Author Topic: lastpoint on rotate  (Read 4358 times)
Andrea
lastpoint on rotate
« on: November 11, 2009, 09:28:10 AM »
Hi all..
any one have an idea on how to get the last point when we make ROTATE ?   :|
Keep smile...
efernal
Re: lastpoint on rotate
« Reply #1 on: November 11, 2009, 10:11:33 AM »
did you try
(getvar "LASTPOINT")
ef
e.fernal
Andrea
« Reply #2 on: November 11, 2009, 10:20:48 AM »
did you try
ef
LASTPOINT return the rotation basepoint not the last one..
Keep smile...
efernal
« Reply #3 on: November 11, 2009, 11:25:49 AM »
if the rotation angle is get by clicking another point, this one will be the last...
ef
e.fernal
Andrea
« Reply #4 on: November 11, 2009, 12:09:13 PM »
ef
that what i've thougth...but
.....the LASTPOINT give me the basepoint of rotation
Keep smile...
« Reply #5 on: November 11, 2009, 02:15:46 PM »
Create your own Rotate command. :)
Andrea
« Reply #6 on: November 11, 2009, 04:29:14 PM »
Keep smile...
« Reply #7 on: November 11, 2009, 06:46:11 PM »
Try this, quick & dirty. 8-)
;;  CAB 11.11.09
;;  Simulate the rotate command
(defun Rotate (ss BasePoint / ip ObjList i ename ip grr
               ANG BPT LASTROT OBJANG ROT STARTANG)
  (defun GroupRotate (objects bpt ang)
    (setq bpt (vlax-3D-point bpt))
    (mapcar (function (lambda (x) (vla-rotate x bpt ang))) Objects)
  (setq ObjAng 0.0
        rot 0.0
  (setq StartAng ObjAng)      ; save angle before rotation begins
  (setq i -1)
  (while (setq ename (ssname ss (setq i (1+ i))))
    (setq ObjList (cons (vlax-ename->vla-object ename) ObjList))
  (while (progn
           (redraw)
             ((eq 3 (car (setq grr (grread T 15 0))))
              (setq ip (cadr grr))
              nil
             ((and (eq 2 (car grr)) (eq 13 (cadr grr)))
              (GroupRotate ObjList BasePoint (- StartAng LastRot))
              (setq ip nil)
             ((eq 5 (car grr)) ; point from mouse, update star
              (setq rot (angle BasePoint (trans (setq ip (cadr grr)) 1 0)))
                              ; pointer angle
              (GroupRotate ObjList BasePoint (- rot ObjAng))
              (setq ObjAng rot) ; update object current angle
              (and (>= ObjAng (* 2 pi)) (setq ObjAng (- ObjAng (* 2 pi))))
                              ; correct if >= 2pi
              (setq LastRot ObjAng)
              t
  ip
(defun c:MyRotate (/ ss bpt)
  (and
    (princ "\nSelect objects to rotate:")
    (setq ss (ssget))
    (setq bpt (getpoint "\nSpecify base point: "))
    (princ "\nSpecify rotation angle. ")
    (princ (rotate ss bpt))
alanjt
  • Standby for witty remark...
« Reply #8 on: November 11, 2009, 07:38:28 PM »
Very cool Alan. I knew it was possible, I just wasn't sure what math to apply. I'll have to do a little studying. :)
Added reference line:
;;  CAB 11.11.09
  (setq ObjAng 0.0
        rot 0.0
  (setq i -1)
  (while (progn
              nil
              (setq ip nil)
              (redraw)
              (grdraw BasePoint ip 7)
                              ; pointer angle
                              ; correct if >= 2pi
              t
  (redraw)
  ip
Dropbox
« Reply #9 on: November 11, 2009, 08:51:35 PM »
Excellent, thanks.  :-)
« Reply #10 on: November 12, 2009, 12:14:34 AM »
Catches locked layers:
;;  CAB 11.12.09
;;  ss may be a selection set or list of enames or vla objects
(defun Rotate (ss BasePoint / ip ObjList i ename ip grr rot layrs obj doc
              LastRot ObjAng)
  (defun LayUnLocked (Obj layrs)
   (= :vlax-false (vla-get-Lock (vla-Item  layrs (vla-get-Layer Obj))))
  (setq ObjAng 0.0
        rot    0.0
        doc    (vla-get-ActiveDocument (vlax-get-acad-object))
        Layrs  (vla-get-Layers doc)
  (vla-endundomark doc)
  (vla-startundomark doc)
    ((= (type ss) 'PICKSET)
      (setq i -1)
        (if (LayUnLocked (setq obj (vlax-ename->vla-object ename)) Layrs)
          (setq ObjList (cons obj ObjList))
    ((= (type (car ss)) 'ENAME)
     (mapcar (function (lambda(x)
        (if (LayUnLocked (setq obj (vlax-ename->vla-object x)) Layrs)
      ss)
    (t
        (if (LayUnLocked x Layrs)
          (setq ObjList (cons x ObjList))
      ss)
  (while (progn
              nil
              (GroupRotate ObjList BasePoint (- LastRot))
              (setq ip nil)
              (redraw)
              (grdraw BasePoint ip 7); pointer angle
              (and (>= ObjAng (* 2 pi)) (setq ObjAng (- ObjAng (* 2 pi)))) ; correct if >= 2pi
              t
  (redraw)
  ip
Andrea
« Reply #11 on: November 12, 2009, 06:44:20 PM »
nice Allan !  thanks..
I'll take your code as example.   :wink:
but ..
what about all Osnaps ? ortho ? input ?
I mean...why doing a new existing command only to take the last pickpoint ?
is there realy no way to get it ?
Keep smile...
« Reply #12 on: November 12, 2009, 07:35:49 PM »
Not that I know of.
This too is inaccurate if osnaps are used.
  (command "_rotate" pause)
  (while (>(getvar "CMDACTIVE")0) (command pause))
  (cadr (grread 1 1))
Andrea
« Reply #13 on: November 12, 2009, 09:27:51 PM »
aaahh.....
there it is...
(command "._rotate" (ssget) "")
(setq Lastpoint (osnap (cadr (grread 1 1)) "_end"))
Thanks Allan.. :roll:
It miss precision without Osnap..but near the goal.
Keep smile...
Serge J. Gianolla
« Reply #14 on: November 12, 2009, 09:29:15 PM »
but ..
Salut Andrea,
Is the @ helping you, like in
Command: PL
PLINE
Specify start point: @
