Author Topic: Delete an edge within hence split a polyline  (Read 2617 times)
SteveK
« on: November 10, 2009, 11:52:40 PM »
gday (hello),
My aim is to delete a line within a polyline (and therefore split a polyline). To do this I quickly wrote this code just making two lines and trim using these lines. You don't need to tell me there's better ways of doing this but I just wanted something fast with one select. Anyways, was wondering if anyone can (if you're bored) or has come up with something better.
; Split Polyline by trimming either side of a line (This is dodgy)
(defun c:trpl (/ MSPC PT LN1 LN2 VE1 VE2 VP1 VP2 TR)
  (setq mspc (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
tr (ssadd))
  (setq pt (cadr (entsel))
ve1 (car (nentselp pt))
ve2 (entnext ve1))
  (setq vp1 (cdr (assoc 10 (entget ve1)))
vp2 (cdr (assoc 10 (entget ve2))))
  (command "_UNDO" "BEGIN")
  (setq ln1 (vlax-vla-object->ename (vla-addline
     mspc
     (vlax-3d-point vp1)
     (vlax-3d-point (list
      (+ (car vp1) 1.)
      (+ (cadr vp1) 1.)
      (caddr vp1)
  (ssadd ln1 tr)
  (setq ln2 (vlax-vla-object->ename (vla-addline
     mspc
     (vlax-3d-point vp2)
      (+ (car vp2) 1.)
      (+ (cadr vp2) 1.)
      (caddr vp2)
  (ssadd ln2 tr)
  (command "_TRIM" tr "" pt "")
  (setq tr nil)
  (entdel ln1)
  (entdel ln2)
  (command "_UNDO" "END")
steve  :-)
alanjt
  • Standby for witty remark...
Re: Delete an edge within hence split a polyline
« Reply #1 on: November 11, 2009, 12:35:37 AM »
This should make you laugh:
(defun c:test (/ e)
  (and (setq e (entsel "\nSelect *Polyline: "))
       (command "_.trim" e "" e ""))
  (princ))
Dropbox
Serge J. Gianolla
« Reply #2 on: November 11, 2009, 01:53:14 AM »
And not using lisp.  :lol:
Select Pline as cutting edge, then select segment to remove!
DEVITG
« Reply #3 on: November 11, 2009, 04:42:18 AM »
(defun c:test (/ e)
  (princ))
Hi AlanJT , please explain how or why it can be used the e as
as ENTITY despite it also hold the point .
(<Entity name: 7da769b8> (84.6011 56.7525 0.0))
Normally it is used as
(setq ent  ( car e))
« Reply #4 on: November 11, 2009, 07:42:38 AM »
Several commands will use the list (ename point), look at Break.
DEVITG
« Reply #5 on: November 11, 2009, 08:04:52 AM »
Ok , thanks , new for me .
alanjt
« Reply #6 on: November 11, 2009, 08:20:52 AM »
or Lengthen
Dropbox
SteveK
« Reply #7 on: November 11, 2009, 04:09:52 PM »
(defun c:test (/ e)
  (princ))
  :-D hahaha. dearie me :oops:. Thanks Alan.
Sorry what command is that?
alanjt
« Reply #8 on: November 11, 2009, 04:12:47 PM »
(defun c:test (/ e)
  (princ))
He's referring to doing exactly what I did, except w/o code.
Command: tr TRIM
Current settings: Projection=UCS, Edge=None
Select cutting edges ...
Select objects or <select all>: 1 found
Select objects:
Select object to trim or shift-select to extend or
[Fence/Crossing/Project/Edge/eRase/Undo]:
Dropbox
SteveK
« Reply #9 on: November 11, 2009, 04:15:07 PM »
Command: tr TRIM
Select objects:
Ah Right :ugly:. Ta
alanjt
« Reply #10 on: November 11, 2009, 04:25:08 PM »
Actually, now that I think of it, Lee wrote this exact same program a month or so back.
Dropbox
