Author Topic: Dynamic Align Text to Curve { with Reactors }  (Read 58458 times)
Re: Dynamic Align Text to Curve { with Reactors }
« Reply #135 on: February 16, 2010, 05:49:07 PM »
I have updated the first post to Version 2.9.
This should hopefully resolve most (if not all) of the issues that we have discussed.
My sincere thanks go to all who have contributed along the way; - if any more bugs are found, let me know!  :-)
Thanks,
Lee
jitupnair
« Reply #136 on: May 09, 2010, 03:13:31 AM »
Lee,
Its really wonderful. Great program.
Jithesh. P. Nair
Thanks,
Lee
jitupnair
« Reply #137 on: May 09, 2010, 05:04:09 AM »
Lee,
While aligning one text to a line using this progam, I pressed P to make the text perpendicular but before fixing the possition of text,
I changed my mind and pressed P again to make the text parallel to the Line and fixed the possition. Till here it worked fine. But when I moved the line the text become perpendicular to the line. Is there any problem with program or I did something wrong?.
Thanks & regards
Jithesh P. Nair
Thanks,
Lee
« Reply #138 on: May 09, 2010, 07:59:55 AM »
I cannot seem to reproduce your error, does anyone else receive the same problem?
jitupnair
« Reply #139 on: May 13, 2010, 06:18:40 AM »
In my home PC its working well. But in office PC its giving the above said problem. I think Its a problem in my  AutoCAD or PC (in office).
« Reply #140 on: May 13, 2010, 10:59:15 AM »
I cannot work out why that would happen, but let me know if you find anything else, or indeed if anyone else is suffering with this bug  :-)
Willie
  • Going nowhere slowly
« Reply #141 on: May 17, 2010, 09:35:35 PM »
Just a suggestion for a future version.
How about a reset option to position the text back to the initial position?  Sometimes after you have used the "+" and "-" and the text position is not to your liking you can reset the position and start the "+" "-" etc. process again.
« Reply #142 on: May 18, 2010, 05:05:54 AM »
Maybe I've misunderstood the request, but you could press 'O' to specify an Offset manually.  :-)
Willie
« Reply #143 on: May 18, 2010, 05:09:20 AM »
That will work.
« Reply #144 on: May 18, 2010, 05:22:19 AM »
Excellent, let me know if you have any problems with it :-)
ljh19991220
« Reply #145 on: June 14, 2010, 01:01:40 AM »
thanks.  :-)  VERY GOOD
« Reply #146 on: June 14, 2010, 03:20:15 AM »
You're very welcome - glad you like it  :-)
fabcad
« Reply #147 on: September 06, 2010, 09:04:13 AM »
Hello Lee,
Very interresting function because i manipulate a lot of texts and mtexts on map.
For your texts functions, should be an option to type zero to align the text-mtext on the polyline reference after the use of + or +.
Because we write our texts roads on polylines roads.
Thanks for your best work,
Fabrice
« Reply #148 on: September 06, 2010, 02:40:34 PM »
Type 'O' during alignment.
fabcad
« Reply #149 on: September 06, 2010, 03:02:11 PM »
Sorry I had not seen the option Offset Thanks for your reply.
Fabrice
