Author Topic: Dynamic Offset  (Read 49998 times)
Dynamic Offset
« on: October 18, 2009, 07:58:14 AM »
Was experimenting with this idea..., perhaps it might be useful to some of you, (possibly those doing piping?) - let me know what you think  :wink:
Settings Dialog:
;;;¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,;;;
;;;ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,¤º°`°º¤;;;
;;                        --=={  Dynamic Offset  }==--                           ;;
;;  Allows the user to dynamically offset multiple objects simultaneously, by    ;;
;;  either specifying the offset distance via mouse-click, or at the             ;;
;;  command-line. The command-line default will remember the last offset entered ;;
;;  by the user.        ;;
;;  Object Snap functionality is retained, and the on-screen offset distance is  ;;
;;  determined by the nearest object in the offset selection set.                ;;
;;  The user can use the +/- keys to change the number of offsets, or,           ;;
;;  alternatively, the user can press 'N' and specify the number of offsets      ;;
;;  directly.        ;;
;;  The user can also press 'S' during object offset to change the layer,        ;;
;;  linetype, lineweight, and colour of the resultant offset objects.            ;;
;;  By pressing TAB the user can switch modes between offsetting both sides or   ;;
;;  just one side of an object.                                                  ;;
;;  The toggle for retaining or deleting the original Objects can be altered by  ;;
;;  pressing 'D'. The user can hold SHIFT to highlight the offset entities.      ;;
;;  FUNCTION SYNTAX:  DYNOFF                                                     ;;
;;  AUTHOR:        ;;
;;  Copyright © Lee McDonnell, October 2009. All Rights Reserved.                ;;
;;      { Contact: Lee Mac @ TheSwamp.org, CADTutor.net }                        ;;
;;  WITH THANKS TO:                                                              ;;
;;      ¤ø¤   Elpanov Evgeniy           ~¤~   Code for GrRead OSnap Symbols.     ;;
;;  VERSION:        ;;
;;    ø 1.0   ~¤~   17th October 2009   ~¤~   º First Release                    ;;
;;    ø 1.1   ~¤~   19th October 2009   ~¤~   º Added Object Snap functionality  ;;
;;    ø 1.2   ~¤~   20th October 2009   ~¤~   º Added Multiple Offset Option     ;;
;;    ø 1.3   ~¤~   21st October 2009   ~¤~   º Updated Object Snap Coding       ;;
;;    ø 1.4   ~¤~   23rd October 2009   ~¤~   º Updated Offset Number Options    ;;
;;                                            º Added option to specify Offset   ;;
;;                                              factor.                          ;;
;;    ø 1.5   ~¤~   29th October 2009   ~¤~   º Added Settings Dialog.           ;;
;;    ø 1.6   ~¤~   8th December 2009   ~¤~   º Added option to only offset      ;;
;;                                              object on one side.              ;;
;;    ø 1.7   ~¤~  10th December 2009   ~¤~   º Added option to delete original  ;;
;;                                              objects.                         ;;
;;    ø 1.8   ~¤~  14th December 2009   ~¤~   º Added ability to offset to the   ;;
;;                                              center of two objects.           ;;
;;    ø 1.9   ~¤~  16th December 2009   ~¤~   º Modified method for spacing      ;;
;;                                              multiple offsets.                ;;
;;                                            º Improved OSnap Coding.           ;;
;;    ø 2.0   ~¤~  18th December 2009   ~¤~   º Added colour change for offset   ;;
;;                                              entities.                        ;;
;;                                            º Fixed Bug when using Offset      ;;
;;                                              Factor.                          ;;
[ Code updated to Version 2.0 ]
Code available here.
« Last Edit: November 14, 2010, 08:04:16 PM by Lee Mac »
Crank
Re: Dynamic Offset
« Reply #1 on: October 18, 2009, 12:19:41 PM »
Lee,
I like how it's working, but as it is this is almost useless to me. In the dynamic part only a through point is possible, but osnaps are not working.
I think it would also a good idea to have a list with fixed distances. Pressing the CTRL-key would use a picked distance (like relaxed constrains) and if not pressed it would use the fixed distances of the list.
alanjt
  • Standby for witty remark...
Re: Dynamic Offset
« Reply #2 on: October 18, 2009, 12:49:07 PM »
I was thinking the same thing. Offsetting is such a specific task.
Dropbox
qjchen
  • Best wishes to all
Re: Dynamic Offset
« Reply #3 on: October 19, 2009, 01:00:47 AM »
I will also wish Autodesk can directly support grread with osnap.
Here, Evgeniy also write the similar function :)
http://www.theswamp.org/index.php?topic=12692.0
http://qjchen.mjtd.com
alanjt
Re: Dynamic Offset
« Reply #4 on: October 19, 2009, 01:13:24 AM »
Wouldn't that be nice. :)
Dropbox
Re: Dynamic Offset
« Reply #5 on: October 19, 2009, 07:07:51 AM »
Thanks for the feedback guys, I realise that with most GrRead programs, OSnap is needed, and I will consider incorporating it into this example in the near future.
You can specify an offset at the command line, and it will also remember the last entry as default. I wanted to make it as generic as possible, but I shall consider your list idea.  :wink:
Lee
Andrea
Re: Dynamic Offset
« Reply #6 on: October 19, 2009, 01:29:32 PM »
Hi Lee...
another nice one ! congrat !
Idea:
It will be nice to have the possibility to have choice between offset 1 or 2 sides of the object.
Also,..there's more from my head.. :roll:
(see pic)
Keep smile...
Re: Dynamic Offset
« Reply #7 on: October 20, 2009, 07:17:01 AM »
Thanks Andrea - some nice ideas there indeed... I shall see what I can add to it when time permits  :wink:
Thanks for the suggestions, I also have a few more ideas of my own for this one  :wink:
Re: Dynamic Offset
« Reply #8 on: October 20, 2009, 07:28:16 AM »
I have updated the code in the first post to include Version 1.1, hopefully incorporating the all-important Object Snap!  :angel:
VovKa
  • Ukraine
Re: Dynamic Offset
« Reply #9 on: October 20, 2009, 01:11:53 PM »
alanjt
Re: Dynamic Offset
« Reply #10 on: October 20, 2009, 01:19:43 PM »
The osnap marker is displaying a million miles (km, since your british  :wink:) away.
Dropbox
alanjt
Re: Dynamic Offset
« Reply #11 on: October 20, 2009, 01:25:01 PM »
Dropbox
Re: Dynamic Offset
« Reply #12 on: October 21, 2009, 05:16:35 AM »
miles... since I'm british...  :-P
It does work fine for me, but I shall look into it all the same  :-)
Re: Dynamic Offset
« Reply #13 on: October 21, 2009, 05:29:45 AM »
I have updated the code to Version 1.2, this will not yet correct the oSnap difficulties you are having, but there is a new option to offset multiple times (by pressing +/-).  ;-)
Just out of interest, are you all experiencing the problems that Alan reported?
Lee
alanjt
Re: Dynamic Offset
« Reply #14 on: October 21, 2009, 10:27:07 AM »
Lee, was the method for entering/backspacing a number value one of your ideas? That is freaking brilliant. I'm totally stealing that.
Dropbox
