Author Topic: Dynamic Offset  (Read 49195 times)
Re: Dynamic Offset
« Reply #75 on: February 26, 2010, 11:12:40 AM »
Evgeniy - fantastic idea to use inters, makes the problem much simpler  8-)
LE3
Re: Dynamic Offset
« Reply #76 on: February 26, 2010, 11:29:48 AM »
nice tools !
anyone had tried them with heavy polylines? - (just tested the one Eugenio posted)
dynoff works - remainds me one of the commands from intergraph microstation 4.0
Excellent, thanks Luis  8-)
I see you started to hide your ideas, great move :)
Re: Dynamic Offset
« Reply #77 on: February 26, 2010, 11:31:51 AM »
nice tools !
I just like a have a bit more ownership on some programs - if I have spent a bit more time on them.
ElpanovEvgeniy
  • Moscow (Russia)
Re: Dynamic Offset
« Reply #78 on: February 26, 2010, 12:14:51 PM »
Evgeniy, I have a question,
why the use of 'progn' at the very start of the code? What is its purpose in this case?
This debris was left after the stage of writing ...
Re: Dynamic Offset
« Reply #79 on: February 26, 2010, 12:49:17 PM »
Ok I see  :-)
wizman
Re: Dynamic Offset
« Reply #80 on: February 26, 2010, 02:42:34 PM »
Good clean solution Elpanov, but having minor bug if first segment is an arc.
ElpanovEvgeniy
  • Moscow (Russia)
Re: Dynamic Offset
« Reply #81 on: February 26, 2010, 04:37:32 PM »
My program, only a demonstration of one approach to solving the problem.
I do not have enough time to write the final function.
Re: Dynamic Offset
« Reply #82 on: February 26, 2010, 04:57:51 PM »
Its a shame that LISP does not have a 'remove_last' function, all those reverse's can't do much for performance...  :-(
Ее жаль, что Лисп не имеет функции "remove_last ', все эти обратное не может многое сделать для выполнения ...
qjchen
  • Best wishes to all
Re: Dynamic Offset
« Reply #83 on: February 26, 2010, 06:57:20 PM »
I can not get an error on your description ...
autocad 2008 en (sp 1)
Evgeiny, I am still use Autocad 2004, maybe this cause the error.
It seems that I should upgrade my acad version~~
http://qjchen.mjtd.com
ElpanovEvgeniy
  • Moscow (Russia)
Re: Dynamic Offset
« Reply #84 on: February 27, 2010, 12:32:35 AM »
Hello, Chen!
Today, I will set the program to work in acad 2004.
ElpanovEvgeniy
  • Moscow (Russia)
Re: Dynamic Offset
« Reply #85 on: February 27, 2010, 01:04:22 AM »
(defun c:ofss (/ E G O P1 P2 V1 V2 V3)
* by ElpanovEvgeniy 26.02.2010
* 27.02.2010 8:30
* fix bug for acad 2004 (vlax-curve-getFirstDeriv e (vlax-curve-getEndParam e))
* 27.02.2010 8:55
* fix bug for first arc segment
 (setq e  (entsel)
       p1 (cadr e)
       e  (car e)
       p1 (fix (vlax-curve-getParamAtPoint e (vlax-curve-getClosestPointTo e p1)))
       o  (vlax-ename->vla-object e)
 ) ;_  setq
 (if (= 1 (cdr (assoc 70 (entget e))))
  (cond ((zerop p1)
         (setq p2 (1+ p1)
               v1 (list (vlax-curve-getPointAtParam e (vlax-curve-getEndParam e))
                        (vlax-curve-getFirstDeriv e (1- (vlax-curve-getEndParam e)))
                  ) ;_  list
               v2 (list (vlax-curve-getPointAtParam e p1) (vlax-curve-getFirstDeriv e 0.5))
               v3 (list (vlax-curve-getPointAtParam e p2) (vlax-curve-getFirstDeriv e 1.5))
         ) ;_  setq
        ((= p1 (1- (vlax-curve-getEndParam e)))
         (setq p2 0
               v1 (list (vlax-curve-getPointAtParam e (1- p1))
                        (vlax-curve-getFirstDeriv e (+ (1- p1) 0.5))
                  ) ;_  list
               v2 (list (vlax-curve-getPointAtParam e p1) (vlax-curve-getFirstDeriv e (+ p1 0.5)))
               v3 (list (vlax-curve-getPointAtParam e p2) (vlax-curve-getFirstDeriv e (+ p2 0.5)))
         ) ;_  setq
        ((setq p2 (1+ p1)
                  ) ;_  list
         ) ;_  setq
  ) ;_  cond
  (cond ((zerop p1)
         (setq p2 (1+ p1)
               v2 (list (vlax-curve-getPointAtParam e 0) (vlax-curve-getFirstDeriv e 0.5))
               v1 (list (car v2) (list (cadadr v2) (- (caadr v2)) 0.))
         ) ;_  setq
         (setq p2 (vlax-curve-getEndParam e)
                  ) ;_  list
               v3 (list (vlax-curve-getPointAtParam e p2) (list (cadadr v2) (- (caadr v2)) 0.))
         ) ;_  setq
        ((setq p2 (1+ p1)
                  ) ;_  list
         ) ;_  setq
  ) ;_  cond
 ) ;_  if
 (while (= (car (setq g (grread nil 5 0))) 5)
  (vla-put-coordinate
   o
   p1
   (vlax-make-variant
    (vlax-safearray-fill (vlax-make-safearray 5 '(0 . 1))
                         (reverse (cdr (reverse (inters (car v1)
                                                        (mapcar '+ (car v1) (cadr v1))
                                                        (cadr g)
                                                        (mapcar '+ (cadr g) (cadr v2))
                                                        nil
                                                ) ;_  inters
                                       ) ;_  reverse
                                  ) ;_  cdr
                         ) ;_  reverse
    ) ;_  vlax-safearray-fill
   ) ;_  vlax-make-variant
  ) ;_  vla-put-coordinate
  (vla-put-coordinate
   o
   p2
   (vlax-make-variant
                         (reverse (cdr (reverse (inters (car v3)
                                                        (mapcar '+ (car v3) (cadr v3))
                                                        (cadr g)
                                                        nil
                                                ) ;_  inters
                                       ) ;_  reverse
                                  ) ;_  cdr
                         ) ;_  reverse
 ) ;_  while
« Last Edit: February 27, 2010, 01:41:18 AM by ElpanovEvgeniy »
wizman
Re: Dynamic Offset
« Reply #86 on: February 27, 2010, 01:07:58 AM »
Outstanding Sir, thanks for Sharing your solution.
ElpanovEvgeniy
  • Moscow (Russia)
Re: Dynamic Offset
« Reply #87 on: February 27, 2010, 01:29:47 AM »
Many thanks!  :-)
Atwist
Re: Dynamic Offset
« Reply #88 on: February 27, 2010, 08:05:46 AM »
Hello ElpanovEvgeniy,
I have load your LISP but I have a problem, what does this mean.
Sorry but my knowledge of lisp is nil.
sceenshot have attached
qjchen
Re: Dynamic Offset
« Reply #89 on: February 27, 2010, 10:31:38 AM »
Thanks Evgeniy.
Now it works very good in Autocad 2004, and also good for the first segment arc situation~
