Author Topic: Wind Turbines  (Read 4977 times)
Wind Turbines
« on: October 19, 2009, 02:25:30 PM »
Looking for some dwg's of wind turbines. Anyone have any thing they can share?
thanks
« Last Edit: October 19, 2009, 02:33:58 PM by Mark »
Re: Wind Turbines
« Reply #1 on: October 19, 2009, 03:00:34 PM »
you have any spacial size in mind?
mtc49 might have some...might want to PM to get his attention...
Re: Wind Turbines
« Reply #2 on: October 19, 2009, 03:04:34 PM »
I'm looking for the basic structure, something that could be used in a presentation. A 3D drawing is the ultimate goal.
Will do. Thanks Michael.
Re: Wind Turbines
« Reply #3 on: October 19, 2009, 03:16:48 PM »
also let me hit these other folks...I think they were doing a wind farm siting study, and might have some pin wheels, I mean Turbines for you....are you in the 120' blade range out there in the swamps?
Re: Wind Turbines
« Reply #4 on: October 19, 2009, 03:22:12 PM »
These are the big ones from what I gather, 500' towers.
Re: Wind Turbines
« Reply #5 on: October 19, 2009, 11:42:12 PM »
OK, just for fun and games (and to review the 3d tools in 2010) I've ripped this one out for you.
I've use (meters) for units and the Base Point is the Bottom of a 500' tower and a modified dihedral blade (40 meters)
a generic nose cone and generator housing structure on top. You might want to rev or extrude a main axle to connect the blades/hub to the Generator box should that angle be in view in your renders.  I did not round the tips of the turbine blades; not that they all are, for your stated needs that shouldn't be an issue.  You have most of the primatives so have fun!
What I might do from here, is apply some basic material (white paint) to most of it and a decal/image map to the turbine housing for the (utility, client. or your company logo), then save 3 or 4 versions with different rotations applied to the blades.  Then insert these as reference blocks to build up the wind farm.
« Last Edit: October 20, 2009, 12:31:18 AM by mjfarrell »
Re: Wind Turbines
« Reply #6 on: October 20, 2009, 01:48:59 AM »
Oh, yeah,
this is crossing into C3D; if one sets up a point style/description key that uses the Turbines as the points symbol.  Then one can use points on surface command (Gird of points) and place a small herd of them rather quickly.  Then just kill a few random ones it looks pretty good.  Alternately, if one inserts the turbines as blocks, one should then use the move blocks to surface function.
Re: Wind Turbines
« Reply #7 on: October 20, 2009, 06:56:51 AM »
Thank you, very much! I was going to try my hand at drawing one too but couldn't even find some specs for one.
Re: Wind Turbines
« Reply #8 on: October 20, 2009, 07:02:52 AM »
Could I get that in an older version? Say '09 maybe.
Thanks Michael
Re: Wind Turbines
« Reply #9 on: October 20, 2009, 09:23:15 AM »
Thanks Michael
And to think folks believe I'm on a TIRADE when I complain about lack of compatability between versions....
Anyway before I go off on a rant ;) ...
Here it is in 2007 format from the 2010 True View converter.
Re: Wind Turbines
« Reply #10 on: October 20, 2009, 09:35:38 AM »
Specs....we don't need no stinking specs....   8-)  <<theres yer specs
Although I must say the experience was overall GOOD.  There are still some interface and command settings in this 2010 that are enough different that I must say it impacted the overall speed of the process.  However there are a lot a of good basic 3d tools to play with!
Re: Wind Turbines
« Reply #11 on: October 20, 2009, 09:44:15 AM »
On a side note; during my research for the model, I happened across a company in Japan that creates blades in a 'composite' method using Bamboo fibers! Now that is both GREEN and SUSTAINABLE!  Wind power blades made from big giant weeds (bamboo)!
Re: Wind Turbines
« Reply #12 on: October 20, 2009, 01:01:44 PM »
Mark, let's see some sample renders...if that worked for you.
Re: Wind Turbines
« Reply #13 on: October 20, 2009, 01:38:12 PM »
Thanks Michael
When I try to open that dwg I get the following.
Re: Wind Turbines
« Reply #14 on: October 20, 2009, 05:34:56 PM »
