Author Topic: Inventor 2010 Default Field Text Add-in  (Read 1904 times)
vegbruiser
« on: October 26, 2009, 12:17:27 PM »
Hi folks,
I am using Inventor 2010, VB.NET Express 2008, and Windows XP Pro (x86)
My problem is this: -
We create Inventor drawings (.idw) that we output to AutoCAD 2000 (.dwg) format.
I was hoping to be able to set up "default" entries for a lot of the Inventor-based attributes, and since we can't use Inventor fields* I was hoping to get some suggestions about a way forward.
Specifically:
  • what's the best storage format for the list of default values?
  • the best way of displaying these default values to the user?
  • is it worth having an "Admin" function capable of adding/editing default values built-into the resultant tool? (Would likely mean user authentication I think?)
Thanks in advance.
*Because exporting the .idw files to .dwg format loses any custom fields you setup in the .idw file (or at least it did in IV2009) - amongst other issues.
PS. thus far I can get my code to capture the "right-click" context menu that would normally contain the "Edit Field Text.." command.
