Author Topic: ADDING a function to VLISP libary  (Read 10400 times)
ArgV
« on: October 24, 2009, 02:56:28 AM »
I think there is a way to do this, but I can't remember. I want to take some of the commands I've made and add them to VLISP standard library (even so they turn blue when typed).
I've been making several small functions that I would like to use, even if I have to import them, but want to use them in compilations.
thanks!
-ArgV
Re: ADDING a function to VLISP libary
« Reply #1 on: October 24, 2009, 03:26:52 AM »
Have a play with something like this ..
(setq *temp-symbols* '(fun_1 fun_2 fun_3 fun_4 fun_5))
(eval
  (list 'pragma (list 'quote (list (cons 'unprotect-assign *temp-symbols*))))
;; add the defuns here < snip >
(defun fun_1 () (princ "fun 1") (princ))
(defun fun_2 (p1 p2) (princ "fun 2") (princ))
(defun fun_3 (a b) (princ "fun 3") (princ))
(defun fun_4 () (princ "fun 4") (princ))
(eval (list 'pragma (list 'quote (list (cons 'protect-assign *temp-symbols*)))))
(setq *temp-symbols* nil)
alanjt
  • Standby for witty remark...
« Reply #2 on: October 24, 2009, 04:25:06 PM »
(eval
Incredible, I had no idea you could do something like this. Are there any adverse effects?
Dropbox
ArgV
« Reply #3 on: October 24, 2009, 04:56:25 PM »
(eval
Sweet, that is a good step in the right direction. Now, of course, to take it a step further, is it possible to include my functions with the (vl-load-com) statement, or can I make my own version of the (vl-load-com) statement to use to import my functions?
Thank you very much. I learned all kinds of stuff looking up these new subrs, but most of it talks about objectARX, which I haven't started using quite yet.
-ArgV
« Reply #4 on: October 24, 2009, 05:01:31 PM »
No adverse effects.
« Reply #5 on: October 24, 2009, 05:05:10 PM »
-ArgV
Sorry, don't understand your intent.
This is just basic VisualLisp, nothing to do with ObjectARX.
alanjt
« Reply #6 on: October 24, 2009, 10:35:16 PM »
Is this kind of what you had in mine ArgV?
(defun AT-Load-Com (/ #Dir #List)
    ((setq #Dir (findfile "c:\\AlanThompson\\LSP\\_Subs"))
     (foreach x (vl-directory-files #Dir)
       (if (wcmatch (strcase x) "*.LSP")
         (load (strcat #Dir "\\" x) nil)
       ) ;_ if
     ) ;_ foreach
     (setq #List (mapcar 'read
                         (vl-remove-if-not
                           '(lambda (x) (wcmatch (strcase x) "AT*"))
                           (atoms-family 1)
                         ) ;_ vl-remove-if-not
                 ) ;_ mapcar
     ) ;_ setq
     (eval (list 'pragma (list 'quote (list (cons 'unprotect-assign #List)))))
     (eval (list 'pragma (list 'quote (list (cons 'protect-assign #List)))))
     T
  ) ;_ cond
) ;_ defun
This is what I was thinking for myself. Load all my subroutines in my _Subs folder, then create a list, based on what matches "AT*" from (atoms-family 1) and add them accordingly.
Is there a way to check if a function is already assigned? If i run this a second time (not that I would need to) and vlide is open, I have to OK through redefining each.
Dropbox
« Reply #7 on: October 25, 2009, 12:04:22 AM »
Alan,
The process required is to
unprotect-assign the symbol name,
define the function or variable (symbol name),
protect-assign the symbol name.
so your best methodology may be to add the pragma to the head and tail of each function definition or each file.
something like this
(pragma '((unprotect-assign HelloWorld)))
(defun HelloWorld () (alert "Hello World!"))
(pragma '((protect-assign HelloWorld)))
(pragma '((unprotect-assign kg:270 kg:180 kg:90 kg:45)))
(setq kg:270 (* pi 1.5))
(setq kg:180 (* pi 1.0))
(setq kg:90  (* pi 0.5))
(setq kg:45  (* pi 0.25))
(pragma '((protect-assign kg:270 kg:180 kg:90 kg:45)))
ADDED PICCY :
« Reply #8 on: October 25, 2009, 08:46:07 AM »
Kerry,
Interesting thread, never really thought about doing something like this.  :-)
Is there any documentation available for the pragma function that you know of?
Lee
« Reply #9 on: October 25, 2009, 04:12:00 PM »
No documentation as far as I know Lee.
It's a carry over from Vital Lisp by Basis Software who sold what became Visual Lisp to AutoDesk. ( about 1995 if I recall).
I have the manuals boxed away 'somewhere' I think.
DEVITG
« Reply #10 on: October 25, 2009, 09:27:21 PM »
After a Search .
I got it
http://msdn.microsoft.com/en-us/library/sctyh01s%28VS.80%29.aspx
If you use the intrinsic pragma (or /Oi) to tell the compiler to generate intrinsic functions (intrinsic functions are generated as inline code, not as function calls), you can use the function pragma to explicitly force a function call. Once a function pragma is seen, it takes effect at the first function definition containing a specified intrinsic function. The effect continues to the end of the source file or to the appearance of an intrinsic pragma specifying the same intrinsic function. The function pragma can be used only outside of a function — at the global level.
For lists of the functions that have intrinsic forms, see #pragma intrinsic.
 Example
« Reply #11 on: October 25, 2009, 10:08:05 PM »
ok, a revised answer.
No documentation from AutoDesk relating explicitly to VLisp as far as I know Lee.  :)
TimSpangler
  • CAD Naked!!
« Reply #12 on: October 26, 2009, 07:27:48 AM »
So maybe Its because I haven't had my morning java yet, ....but.....what's the value of doing t his?
ACA 2015 - Windows 7 Pro
« Reply #13 on: October 26, 2009, 08:34:16 AM »
I use it for library functions Tim.
Because the functions Symbol name is protected, any attempt to redefine the function will generate a warning.
... handy sometimes.
TimSpangler
  • CAD Naked!!
« Reply #14 on: October 26, 2009, 10:55:03 AM »
Ah...Gotcha!
Thanks  8-)
