determinant of a 3x3 matrix... which is where I got the inspiration for this challenge...   :evil:
I wondered how many of you would be interested - I saw a similar thread on here about Matrix Mathematics, but it wasn't taken very far... I knew that Gile would rise to the challenge - I've seen his mathematical genius before...   :wink:
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #7 on: November 16, 2009, 08:15:53 AM »
I hope, I not strongly was late with the answer?
(defun det-g (l)
 ;; By ElpanovEvgeniy
  ((null l) 1)
  ((zerop (caar l)) 0)
  ((* (caar l)
      (det-g (mapcar '(lambda (a)
                       (mapcar '(lambda (b c) (- b (* c (/ (car a) (float (caar l))))))
                               (cdr a)
                               (cdar l)
                       ) ;_  mapcar
                      ) ;_  lambda
                     (cdr l)
             ) ;_  mapcar
      ) ;_  det
   ) ;_  *
 ) ;_  cond
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #8 on: November 16, 2009, 08:21:44 AM »
version 2:
(defun det-g (l)
 (cond ((null l) 1)
       ((* (caar l)
           (det-g (mapcar '(lambda (a / d)
                            (setq d (/ (car a) (float (caar l))))
                            (mapcar '(lambda (b c) (- b (* c d))) (cdr a) (cdar l))
                           ) ;_  lambda
                          (cdr l)
                  ) ;_  mapcar
           ) ;_  det
        ) ;_  *
 ) ;_  cond
) ;_  defun
VovKa
  • Ukraine
« Reply #9 on: November 16, 2009, 01:02:03 PM »
and that's why i love Evgeniy :)
« Reply #10 on: November 16, 2009, 01:34:56 PM »
Wow! Concise solution - nice one Evgeniy  :lol:
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #11 on: November 16, 2009, 01:43:28 PM »
If it is necessary concise:
(defun d(l)(if l(*(caar l)(d(mapcar'(lambda(a)(mapcar'(lambda(b c)(- b(* c(/(car a)1.(caar l)))))(cdr a)(cdar l)))(cdr l))))1))
« Reply #12 on: November 16, 2009, 01:47:08 PM »
Haha - now thats showing off  :-P  :evil:
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #13 on: November 16, 2009, 01:53:58 PM »
I am not assured, that I can really write more shortly. :(
qjchen
  • Best wishes to all
« Reply #14 on: January 25, 2011, 08:01:10 PM »
Wow, all of you are so excellent.
Last night I thought that we should challenge  determinant, a matrix and recursive problem. But after I searched, I was shocked by your codes, especially Evgeniy's.
My solution is tooooooo longer.
Thank you all~
http://qjchen.mjtd.com
