Author Topic: What's the most efficent way to get layout names  (Read 5164 times)
Viktor
« on: October 21, 2009, 01:56:00 PM »
I have a need in one of my apps to let the user pick layouts out of a drawing. Normally, I have a listbox with a list of files in a selected directory, and if a user checks a mutli-tab checkbox, then I want to update the list with all the filesnames and layouts.
Anyway, I've written a simple GetLayouts function to go through the btrs and check if its a layout then retrieve the name and return an array of names. This works great if there's 5 files, but if I have 50 this may take upto 20 seconds... The most consuming part of the code of course is this:
database.ReadDwgFile(filepath, FileOpenMode.OpenForReadAndAllShare, False, "")
So is there any other quicker way to get layouts?
Thanks,
Viktor.
gile
  • Marseille, France
Re: What's the most efficent way to get layout names
« Reply #1 on: October 21, 2009, 02:07:07 PM »
You can iterate the "ACAD_LAYOUT" dictionary.
    DBDictionary NOD = (DBDictionary)tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead);
    DBDictionary layouts = (DBDictionary)tr.GetObject(NOD.GetAt("ACAD_LAYOUT"), OpenMode.ForRead);
    foreach (DBDictionaryEntry entry in layouts)
        string name = entry.Key;
« Last Edit: October 21, 2009, 02:17:28 PM by gile »
Glenn R
« Reply #2 on: October 21, 2009, 04:22:57 PM »
Viktor,
You need to specify at the least, the following information for more targeted help from members:
1. AutoCAD version
2. .NET framework version
3. Operating system and service packs
4. Visual Studio version
5. 32 or 64 bit for all the above for good measure
Also, a small example project that members can test with would be very beneficial as well.
Viktor
« Reply #3 on: October 21, 2009, 05:05:39 PM »
Viktor,
1. AutoCAD version
My apology Glenn, it was more of a general question, here's more info:
1. AutoCad 2010
2. .net 3.5
4. XP
4. VS2008 express
5. 32bit
6. VB.net
Here's the function I use to get the layouts:
    Public Function GetLayouts(ByVal filepath As String) As ArrayList
        Dim database As New Database(False, True)
        Dim list As New ArrayList
        Dim transaction As Transaction = database.TransactionManager.StartTransaction
        Using database
            Try
                database.ReadDwgFile(filepath, FileOpenMode.OpenForReadAndAllShare, True, Nothing)
                Dim enumerator As SymbolTableEnumerator = DirectCast(database.BlockTableId.GetObject(OpenMode.ForRead), BlockTable).GetEnumerator
                Do While enumerator.MoveNext
                    Dim record As BlockTableRecord = DirectCast(enumerator.Current.GetObject(OpenMode.ForRead), BlockTableRecord)
                    If record.IsLayout Then
                        Dim layout As Layout = DirectCast(record.LayoutId.GetObject(OpenMode.ForRead), Layout)
                        If (layout.LayoutName <> "Model") Then
                            list.Add((layout.LayoutName))
                        End If
                    End If
                Loop
            Catch exception1 As Exception
                transaction.Abort()
                Return Nothing
            Finally
                transaction.Dispose()
            End Try
        End Using
        Return list
    End Function
This works, but the fact that I have to read the database of each drawing in my list takes quiet a bit of time. For example, if i have 30 drawings that are 2-5mb each with 3-5 layouts in each, this can take upto 30 seconds to scan for layouts. Like I said, the most consuming part of this code is opening the database.
I'd guess there's no other way without using objectarx, but thought i'd ask either way.
Glenn R
« Reply #4 on: October 21, 2009, 05:48:06 PM »
heh...forgot to add 6. Language - thanks.
In ObjectARX, you would still have to 'read' the dwg dbase as well, so that point is moot.
You could also do this:
[CommandMethod("MyCommandLocal", CommandFlags.Modal)]
public void MyCommand() // This method can have any name
Document doc = acadApp.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
DBDictionary layoutDict = tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead, false) as DBDictionary;
foreach (DBDictionaryEntry dictEnt in layoutDict)
//Layout layout = tr.GetObject(dictEnt.Value, OpenMode.ForRead, false) as Layout;
//ed.WriteMessage("{0}Layout name: {1}", Environment.NewLine, layout.LayoutName);
ed.WriteMessage("{0}Layout name: {1}", Environment.NewLine, dictEnt.Key);
Also, why are you using GetEnumerator?
Viktor
« Reply #5 on: October 21, 2009, 06:02:06 PM »
Thankgs Glenn, yea i was feeling hopeless either way but thought of asking. In the sample you provided you're getting the layouts of the current drawing if i'm not mistaken, I don't want to open drawings cause that would take another 20 minutes.
As far as enumerator goes, i actually copied this from a vb.net book i use, but to be honest with you i rarely use the enumerator other than where I copied it. I may not be doing it any better way though, i just loop through the id's in a for each loop once i find what i need i exit for.
What's the best way?
I also signed up for the linq class at AU this year, i love linq for everything outside of autocad db, so it'd be interesting to see how i can use it in autocad db. Do you linq?
Glenn R
« Reply #6 on: October 21, 2009, 06:09:25 PM »
Yes I am, but it's a quick example. You will see that I'm getting the layouts from the DATABASE of the current document...it's still a databse, the same as you're constructing and using in ReadDwgFile.
Also, you're iterating the whole block table to find the layouts, which in dwgs of 2-5mb could be large, whereas I'm going straight to the layouts dictionary, similar to what gile posted above, which, all things being equal, should be faster.
Try it.
gile
  • Marseille, France
« Reply #7 on: October 21, 2009, 06:18:58 PM »
Something like this ?
public ArrayList GetLayouts(string filename)
    ArrayList lst = new ArrayList();
    using (Database db = new Database(false, true))
        try
            db.ReadDwgFile(filename, System.IO.FileShare.None, false, string.Empty);
                    if (name == "Model") continue;
                        lst.Add(name);
                tr.Commit();
            return lst;
        catch
            return null;
Glenn R
« Reply #8 on: October 21, 2009, 06:23:49 PM »
I don't think FileShare.None is correct; from memory this will block anybody from using the file...it's the opposite to what I always think it is ;)
Also gile, you're going for the NOD, whereas what I posted, bypasses that, but other than that, yes.
Viktor
« Reply #9 on: October 21, 2009, 06:40:00 PM »
Try it.
No doubt its faster the way you have it, will be using your approach there. But to eliminate the reading of the database I am changing the architecture of the app. Instead of reloading the list with filenames/layouts I instead load on demand when the user actually clicks on the file, then I get all the data from all the layouts and allow the user to shuffle between sheets at that point. So i'm moving the delay to a place where its less noticable.
Anyway, thanks everyone for their input.
gile
  • Marseille, France
« Reply #10 on: October 21, 2009, 06:44:14 PM »
Thanks for the corrections.
I didn't saw "db.LayoutDictionaryId" before (so many things to learn...)
Glenn R
« Reply #11 on: October 21, 2009, 06:46:57 PM »
Viktor,
I was going to suggest a lazy loading approach, but try what I suggested first and then make the decision.
Gile,
You're wlecome.
« Reply #12 on: October 21, 2009, 07:39:01 PM »
Who's teaching the class Viktor ??
csharpbird
« Reply #13 on: October 22, 2009, 09:03:39 AM »
Albert Szilvasy
Using .NET 4.0 with AutoCADŽ
http://au.autodesk.com/?nd=e_class&session_id=5164
Viktor
« Reply #14 on: October 22, 2009, 12:25:58 PM »
How many of you guys going to AU .net classes?
btw, who's using linq in autocad db so far?
