Author Topic: Appload in acad 2000  (Read 4061 times)
vinnyg
« on: October 25, 2009, 07:48:29 AM »
Hi all,
I just recently installed acad 2000. When I go to tools to load applications, nothing happens...it won't
load. I have worked with r14 and had no problems.  Any advice?
thanks
vinnyg
Re: Appload in acad 2000
« Reply #1 on: October 25, 2009, 10:14:39 PM »
do you mean the appload dialog doesn't show .. or the selected file from appload won't load. ??
« Reply #2 on: October 26, 2009, 07:32:52 AM »
Issue
When you entered APPLOAD on the command line or clicked Tools menu > Load Application, the following error message was displayed:
Unknown Command
Solution
This error may occur if the program is not set to automatically load the ARX files it needs.
To change this setting
1.Click Tools menu > Options
2.Click the Open and Save tab.
3.Under ObjectARX Applications, change the setting Demand load ObjectARX Apps to Object Detect and Command Invoke.
4.Click Apply and then OK.
vinnyg
« Reply #3 on: October 26, 2009, 03:05:56 PM »
Kerry,
The appload dialog box dosen't load
thanks
vinnyg
« Reply #4 on: October 26, 2009, 03:12:41 PM »
mjFarrell,
I looked at that setting and it was already set as you suggested.....thanks for your help
vinnyg
Matt__W
  • I like my water diluted.
« Reply #5 on: October 26, 2009, 03:14:16 PM »
FILEDIA = 1?
Autodesk Expert Elite
David Hall
  • Automatic Duh Generator
« Reply #6 on: October 26, 2009, 03:35:05 PM »
cmddia=1?
« Reply #7 on: October 26, 2009, 05:58:29 PM »
perhaps it is or has been located off screen...close autocad,
change screen resolution,
reopen acad....appload....find the box...
Matt__W
« Reply #8 on: October 27, 2009, 08:10:32 AM »
Or ALT + Spacebar and see if the Restore/Move/Size/Minimize/Maximize/Close dialog pops up somewhere.
