Author Topic: Ellipses to polylines  (Read 24491 times)
gile
  • Marseille, France
« on: November 08, 2009, 04:06:31 PM »
I think I found the way AutoCAD approximates ellipses using polylines (arcs) while PELLIPSE is set to 1.
Here's an EllipseToPolyline routine which creates a polyline which matches the ellipse (the routine doesn't delete the ellipse).
It works with elliptical arcs.
It works whatever the ellipse construction plane.
;; EllipseToPolyline
;; Returns a polyline (vla-object) which is an approximation of the ellipse (or elliptical arc)
;; Argument : an ellipse (vla-object)
(defun EllipseToPolyline (el /     cl    norm  cen elv   pt0   pt1   pt2 pt3   pt4   ac0
  ac4 a04   a02   a24   bsc0 bsc2  bsc3  bsc4  plst blst  spt   spa
  fspa srat  ept   epa   fepa erat  n
  (setq cl   (= (ang<2pi (vla-get-StartAngle el))
(ang<2pi (vla-get-EndAngle el)))
norm (vlax-get el 'Normal)
cen  (trans (vlax-get el 'Center) 0 norm)
elv  (caddr cen)
cen  (3dTo2dPt cen)
pt0  (mapcar '+ (trans (vlax-get el 'MajorAxis) 0 norm) cen)
ac0  (angle cen pt0)
pt4  (mapcar '+ cen (trans (vlax-get el 'MinorAxis) 0 norm))
pt2  (3dTo2dPt (trans (vlax-curve-getPointAtparam el (/ pi 4.)) 0 norm))
ac4  (angle cen pt4)
a04  (angle pt0 pt4)
a02  (angle pt0 pt2)
a24  (angle pt2 pt4)
bsc0 (/ (ang<2pi (- a02 ac4)) 2.)
bsc2 (/ (ang<2pi (- a04 a02)) 2.)
bsc3 (/ (ang<2pi (- a24 a04)) 2.)
bsc4 (/ (ang<2pi (- (+ ac0 pi) a24)) 2.)
pt1  (inters pt0
     (polar pt0 (+ ac0 (/ pi 2.) bsc0) 1.)
     pt2
     (polar pt2 (+ a02 bsc2) 1.)
     nil
pt3  (inters pt2
     (polar pt2 (+ a04 bsc3) 1.)
     pt4
     (polar pt4 (+ a24 bsc4) 1.)
     nil
plst (list pt4 pt3 pt2 pt1 pt0)
blst (mapcar '(lambda (b) (tan (/ b 2.)))
     (list bsc4 bsc3 bsc2 bsc0)
  (foreach b blst
    (setq blst (cons b blst))
  (foreach b blst
  (foreach p (cdr plst)
    (setq ang  (angle cen p)
  plst (cons
(polar cen (+ ang (* 2 (- ac4 ang))) (distance cen p))
plst
  plst (cons
(polar cen (+ ang (* 2 (- ac0 ang))) (distance cen p))
plst
  (setq pl
(vlax-invoke
   (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object)))
   'AddLightWeightPolyline
   (apply 'append
  (setq plst
(reverse (if cl
    (cdr plst)
    plst
  (vlax-put pl 'Normal norm)
  (vla-put-Elevation pl elv)
  (mapcar '(lambda (i v) (vla-SetBulge pl i v))
  '(0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16)
  blst
  (if cl
    (vla-put-Closed pl :vlax-true)
      (setq spt (vlax-curve-getClosestPointTo pl (vlax-get el 'Startpoint))
    spa (vlax-curve-getParamAtPoint pl spt)
    fspa (fix spa)
    ept (vlax-curve-getClosestPointTo pl (vlax-get el 'Endpoint))
    epa (vlax-curve-getParamAtPoint pl ept)
    fepa (fix epa)
    n 0
((equal spt (trans pt0 norm 0) 1e-9)
(if (= epa fepa)
   (setq plst (sublist plst 0 (1+ fepa))
blst (sublist blst 0 (1+ fepa))
   (setq erat (/ (- (vlax-curve-getDistAtParam pl epa)
    (vlax-curve-getDistAtParam pl fepa)
(- (vlax-curve-getDistAtParam pl (rem (1+ fepa) 17))
plst (append (sublist plst 0 (1+ fepa))
      (list (3dTo2dPt (trans ept 0 norm)))
blst (append (sublist blst 0 (1+ fepa))
      (list (k*bulge (nth fepa blst) erat))
((equal ept (trans pt0 norm 0) 1e-9)
(if (= spa fspa)
   (setq plst (sublist plst fspa nil)
blst (sublist blst fspa nil)
   (setq srat (/ (- (vlax-curve-getDistAtParam pl (rem (1+ fspa) 17))
    (vlax-curve-getDistAtParam pl spa)
    (vlax-curve-getDistAtParam pl fspa)
plst (cons (3dTo2dPt (trans spt 0 norm))
    (sublist plst (1+ fspa) nil)
blst (cons (k*bulge (nth fspa blst) srat)
    (sublist blst (1+ fspa) nil)
(T
(if (< epa spa)
   (setq plst (append
(if (= spa fspa)
(cdr (sublist plst 0 (1+ fepa)))
(if (/= epa fepa)
blst (append
(if (= spa fspa)
  (cons
(sublist blst 0 fepa)
(if (= epa fepa)
  (list (nth fepa blst))
   (setq plst (append
(if (= spa fspa)
  (sublist plst fspa (1+ (- fepa fspa)))
(sublist plst (1+ fspa) (- fepa fspa))
blst (append
(if (= spa fspa)
  (sublist blst fspa (- fepa fspa))
  (cons
    (sublist blst (1+ fspa) (- fepa fspa))
(if (= epa fepa)
      (vlax-put pl 'Coordinates (apply 'append plst))
      (foreach b blst
(vla-SetBulge pl n b)
(setq n (1+ n))
  pl
;; Ang<2pi
;; Returns the angle expression betweem 0 and 2*pi
(defun ang<2pi (ang)
  (if (and (<= 0 ang) (< ang (* 2 pi)))
    ang
    (ang<2pi (rem (+ ang (* 2 pi)) (* 2 pi)))
;; 3dTo2dPt
;; Returns the 2d point (x y) of a 3d point (x y z)
(defun 3dTo2dPt (pt) (list (car pt) (cadr pt)))
;; Tan
;; Returns the angle tangent
(defun tan (a) (/ (sin a) (cos a)))
;; SUBLIST
;; Returns a sub list
;; Arguments
;; lst : a list
;; start : start index (first item = 0)
;; leng : the sub list length (number of items) or nil
(defun sublist (lst start leng / n r)
  (if (or (not leng) (< (- (length lst) start) leng))
    (setq leng (- (length lst) start))
  (setq n (+ start leng))
  (while (< start n)
    (setq r (cons (nth (setq n (1- n)) lst) r))
;; K*BULGE
;; Returns the proportinal bulge to the référence bulge
;; Arguments :
;; b : the bulge
;; k : the proportion ratio (between angles or arcs length)
(defun k*bulge (b k / a)
  (setq a (atan b))
  (/ (sin (* k a)) (cos (* k a)))
And two commands:
EL2PL to transform selected ellipses into polylines
PELL to draw an 'elliptical polyline' on the fly
;; EL2PL
;; Converts ellipses and elliptcal arcs into polylines
(defun c:el2pl (/ *error* fra acdoc ss)
  (defun *error* (msg)
    (if (and (/= msg "Fonction annulée")
             (/= msg "Function cancelled")
      (princ (strcat (if (= "FRA" (getvar 'locale))
                       "\nErreur: "
                       "\Error: "
                     msg
    (vla-endUndoMark acdoc)
  (setq acdoc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (if (ssget '((0 . "ELLIPSE")))
      (vla-StartUndoMark acdoc)
      (vlax-for e (setq ss (vla-get-ActiveSelectionSet acdoc))
        (EllipseToPolyline e)
        (vla-delete e)
      (vla-delete ss)
      (vla-EndUndoMark acdoc)
;; PELL
;; Draws an ellipse or an elliptical arc approximation (polyline) on the fly
(defun c:pell (/ *error* ec pe old ent)
    (if (and msg
                       "\nErreur: "
                       "\Error: "
                     msg
    (setvar 'cmdecho ec)
    (setvar 'pellipse pe)
  (setq ec  (getvar 'cmdecho)
        pe  (getvar 'pellipse)
        old (entlast)
  (setvar 'cmdecho 1)
  (setvar 'pellipse 0)
  (command "_.ellipse")
  (while (/= 0 (getvar 'cmdactive))
    (command pause)
  (if (not (eq old (setq ent (entlast))))
    (EllipseToPolyline (vlax-ename->vla-object ent))
    (entdel ent)
  (*error* nil)
« Last Edit: October 18, 2011, 01:15:27 PM by gile »
cjw
Re: Ellipses to polylines
« Reply #1 on: November 09, 2009, 04:33:45 AM »
Very nice code,gile. 8-)
Here is easy way.
;;Ellipses to polylines By cjw 11/9/09
(defun C:EL2PL (/ E E1 E2 O)
  (setq E (car (entsel "\nSelect the ellipse: ")))
  (setq O (vlax-ename->vla-object E))
  (vla-offset O 0.1)
  (setq E1 (entlast))
  (vla-offset (vlax-ename->vla-object E1) -0.1)
  (setq E2 (entlast))
  (entdel E)
  (entdel E1)
gile
  • Marseille, France
« Reply #2 on: November 09, 2009, 06:19:42 AM »
Thanks cjw
AFAIK (but my knowledge isn't so great), offsting an ellipse creates a spline, not a polyline.
Hedgehog
« Reply #3 on: November 09, 2009, 06:46:20 AM »
Double click the spline & convert to a polyline... or add a line of code to do that  :-)
gile
  • Marseille, France
« Reply #4 on: November 09, 2009, 07:15:14 AM »
Not prior A2010 :-(
Hedgehog
« Reply #5 on: November 09, 2009, 07:23:27 AM »
... oops  :-(
gile
  • Marseille, France
« Reply #6 on: November 09, 2009, 04:30:23 PM »
I tried the offset, offset back an splinedit method on a 2010 version.
Even specifying the lowest precision (1) I got a 257 vertices polyline.
cjw
« Reply #7 on: November 09, 2009, 07:36:37 PM »
Thanks cjw
I am sorry! :-(
Thanks.
luiscarneirorm
« Reply #8 on: October 18, 2011, 09:31:11 AM »
                          pt3   pt4   ac0   ac4   a04   a02   a24   bsc0  bsc2
                          bsc3  bsc4  plst  blst  spt   spa   fspa  srat  ept
                          epa   fepa  erat  n
  (setq cl   (and (= (vla-get-StartAngle el) 0.0)
                  (= (vla-get-EndAngle el) (* 2 pi))
        elv  (caddr cen)
        cen  (3dTo2dPt cen)
        ac0  (angle cen pt0)
        ac4  (angle cen pt4)
        a04  (angle pt0 pt4)
        a02  (angle pt0 pt2)
        a24  (angle pt2 pt4)
        pt1  (inters pt0
                     pt2
                     nil
        pt3  (inters pt2
                     pt4
                     nil
  (foreach b blst
  (foreach b blst
          plst (cons
                 plst
          plst (cons
                 plst
  (setq pl
         (vlax-invoke
           (apply 'append
                  (setq plst
                         (reverse (if cl
                                    (cdr plst)
                                    plst
          blst
  (if cl
            fspa (fix spa)
            fepa (fix epa)
            n    0
         (if (= epa fepa)
                    (- (vlax-curve-getDistAtParam pl (1+ fepa))
         (if (= spa fspa)
           (setq srat (/ (- (vlax-curve-getDistAtParam pl (1+ fspa))
        (T
         (if (< epa spa)
           (setq plst (append
                        (if (= spa fspa)
                        (if (/= epa fepa)
                 blst (append
                        (if (= spa fspa)
                          (cons
                        (if (= epa fepa)
           (setq plst (append
                        (if (= spa fspa)
                 blst (append
                        (if (= spa fspa)
                          (cons
                        (if (= epa fepa)
      (foreach b blst
        (setq n (1+ n))
  pl
;; Ang<2pi
;; Returns the angle expression beweem 0 and 2*pi
    ang
;; 3dTo2dPt
;; Tan
;; SUBLIST
;; Arguments
;; lst : a list
  (while (< start n)
;; K*BULGE
;; Arguments :
;; b : the bulge
  (setq a (atan b))
And two commands:
;; EL2PL
                       "\nErreur: "
                       "\Error: "
                     msg
        (vla-delete e)
      (vla-delete ss)
;; PELL
    (if (and msg
                       "\nErreur: "
                       "\Error: "
                     msg
        old (entlast)
  (setvar 'cmdecho 1)
    (command pause)
    (entdel ent)
  (*error* nil)
Hi. Sorry for digging up the topic, but needed help with this routine, I am using this routine to convert arcs of ellipse to polylines, but I'm having problems with the arcs of ellipse that have start angle 0 and end angle 180  :x.
the curious thing is that if I change these values ​​to others, and then replacing the original values ​​and execute the routine she now works correctly.
luiscarneirorm
« Reply #9 on: October 18, 2011, 10:00:48 AM »
I think I've detected the problem, I went to see the code dxf arc that was giving me problems and found the following:
(40 . 0.240816) (41 . -1.87175e-007) (42 . 3.14176))
the value in bold corresponds to the start angle and should be 0. it's possible to contour that problem???
gile
  • Marseille, France
« Reply #10 on: October 18, 2011, 11:57:56 AM »
I do not understand your request.
Can you explain more deeply why do you think the routine doesn't work as expected.
You're talking about the ellipse start angle which does not seem to be as you want.
The routine does not deals with the elliptical arc angles, only with start point and end point.
luiscarneirorm
« Reply #11 on: October 18, 2011, 12:14:08 PM »
Humm???
I put here the case that is giving me problems, it may be easier for you to understand, because my English is very bad.
If you see the proprieties of the arc, the start angle it's 0, and the end angle its 180, so the dxf code should be:
(41 . 0.0) (42 . 3.14176))
and it is
I'm newbie in lisp, but I think the problem is there.
« Last Edit: October 18, 2011, 12:19:25 PM by luiscarneirorm »
gile
  • Marseille, France
« Reply #12 on: October 18, 2011, 12:30:40 PM »
This expression is only used to evaluate if the ellipse is closed.
While dealing with elliptical arcs (i.e. non closed ellipses) the code only used the ellipse start point and end point to 'break' the polyline.
The example you give shows that the elliptical arc is not exactly starting with a 0.0 angle. It looks like it is your elliptical arc which isn't very accurate, not the LISP...
luiscarneirorm
« Reply #13 on: October 18, 2011, 12:36:39 PM »
hum, ok...
You try tu use the function in this arc? she work's ok for you???
gile
  • Marseille, France
« Reply #14 on: October 18, 2011, 12:39:37 PM »
hum, ok...
What arc are you talking about ?
Post a drawing example, please.
