Author Topic: Ellipses to polylines  (Read 24719 times)
luiscarneirorm
Re: Ellipses to polylines
« Reply #15 on: October 18, 2011, 12:41:36 PM »
it's in the 11# post  8-)
P.S: even now, if I draw an ellipse, and then stretch it or shrink it, sometimes the start angle and end angle is no longer 0 and 360, and become for example 90 90, or 180 180, and then to use function gives me problems ...
You can work around this??
« Last Edit: October 18, 2011, 12:45:23 PM by luiscarneirorm »
gile
  • Marseille, France
« Reply #16 on: October 18, 2011, 01:11:29 PM »
Try this one
;; EllipseToPolyline
;; Returns a polyline (vla-object) which is an approximation of the ellipse (or elliptical arc)
;; Argument : an ellipse (vla-object)
(defun EllipseToPolyline (el /     cl    norm  cen elv   pt0   pt1   pt2 pt3   pt4   ac0
  ac4 a04   a02   a24   bsc0 bsc2  bsc3  bsc4  plst blst  spt   spa
  fspa srat  ept   epa   fepa erat  n
  (setq cl   (= (ang<2pi (vla-get-StartAngle el))
(ang<2pi (vla-get-EndAngle el)))
norm (vlax-get el 'Normal)
cen  (trans (vlax-get el 'Center) 0 norm)
elv  (caddr cen)
cen  (3dTo2dPt cen)
pt0  (mapcar '+ (trans (vlax-get el 'MajorAxis) 0 norm) cen)
ac0  (angle cen pt0)
pt4  (mapcar '+ cen (trans (vlax-get el 'MinorAxis) 0 norm))
pt2  (3dTo2dPt (trans (vlax-curve-getPointAtparam el (/ pi 4.)) 0 norm))
ac4  (angle cen pt4)
a04  (angle pt0 pt4)
a02  (angle pt0 pt2)
a24  (angle pt2 pt4)
bsc0 (/ (ang<2pi (- a02 ac4)) 2.)
bsc2 (/ (ang<2pi (- a04 a02)) 2.)
bsc3 (/ (ang<2pi (- a24 a04)) 2.)
bsc4 (/ (ang<2pi (- (+ ac0 pi) a24)) 2.)
pt1  (inters pt0
     (polar pt0 (+ ac0 (/ pi 2.) bsc0) 1.)
     pt2
     (polar pt2 (+ a02 bsc2) 1.)
     nil
pt3  (inters pt2
     (polar pt2 (+ a04 bsc3) 1.)
     pt4
     (polar pt4 (+ a24 bsc4) 1.)
     nil
plst (list pt4 pt3 pt2 pt1 pt0)
blst (mapcar '(lambda (b) (tan (/ b 2.)))
     (list bsc4 bsc3 bsc2 bsc0)
  (foreach b blst
    (setq blst (cons b blst))
  (foreach b blst
  (foreach p (cdr plst)
    (setq ang  (angle cen p)
  plst (cons
(polar cen (+ ang (* 2 (- ac4 ang))) (distance cen p))
plst
  plst (cons
(polar cen (+ ang (* 2 (- ac0 ang))) (distance cen p))
plst
  (setq pl
(vlax-invoke
   (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object)))
   'AddLightWeightPolyline
   (apply 'append
  (setq plst
(reverse (if cl
    (cdr plst)
    plst
  (vlax-put pl 'Normal norm)
  (vla-put-Elevation pl elv)
  (mapcar '(lambda (i v) (vla-SetBulge pl i v))
  '(0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16)
  blst
  (if cl
    (vla-put-Closed pl :vlax-true)
      (setq spt (vlax-curve-getClosestPointTo pl (vlax-get el 'Startpoint))
    spa (vlax-curve-getParamAtPoint pl spt)
    fspa (fix spa)
    ept (vlax-curve-getClosestPointTo pl (vlax-get el 'Endpoint))
    epa (vlax-curve-getParamAtPoint pl ept)
    fepa (fix epa)
    n 0
((equal spt (trans pt0 norm 0) 1e-9)
(if (= epa fepa)
   (setq plst (sublist plst 0 (1+ fepa))
blst (sublist blst 0 (1+ fepa))
   (setq erat (/ (- (vlax-curve-getDistAtParam pl epa)
    (vlax-curve-getDistAtParam pl fepa)
(- (vlax-curve-getDistAtParam pl (rem (1+ fepa) 17))
plst (append (sublist plst 0 (1+ fepa))
      (list (3dTo2dPt (trans ept 0 norm)))
blst (append (sublist blst 0 (1+ fepa))
      (list (k*bulge (nth fepa blst) erat))
((equal ept (trans pt0 norm 0) 1e-9)
(if (= spa fspa)
   (setq plst (sublist plst fspa nil)
blst (sublist blst fspa nil)
   (setq srat (/ (- (vlax-curve-getDistAtParam pl (rem (1+ fspa) 17))
    (vlax-curve-getDistAtParam pl spa)
    (vlax-curve-getDistAtParam pl fspa)
plst (cons (3dTo2dPt (trans spt 0 norm))
    (sublist plst (1+ fspa) nil)
blst (cons (k*bulge (nth fspa blst) srat)
    (sublist blst (1+ fspa) nil)
(T
(if (< epa spa)
   (setq plst (append
(if (= spa fspa)
(cdr (sublist plst 0 (1+ fepa)))
(if (/= epa fepa)
blst (append
(if (= spa fspa)
  (cons
(sublist blst 0 fepa)
(if (= epa fepa)
  (list (nth fepa blst))
   (setq plst (append
(if (= spa fspa)
  (sublist plst fspa (1+ (- fepa fspa)))
(sublist plst (1+ fspa) (- fepa fspa))
blst (append
(if (= spa fspa)
  (sublist blst fspa (- fepa fspa))
  (cons
    (sublist blst (1+ fspa) (- fepa fspa))
(if (= epa fepa)
      (vlax-put pl 'Coordinates (apply 'append plst))
      (foreach b blst
(vla-SetBulge pl n b)
(setq n (1+ n))
  pl
;; Ang<2pi
;; Returns the angle expression betweem 0 and 2*pi
(defun ang<2pi (ang)
  (if (and (<= 0 ang) (< ang (* 2 pi)))
    ang
    (ang<2pi (rem (+ ang (* 2 pi)) (* 2 pi)))
;; 3dTo2dPt
;; Returns the 2d point (x y) of a 3d point (x y z)
(defun 3dTo2dPt (pt) (list (car pt) (cadr pt)))
;; Tan
;; Returns the angle tangent
(defun tan (a) (/ (sin a) (cos a)))
;; SUBLIST
;; Returns a sub list
;; Arguments
;; lst : a list
;; start : start index (first item = 0)
;; leng : the sub list length (number of items) or nil
(defun sublist (lst start leng / n r)
  (if (or (not leng) (< (- (length lst) start) leng))
    (setq leng (- (length lst) start))
  (setq n (+ start leng))
  (while (< start n)
    (setq r (cons (nth (setq n (1- n)) lst) r))
;; K*BULGE
;; Returns the proportinal bulge to the référence bulge
;; Arguments :
;; b : the bulge
;; k : the proportion ratio (between angles or arcs length)
(defun k*bulge (b k / a)
  (setq a (atan b))
  (/ (sin (* k a)) (cos (* k a)))
kraz
« Reply #17 on: October 19, 2011, 12:28:21 AM »
very nice prog.
and here my easy way...but not better than gile.
spline or elipse -> polyline
(defun KZ:GetSPlineVertex (spl n / obj len vd p sum)
 (if (> n 1)
   (if (= (type spl) 'ename)
    (setq obj (vlax-ename->vla-object spl))
    (setq obj spl)
   ;(setq len (ade_expreval (vlax-vla-object->ename obj) ".length" "real"))
   (setq len (vlax-curve-getDistAtParam obj (vlax-curve-getEndParam obj)))
   (setq vd (/ len n) sum 0 plist '())
   (repeat (1+ n)
    (setq p (vlax-curve-getPointAtDist obj sum))
    (setq p (list (car p)(cadr p)))
    (if (not (member p plist)) (setq plist (append plist (list p))))
    (setq sum (+ sum vd))
   );rep
   plist
  nil
(defun c:test( / es cls vtxs n obj pl)
 (vl-cmdf ".undo" "begin")
 (if (setq es (car (entsel "\nSelect Entity... ")))
   (setq n (getint "\nHow many vertex[Default:15]... "))
   (if (or (null n) (< n 2)) (setq n 15))
   (setq obj (vlax-ename->vla-object es))
   (if (and (vlax-property-available-p obj 'closed)
            (= (vlax-get-property (vlax-ename->vla-object es) 'closed) :vlax-true)
    (setq cls 1)
    (setq cls 0)
   );if
   (setq vtxs (KZ:GetSPlineVertex es (1- n)));make n vertexs
   (setq pl (make_pline vtxs (getvar "clayer") 62 cls))
   (entdel es)
 );if
 (vl-cmdf ".undo" "end")
);end defun
« Last Edit: November 18, 2011, 05:59:25 PM by CAB »
luiscarneirorm
« Reply #18 on: October 19, 2011, 03:53:16 AM »
Try this one
elv  (caddr cen)
cen  (3dTo2dPt cen)
ac0  (angle cen pt0)
ac4  (angle cen pt4)
a04  (angle pt0 pt4)
a02  (angle pt0 pt2)
a24  (angle pt2 pt4)
pt1  (inters pt0
     pt2
     nil
pt3  (inters pt2
     pt4
     nil
  (foreach b blst
  (foreach b blst
  plst (cons
plst
  plst (cons
plst
  (setq pl
(vlax-invoke
   (apply 'append
  (setq plst
(reverse (if cl
    (cdr plst)
    plst
  blst
  (if cl
    fspa (fix spa)
    fepa (fix epa)
    n 0
(if (= epa fepa)
(if (= spa fspa)
(T
(if (< epa spa)
   (setq plst (append
(if (= spa fspa)
(if (/= epa fepa)
blst (append
(if (= spa fspa)
  (cons
(if (= epa fepa)
   (setq plst (append
(if (= spa fspa)
blst (append
(if (= spa fspa)
  (cons
(if (= epa fepa)
      (foreach b blst
(setq n (1+ n))
  pl
;; Ang<2pi
    ang
;; 3dTo2dPt
;; Tan
;; SUBLIST
;; Arguments
;; lst : a list
  (while (< start n)
;; K*BULGE
;; Arguments :
;; b : the bulge
  (setq a (atan b))
Tk you very much... I've been doing some testing and so far it is working properly ... I will try to adapt it to my script to handle all the drawing ellipses automatically ...
Andrea
« Reply #19 on: November 18, 2011, 10:48:35 AM »
Hi Gile,
Thank you for sharing the code,....
I've made a little modification...(if you don't mind)
(if (eq (getvar 'tilemode) 1)
             (setq vlaLayout (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object))))
             (setq vlaLayout (vla-get-PaperSpace (vla-get-ActiveDocument (vlax-get-acad-object))))
  (setq pl
(vlax-invoke
   vlaLayout
   (apply 'append
  (setq plst
(reverse (if cl
    (cdr plst)
    plst
I tough this was forget..
 :wink:
Keep smile...
gile
  • Marseille, France
« Reply #20 on: November 18, 2011, 11:09:27 AM »
Thanks for correcting this Andrea.
By my side, I prefer use the object owner in case the object have been selected in an active paper space viewport (i.e. TILEMODE = 1 and CVPORT /= 1)
(setq vlaLayout (vla-ObjectIdToObject *acdoc* (vla-get-OwnerId obj)))
Andrea
« Reply #21 on: November 18, 2011, 11:44:18 AM »
I'm not as skilled..   :blank:
thanks !
Keep smile...
« Reply #22 on: November 18, 2011, 11:48:08 AM »
Somewhat tangential, but on the topic of ObjectIDToObject .... this is what I have in my library:
(defun _Is64Bit ( )
    (setq *Is64Bit* (wcmatch (getvar "platform") "*64*"))
    (defun _Is64Bit ( ) *Is64Bit*)
    *Is64Bit*
(defun _ObjectIDToObject ( document objectid / object )
    (if (zerop objectid)
        document
            (vl-catch-all-apply
                (function
                    (lambda ( )
                        (setq object
                            (vlax-invoke
                                document
                                (if (_Is64Bit) 'objectidtoobject32 'objectidtoobject)
                                objectid
            object
fwiw ...
« Last Edit: November 18, 2011, 12:08:02 PM by MP »
Andrea
« Reply #23 on: November 18, 2011, 12:09:29 PM »
Thank you for the info..
But i'm not sure to understand the difference between both..
vla-objectidtoobject seem to work great in 64 and 32 bits.. case.
(vla-objectidtoobject
   (vla-get-activedocument
   (vla-get-ownerid
       (car (entsel))
Thanks.
Keep smile...
« Reply #24 on: November 18, 2011, 12:11:26 PM »
I mentioned it because vla-objectidtoobject was crashing for me under Windows 7 and AutoCAD 2012.
Andrea
« Reply #25 on: November 18, 2011, 12:43:07 PM »
Hummm...i've tested on 2011 and 2012 win7 64 bits..
But thanks for the info.
Keep smile...
alanjt
  • Standby for witty remark...
« Reply #26 on: November 18, 2011, 05:44:47 PM »
(defun _Is64Bit ( )
    *Is64Bit*
just wow
Dropbox
« Reply #27 on: November 18, 2011, 08:03:58 PM »
« Reply #28 on: November 18, 2011, 08:08:23 PM »
Probably more awe at the succinctness.
alanjt
« Reply #29 on: November 18, 2011, 08:32:57 PM »
Dropbox
