Author Topic: Question about disposing.  (Read 14348 times)
Glenn R
Re: Question about disposing.
« Reply #30 on: October 28, 2009, 05:34:53 PM »
*Edit: At least you all didn't say "what a mess, you call that code?"   :laugh:
Don't count your chickens as the old saying goes... :-D
Seriously, when I asked you to post your solution, what I meant was that you would post it to this thread, not send it to me in a PM, so more eyes than just mine can critique it  - if that's what you're after that is, if not, ignore this.
Can you tell me/us, what you're AutoCAD and programming background is? The reason I ask is that after a quick scan of your solution, there appears to be some fundimental language/usage errors...well, at least to me there is.
Cheers,
Glenn.
BillZndl
« Reply #31 on: October 29, 2009, 07:22:33 AM »
Well, I didn't think it would've helped to just post my main form code without posting the rest too.
But then I didn't think it would work to try to paste everything into a post here either (it's just too much).
It probably was stupid to just dump it all on you anyway, I think I panicked. Sorry.
Again, I'm a newbie at C# and after some labs and trials I put this solution together to help us track out parts.
Most of what I've done is from the Autodesk .net site and web searches for examples/help, i.e. msdn docs & "Through the Interface".
Programming is my unofficial "side job".
I work in a manufacturing facilities engineering/CAD/CAM dept and
I've been using AutoCAD since about '92 and have programmed extensively in Autolisp almost that long.
It was getting to where I needed to learn something new with more functionality and focus on dialogs.
I thought about ObjectDCL, VB or something like that but after looking around,
decided to learn something that may have more of a future and reduce dependencies on 3rd party apps.
Everything has been a "learn as you go" experience with little formal training.
I love to program but at times I think I took on too much with C# as it is quite time consuming.
Trouble is this program works so well I hate to just abandon the whole project.  8-)
Anyway, Sorry for any inconvenience I caused and Thanks to all for your time and efforts and help!
I sure appreciate it.
I'll just keep pecking away here, I think I'm close.  ^-^
It's Alive!
  • Retired
  • AKA Daniel
« Reply #32 on: October 29, 2009, 08:09:40 AM »
Just a question for you, have you actually run the code through the debugger, where you are stepping through the stack? have you tried attaching autocad to visual studio when running your code?
BillZndl
« Reply #33 on: October 29, 2009, 08:21:37 AM »
Hmmm. Not sure what if I know how to "step through the stack".
I have run with "debug" , "start debugging" which opens AutoCAD and runs the program.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #34 on: October 29, 2009, 08:29:12 AM »
Are you setting break points and stepping though the code.. I.e
It's Alive!
  • Retired
  • AKA Daniel
« Reply #35 on: October 29, 2009, 08:33:17 AM »
oops sorry that's C++ but, it's  the same for C#  :-)
« Reply #36 on: October 29, 2009, 08:35:55 AM »
must be past my bed time .. I tried to drag the locals window out of the way to see the code  :oops:
It's Alive!
  • Retired
  • AKA Daniel
« Reply #37 on: October 29, 2009, 08:41:53 AM »
 :lol:
BillZndl
« Reply #38 on: October 29, 2009, 09:37:38 AM »
I found the "mystery glitch".
Evidently, If you open a Group using it's ObjectId from a list,
you cannot change the name to the same name.
                    ObjectIdCollection OIDC = Module.GrpInfoTbl;
                    foreach (ObjectId oid in OIDC)
                        Group grp = trans.GetObject(oid, OpenMode.ForWrite, false, true) as Group;
                        string NewName = GetNewName(grp.Name, CMDName);  //check name and possibly change.
                        grp.Name = NewName; //Kaboom if name is the same. :?
I didn't think it mattered because you are not adding a new group with the same name, only naming an existing group.
BillZndl
« Reply #39 on: November 03, 2009, 08:27:00 AM »
Okay, I'm back. The "mystery glitch" in above post was not the end of my problems on this code.
After much testing and setting break points, all for naught, I noticed something.
When I opened AutoCAD R2006 in a blank drawing, netloaded the dll and typed in the command
to bring the modless form up, then open a drawing that contains groups (SDI=1),
the listview fills and everything looks okay but if I immediately exit autocad, the Fatal Error occurs.
My question is, I have a SelectedIndexChanged event on the listview.
Could it be possible that when I hit exit, that event is firing and trying to do something
that it can't because autocad is already shutting down?
The reason I ask is because when I disable my override on the OnClosing event so that everything disposes first,
then I can shut down autocad without any problems.
The following is so components don't dispose when you want to hide the dialog
and you call up the same instance of the dialog during the session.
protected override void OnClosing(CancelEventArgs e)
            base.OnClosing(e);
            e.Cancel = true;
            Visible = false;
This is my SelectedIndexChanged event,
If I rem out the methods inside, everything exits fine:
private void listView1_SelectedIndexChanged(object sender, EventArgs e)
           if (listView1.SelectedItems.Count > 0)
                try
                    //DrawPartInPicBox();
                    //SetNameDesriptionBox();
                    //DisplayPreview();
                catch (SystemException exception)
                    MessageBox.Show("SelectedIndexDrawPartInPicBox Failed:" + exception);
I've also found some parts of my code that needed some work so it was a good exercise in debugging.
My other question is:
Is there a way to know when a listview is able to be repopulated or can you do that at any time?
TIA
Bill
BillZndl
« Reply #40 on: November 03, 2009, 10:30:41 AM »
I've taken it a step further:
If I rem out only the DrawPartInPicBox(); method, the crashing on exit stops.
               try
                    DisplayPreview();
So that leads me to believe that's the source of the problem and it's an important part of my program.
It's what reads the entities owned by the group and draws a image of it in the picture box.
Here's the code for that, if anyone can help.
Again works fine until exit.
private void DrawPartInPicBox()
            try
                if (listView1.SelectedIndices.Count > 0)
                    string str = GetSelectedItem();
                    if (!string.IsNullOrEmpty(str))
                        ListViewItem item = listView1.SelectedItems[0];
                        int indx = item.Index;
                        Pen pen1 = new Pen(Brushes.LightGray);
                        Pen pen2 = new Pen(Brushes.Cyan);
                        Pen pen3 = new Pen(Brushes.Yellow);
                        Pen pen4 = new Pen(Brushes.Red);
                        Pen pen5 = new Pen(Brushes.Orange);
                        Pen pen6 = new Pen(Brushes.Lime);
                        Pen pen7 = new Pen(Brushes.Magenta);
                        int width = pictureBox1.Size.Width;
                        int height = pictureBox1.Size.Height;
                        int num = 0;                            //counter.
                        string Itext = item.SubItems[0].Text;
                        Bitmap image = new Bitmap(width, height);
                        pictureBox1.Image = image;
                        Graphics graphics = Graphics.FromImage(image);
                        graphics.DrawString(item.Text, new Font("Romans", 10f), Brushes.Yellow, (PointF)new Point(3, height - 16));
                        ArrayList list1 = new GetEntityPointsToDraw().GetEnts(Itext, width, height); //Array of PointF[]'s.
                        if (list1.Count == 1)  //empty list.
                            Font fnt = new Font("Romans", 28f);
                            graphics.DrawString("GROUP EMPTY:", fnt, Brushes.DarkCyan, (PointF)new Point(8, height / 2));
                        if (list1.Count > 1)  //pointF[] lists and colorlist.
                            ArrayList list2 = list1[list1.Count - 1] as ArrayList; //colorlist from GetentityPointsToDraw.
                            list1.Remove(list1[list1.Count - 1]);                  //remove from pointF[]arraylist.
                            foreach (PointF[] tfArray in list1)         //draw each entity from points.
                                string color = list2[num].ToString();   //color of layer entity is on.
                                num++;
                                switch (color)
                                    case "White":
                                        graphics.DrawLines(pen1, tfArray);
                                        break;
                                    case "Blue":
                                        graphics.DrawLines(pen2, tfArray);
                                        break;
                                    case "Yellow":
                                        graphics.DrawLines(pen3, tfArray);
                                        break;
                                    case "Red":
                                        graphics.DrawLines(pen4, tfArray);
                                        break;
                                    case "Orange":
                                        graphics.DrawLines(pen5, tfArray);
                                        break;
                                    case "Green":
                                        graphics.DrawLines(pen6, tfArray);
                                        break;
                                    case "Magenta":
                                        graphics.DrawLines(pen7, tfArray);
                                        break;
                                    default:
                                        break;
                            pictureBox1.Update();
                            pen1.Dispose();
                            pen2.Dispose();
                            pen3.Dispose();
                            pen4.Dispose();
                            pen5.Dispose();
                            pen6.Dispose();
                            pen7.Dispose();
                            graphics.Dispose();
                    }                               //if str.
                }                                   //if selected indices.
            catch (Exception exception)
                MessageBox.Show("DrawPartInPicBox : " + exception.StackTrace);
I'll include the sub methods in the next post,
evidently a limit here.
BillZndl
« Reply #41 on: November 03, 2009, 10:31:38 AM »
Here's the sub methods for DrawPartInPicBox();
And here's the sub methods that the above uses, GetEntityPointsToDraw();
class GetEntityPointsToDraw
        public ArrayList GetEnts(string Strline, int Xpic, int Ypic)
                Document doc = AcadApp.DocumentManager.MdiActiveDocument;
                Database db = HostApplicationServices.WorkingDatabase;
                Editor ed = doc.Editor;
                ArrayList Pnt3dLst = new ArrayList();
                ArrayList colorList = new ArrayList();
                string name = "";
                string LaNam = "";
                using (DocumentLock doclck = doc.LockDocument())
                    using (Transaction trans = db.TransactionManager.StartTransaction())
                        DBDictionary GrpDic = (DBDictionary)trans.GetObject(db.GroupDictionaryId, OpenMode.ForRead);
                        ObjectId Did = ObjectId.Null;
                        try
                            Did = GrpDic.GetAt(Strline);
                        catch { }
                        if (!Did.IsNull)
                            Group EntGrpDic = (Group)trans.GetObject(Did, OpenMode.ForRead);
                            ObjectId[] Eids = EntGrpDic.GetAllEntityIds();
                            foreach (ObjectId eid in Eids)
                                string color;
                                Point3d CnPnt;
                                double Rad;
                                double[] Norm;
                                Point3d[] Smpts;
                                double inc;
                                Point3d EnPnt;
                                Point3d StPnt;
                                Entity ent = (Entity)trans.GetObject(eid, OpenMode.ForRead);
                                name = ent.GetType().Name;
                                LaNam = ent.Layer;
                                color = SetColorByLayerName(LaNam.ToUpper());
                                if (color == "")
                                    name = "";
                                if (name.Equals("Arc") && LaNam.Length >= 1)
                                    AcadArc oLin = (AcadArc)ent.AcadObject;
                                    CnPnt = new Point3d((double[])oLin.Center);
                                    Rad = (double)oLin.Radius;
                                    double StAn = (double)oLin.StartAngle;
                                    double EnAn = (double)oLin.EndAngle;
                                    Norm = (double[])oLin.Normal;
                                    CircularArc3d arc = new CircularArc3d(CnPnt, new Vector3d(Norm), Rad);
                                    arc.SetAngles(StAn, EnAn);
                                    Smpts = arc.GetSamplePoints(12);
                                    Pnt3dLst.Add(Smpts);
                                    colorList.Add(color);
                                    arc.Dispose();
                                if (name.Equals("Polyline") && LaNam.Length >= 1)
                                    AcadLWPolyline oLin = (AcadLWPolyline)ent.AcadObject;
                                    Object[] aco = (Object[])oLin.Explode();
                                    AcadEntity[] acEnts = new AcadEntity[aco.Length];
                                    aco.CopyTo(acEnts, 0);
                                    foreach (AcadEntity ace in acEnts)
                                        if (ace.ObjectName.Equals("AcDbArc"))
                                            AcadArc arc = (AcadArc)ace;
                                            CnPnt = new Point3d((double[])arc.Center);
                                            Rad = (double)arc.Radius;
                                            double StAn = (double)arc.StartAngle;
                                            double EnAn = (double)arc.EndAngle;
                                            Norm = (double[])arc.Normal;
                                            CircularArc3d ARP = new CircularArc3d(CnPnt, new Vector3d(Norm), Rad);
                                            ARP.SetAngles(StAn, EnAn);
                                            Smpts = ARP.GetSamplePoints(12);
                                            ARP.Dispose();
                                        if (ace.ObjectName.Equals("AcDbLine"))
                                            AcadLine lin = (AcadLine)ace;
                                            StPnt = new Point3d((double[])lin.StartPoint);
                                            EnPnt = new Point3d((double[])lin.EndPoint);
                                            Smpts = new Point3d[2];
                                            Smpts[0] = StPnt;
                                            Smpts[1] = EnPnt;
                                if (name.Equals("Circle") && LaNam.Length >= 1)
                                    AcadCircle oLin = (AcadCircle)ent.AcadObject;
                                    double perm = (double)oLin.Circumference;
                                    double dist = (perm / 11); //segments of cricle.
                                    inc = dist;
                                    Circle circ = new Circle(CnPnt, new Vector3d(Norm), Rad);
                                    Smpts = new Point3d[12];
                                    for (int x = 0; x < 12; x++)
                                        Point3d pt = circ.GetPointAtDist(inc);
                                        Smpts[x] = pt;
                                        inc = inc + dist;
                                    circ.Dispose();
                                if (name.Equals("DBPoint") && LaNam.Length >= 1)
                                    AcadPoint oLin = (AcadPoint)ent.AcadObject;
                                    CnPnt = new Point3d((double[])oLin.Coordinates);
                                    double distance = 0.1;
                                    double angle = 0.0;
                                    inc = (Math.PI * 0.5);
                                    Smpts = new Point3d[] { PolarPoint(CnPnt, angle, distance), PolarPoint(CnPnt, Math.PI, distance) };
                                    Smpts = new Point3d[] { PolarPoint(CnPnt, inc, distance), PolarPoint(CnPnt, (Math.PI + inc), distance) };
                                if (name.Equals("Ellipse") && LaNam.Length >= 1)
                                    AcadEllipse oLin = (AcadEllipse)ent.AcadObject;
                                    EnPnt = new Point3d((double[])oLin.EndPoint);
                                    StPnt = new Point3d((double[])oLin.StartPoint);
                                    Vector3d MaAx = new Vector3d((double[])oLin.MajorAxis);
                                    Vector3d MnAx = new Vector3d((double[])oLin.MinorAxis);
                                    double MaRad = (double)oLin.MajorRadius;
                                    double MnRad = (double)oLin.MinorRadius;
                                    double RR = (double)oLin.RadiusRatio;
                                    EllipticalArc3d arc = new EllipticalArc3d(CnPnt, MaAx, MnAx, MaRad, MnRad, StAn, EnAn);
                                    Smpts = arc.GetSamplePoints(50);
                                    arc.Dispose();
                                if (name.Equals("Spline") && LaNam.Length >= 1)
                                    AcadSpline oLin = (AcadSpline)ent.AcadObject;
                                    Point3dCollection fpts = new Point3dCollection();
                                    Vector3d v1 = new Vector3d((double[])oLin.StartTangent);
                                    Vector3d v2 = new Vector3d((double[])oLin.EndTangent);
                                    for (int x = 0; x < oLin.NumberOfFitPoints; x++)
                                        fpts.Add(new Point3d((double[])oLin.GetFitPoint(x)));
                                    CubicSplineCurve3d spl = new CubicSplineCurve3d(fpts, v1, v2);
                                    Smpts = spl.GetSamplePoints(50);
                                    spl.Dispose();
                                if (name.Equals("Line") && LaNam.Length >= 1)
                                    AcadLine oLin = (AcadLine)ent.AcadObject;
                                    Smpts[0] = StPnt;
                                    Smpts[1] = EnPnt;
                                }                //if
                            }          //foreach item in group dictionary.
                        }                      //ObjectId not null from group dictionary.
                    }        //using transaction.
                }      //using document lock.
                ArrayList NewArray = PointsToPicBox(Pnt3dLst, Xpic, Ypic); //PointF[] Array returned.
                NewArray.Add(colorList);                                   //Add color list.
                return NewArray;
        /// <summary>
        /// Translates & converts point3d to pointF's
        /// </summary>
        /// <param name="Pnt3dLst"></param>
        /// <param name="Xpic"></param>
        /// <param name="Ypic"></param>
        /// <returns></returns>
        private ArrayList PointsToPicBox(ArrayList Pnt3dLst, int Xpic, int Ypic)
            ArrayList PntFLst = new ArrayList();                    //PointF's for picbox.
            Matrix3d MatD = new Matrix3d();                         //displacement
            Matrix3d MatT = new Matrix3d();                         //transformation
            Matrix3d MatS = new Matrix3d();                         //scaling
            Matrix3d MatR = new Matrix3d();                         //scaling
            Point3d VwDir = (Point3d)AcadApp.GetSystemVariable("VIEWDIR");
            Plane pln = new Plane(new Point3d(0, 0, 0), VwDir.GetAsVector().Negate());
            MatT = Matrix3d.WorldToPlane(pln);
            ArrayList Pnt2dLst = ConvertPtsTo2D(Pnt3dLst, MatT);
            PointF min = new Point(1000000, 1000000);
            PointF max = new Point(-1000000, -1000000);
            foreach (Point2d[] pts in Pnt2dLst)            //ArrayList of Point2d's.
                foreach (Point2d pnt in pts)
                    PointF pt = new PointF((float)pnt.X, (float)pnt.Y);
                    min = new PointF(pt.X < min.X ? pt.X : min.X, pt.Y < min.Y ? pt.Y : min.Y); //minimum XY point.
                    max = new PointF(pt.X > max.X ? pt.X : max.X, pt.Y > max.Y ? pt.Y : max.Y); //maximum XY point.
            double VwExtX = max.X - min.X;
            double VwExtY = max.Y - min.Y;
            double SclFac;
            if ((VwExtX * 0.850) >= VwExtY)                    //X distance of points greater in proportion to Y?
                SclFac = (Xpic / VwExtX * 0.95);                    //scale X if greatest length.
            else
                SclFac = (Ypic / VwExtY * 0.95);                    //scale to Y if not X.
            Point3d p1 = new Point3d(min.X + (VwExtX / 2.0), min.Y + (VwExtY / 2.0), 0);       //center of part point.
            Point3d p2 = new Point3d(Xpic / 2.0, Ypic / 2.0, 0);                               //center of picbox.
            MatS = Matrix3d.Scaling(SclFac, p2);                                               //scale pointlist to picbox.
            MatD = Matrix3d.Displacement(p2.GetVectorTo(p1));                                  //displacement.
            MatR = Matrix3d.Rotation(Math.PI, new Vector3d(0, 0, 1), p1);                      //rotate.
            MatS = MatS * MatD * MatR;
            Point3d NewPt = new Point3d();
            foreach (Point3d[] pts in Pnt3dLst)                                 //ArrayList of PointF[]'s.
                    PointF[] PntFs = new PointF[pts.Length];
                    for (int x = 0; x < pts.Length; x++)
                        NewPt = pts[x].TransformBy(MatS * MatT);
                        PntFs[x] = new PointF((float)NewPt.X, (float)NewPt.Y);
                    PntFLst.Add(PntFs);
            return PntFLst;                                      //ArrayList of pointF[]'s.
        private ArrayList ConvertPtsTo2D (ArrayList Pnts, Matrix3d MatToPln)
            ArrayList Pt2dLst = new ArrayList();
            Point3d TempPt = new Point3d();
                foreach (Point3d[] pts in Pnts)             //ArrayList of Point3d[]'s.
                    Point2d[] Pnts2d = new Point2d[pts.Length];
                        TempPt = pts[x].TransformBy(MatToPln);
                        Pnts2d[x] = new Point2d(TempPt.X, TempPt.Y);
                    Pt2dLst.Add(Pnts2d);
                return Pt2dLst;
        private string SetColorByLayerName(string str)
            string color = "";
            switch (str)
                case "0":
                    color = "White";
                    break;
                case "BEND":
                    color = "White";
                    break;
                case "CLEAR":
                    color = "Green";
                    break;
                case "HID":
                    color = "Magenta";
                    break;
                case "LDRILL":
                    color = "Blue";
                    break;
                case "NAIL":
                    color = "Yellow";
                    break;
                case "OUTSIDE":
                    color = "Red";
                    break;
                case "PH":
                    color = "Orange";
                    break;
                default:
                    color = "";
                    break;
            return color;
        public Point3d PolarPoint(Point3d basepoint, double angle, double distance)
            return new Point3d(basepoint.X + (distance * Math.Cos(angle)), basepoint.Y + (distance * Math.Sin(angle)), basepoint.Z);
Any help appreciated.
Bill
BillZndl
« Reply #42 on: November 03, 2009, 02:05:13 PM »
Well, FWIW, I think I finally found the problem.
I was looking at GetEntityPointsToDraw() and saw what could be trouble.
After the:
I added a null entity check:
if (ent != null)
and the problem went away. :roll:
I know that I still don't have all this code down properly.
We started this program to replace one that we had that was written in Autolisp.
We were originally using Blocks and when I first wrote this in C#
it was a lot simpler using blocks.
I sort of slapped this one together because our need to have this program was great.
Anyway, I'm still looking to learn how to do things correctly so if anyone has any pointers, feel free to instruct. :)
                                string color;
                                Point3d CnPnt;
                                double Rad;
                                double[] Norm;
                                Point3d[] Smpts;
                                double inc;
                                Point3d EnPnt;
                                Point3d StPnt;
                                if (ent != null)
BillZndl
« Reply #43 on: November 04, 2009, 02:41:26 PM »
Just an update in case anyones been following my flounderings. :grazy:
I think I was just doing too much during certain events.
If I just use the FillListView() on the document activated event and don't use the SetLastSelected() or any other method
and just leave it to the user to select an item, so the SelectedIndexChanged event does the DrawPartInPicBox()
and the DisplayPreview(), things are working alot better.  :-)
I don't know enough to say for sure but it seems to me that there was some sycronization or timing issues involved when I tried to fill the listview and set the last group and display the preview and draw the part in the picturebox all in succession on the document activated. :doa:
I may just put the SetLastSelected() on a button in case one wants to find that last group created.
for some reason it seems like that one gives me trouble when it's activated several times during the drawing and I can't see why.
public class LastGroupInDrawing
        public string FindLastGroup()
            using (DocumentLock dloc = doc.LockDocument())
                    DBDictionary groups = (DBDictionary)tr.GetObject(db.GroupDictionaryId, OpenMode.ForRead);
                    ObjectId grpId = ObjectId.Null;
                    grpId = GetNewest(groups);
                    if (!grpId.IsNull)
                        return groups.NameAt(grpId);
                    else
                        return "No";
        public ObjectId GetNewest(DBDictionary dictionary)
            ICollection ids = ((IDictionary)dictionary).Values;
            ObjectId last = ObjectId.Null;
            foreach (ObjectId temp in ids)
                last = temp;
                break;
            if (!last.IsNull)
                long current = last.Handle.Value;
                foreach (ObjectId id in ids)
                    long value = id.Handle.Value;
                    if (value > current)
                        current = value;
                        last = id;
            return last;
As time permits, I'll study my O'Reilly's C# book and hopefully learn more about all this.
For now the bottom line is, it works, just gotta hit qsave often to be safe.   :whistle:
Glenn R
« Reply #44 on: November 05, 2009, 01:27:51 PM »
Is that book by Jesse Liberty? If so, I was going to suggest it as a beginners book.
When you're ready to move to a more advanced book, myself and others here recommend Andrew Troelsen's 'Pro C# and the .NET 3.5 Platform' - it's excellent.
These languages are not like lisp where you can just 'hack away' - you need to put in the effort of learning the groundwork of the language and it's usage.
Keep at it - it is fun!
