Author Topic: Ellipses to polylines  (Read 24489 times)
Re: Ellipses to polylines
« Reply #30 on: November 18, 2011, 08:36:14 PM »
not at all
your code never ceases to amaze.
Sorry for my misinterpretation. Thank you but I can't take credit for the defun redef technique, I believe Jon Fleming or Tony Tanzillo first did it, probably 437 years ago.
« Reply #31 on: November 18, 2011, 08:38:33 PM »
< ... > probably 437 years ago.
I remember that day, it was a Tuesday.
alanjt
  • Standby for witty remark...
« Reply #32 on: November 18, 2011, 09:14:17 PM »
not at all
:) Well, it's impressive and I thank you regardless.
I borrowed this idea from gile a few years back (slightly modified from his original version that set commands for each view):
(foreach radius '(0 1 2 3 4 5 6 7 8 9)
  ;; Fillet with radius (0-9)
  (eval (list 'defun
              (if (zerop radius)
                'c:FF
                (read (strcat "c:F" (itoa radius)))
              nil
              (list 'setvar "filletrad" radius)
              (list 'princ (strcat "\nFillet radius set to: " (rtos radius)))
              (list 'command "_.fillet")
              '(princ)
Dropbox
« Reply #33 on: November 18, 2011, 09:30:29 PM »
I borrowed this idea from gile a few years back ...
You're welcome. Gile's stuff is always top shelf. Many variants of that technique abound, here's another from awhile back ...
(eval
    (cons 'defun
        (list 'GetAlignment '( value )
            (cons 'cdr
                (list
                    (list 'assoc 'value
                        (list 'quote lst)
alanjt
« Reply #34 on: November 18, 2011, 09:39:05 PM »
HaHa, I remember that thread. Learned quite a bit that day. :)
Dropbox
« Reply #35 on: November 18, 2011, 09:59:38 PM »
some threads are really fun to start :)
« Reply #36 on: November 19, 2011, 07:46:04 AM »
gile
  • Marseille, France
« Reply #37 on: November 19, 2011, 02:39:06 PM »
About ObjectId and 64 bits platforms, from what I read somewhere (I don't remember where) the ObjectId32, OwnerId32 and ObjectIdToObject32 properties and method are only requiered for VBA on 64 bits platforms. By my side I never noticed problems using the 'old' unsuffixed ones with LISP on acad 2010, 2011 and 2012 64 bits (but I do not use as LISP routines as I did).
Another thing, using the "platform" sysvar evaluates the Windows platform version, not the AutoCAD version. On a windows 7 64 bits, I have an AutoCAD 2007 32 bits installed and (getvar 'platform) returns "Microsoft Windows NT Version 6.1 (x64)".
To evaluate the AutoCAD paltform version I'd rather evaluate if ObjectId32 is available :
(defun gc:IsAcad64   ()
  (vlax-property-available-p
    (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object)))
    'ObjectId32
« Reply #38 on: November 19, 2011, 03:01:57 PM »
Great info. Maybe my system needed it because I installed vba on on it. Have to do some investigating. Nonetheless, your info is appreciated, especially the heads up about using the platform sysvar, thank you very much Giles.
And Lee: I never saw your GrText suite before, awesome work.
« Reply #39 on: November 20, 2011, 07:29:51 AM »
Cheers Michael  :-)
VVA
« Reply #40 on: November 22, 2011, 12:58:42 AM »
Another version
;;; http://forum.dwg.ru/showthread.php?t=31568
(defun Acad64Bit-version ()
  (> (strlen (vl-prin1-to-string (vlax-get-acad-object))) 40)
