Author Topic: Dynamic Text Alignment  (Read 27522 times)
« on: October 10, 2009, 10:09:58 AM »
Had a bit of time free last night, was toying around with this idea - will let the user align text horizontally/vertically at any angle.
Not sure if its been done before or not...
;;;¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,;;;
;;;ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,¤º°`°º¤;;;
;;                      --=={  Dynamic Text Align  }==--                         ;;
;;  Allows the user to dynamically align text to any angle. User is prompted to  ;;
;;  make a selection of Text or MText objects to align, and pick an alignment    ;;
;;  point, or select a text object to use for alignment. The selection of text   ;;
;;  is then aligned by either x or y coordinate, or dynamically stretched        ;;
;;  depending on the mode chosen.                                                ;;
;;  The mode can be switched upon pressing TAB during alignment. Text and MText  ;;
;;  entities will be aligned in accordance with their respective justifications. ;;
;;  The user can also specify a fixed text spacing, by pressing 'S' during text  ;;
;;  alignment. Holding Shift whilst aligning Text will alter Text Rotation, the  ;;
;;  user can also refine Rotation by pressing 'R' during text alignment. Text    ;;
;;  Justfication can be altered by pressing 'J' during text alignment.           ;;
;;  Object Alignment Mode:-                                                      ;;
;;  Text can be aligned to an object by pressing 'O' during text alignment. In   ;;
;;  this mode, the text spacing along the object can be adjusted by pressing     ;;
;;  'S' and the text offset from the object can also be altered by pressing 'O'. ;;
;;  Text Rotation can be aligned to the tangent vector of the object at the      ;;
;;  point of alignment by holding Shift during text placement. The user can      ;;
;;  furthermore specify a text rotation by pressing 'R'.                         ;;
;;  The order of the text entities along the object can be Reversed by pressing  ;;
;;  'V' during Text placement. The original order of these entities is           ;;
;;  determined by the drawing direction of the object.                           ;;
;;  FUNCTION SYNTAX:  TXALIGN                                                    ;;
;;  Notes:-        ;;
;;  Shift Functionality requires the user to have Express Tools installed.       ;;
;;  AUTHOR:        ;;
;;  Copyright © Lee McDonnell, October 2009. All Rights Reserved.                ;;
;;      { Contact: Lee Mac @ TheSwamp.org, CADTutor.net }                        ;;
;;  VERSION:        ;;
;;    ø 1.0   ~¤~   12th October 2009   ~¤~   º First Release                    ;;
;;    ø 1.1   ~¤~   14th October 2009   ~¤~   º Added ability to Specify fixed   ;;
;;                                              text spacing                     ;;
;;    ø 1.2   ~¤~   15th October 2009   ~¤~   º Added Stretch Mode               ;;
;;                                            º Upgraded User messaging          ;;
;;    ø 1.3   ~¤~   18th October 2009   ~¤~   º Added Rotation Functionality     ;;
;;    ø 1.4   ~¤~   20th October 2009   ~¤~   º Added functionality to align     ;;
;;                                              text to object.                  ;;
;;    ø 1.5   ~¤~   23rd October 2009   ~¤~   º Added Justification Options.     ;;
;;    ø 1.6   ~¤~   28th October 2009   ~¤~   º Added Option to Select Text      ;;
;;                                              object at Alignment Point prompt ;;
[ Code updated to Version 1.6 ]
Read the code header for help  :-)
Code available here.
« Last Edit: November 14, 2010, 08:07:56 PM by Lee Mac »
Re: Dynamic Text Alignment
« Reply #1 on: October 10, 2009, 11:05:58 AM »
Looks like a dynamic bonanza around here. :roll:
Very cool.
SteveK
« Reply #2 on: October 11, 2009, 05:13:31 PM »
I think I'm gonna find that extremely useful! Thanks Lee (Though I thought you are meant to be studying now...)
SteveK
« Reply #3 on: October 11, 2009, 05:15:29 PM »
So yeah, looking forward to it. Though hopefully you can integrate a feature that allows for static vertical or horizontal (ie it'll just align one)
Hugo
« Reply #4 on: October 12, 2009, 02:45:54 AM »
Hallo Lee
Sieht Tool aus, aber wo kann man das Uploden
Bakerman
« Reply #5 on: October 12, 2009, 07:00:05 AM »
Hey, I think I could use something like that. Nice job!  :-)
« Reply #6 on: October 12, 2009, 08:00:56 AM »
Thanks guys,
Haven't had too much time as you know, but will get the code on here asap  ;-)
« Reply #7 on: October 12, 2009, 08:01:50 AM »
With regards to the static vertical/horizontal alignment, you can hit Ortho for these  :wink:
Krushert
  • FREE BEER Tomorrow!!
« Reply #8 on: October 12, 2009, 08:45:52 AM »
Very cool beans.  I will give it a try.
Maybe along the alignment feature throw in a "Enter amount of clear space between" user input variable/feature.  Pretty please with sugar on top.  :roll: :-)
Which is on my to-do list to add to antiquated text alignment proggy that I have.
« Reply #9 on: October 12, 2009, 11:27:10 AM »
Here is one I wrote awhile ago, not dynamic or anything though.......  :-)
(defun c:SpaceNotes (/ TxtRot TxtList TxtHt Obj NewInsPt InsPt Ent Dis1 StyObj DftHt TxtSty StyList curSty
    temp1 temp2 ss ocmd SpaceRatio)
    Used to line up notes equally spaced vertically.
    By Tim Willey   Dec. 2004
    Sub's 'tmw:ss->Objlist 'tmw:Var->Safe 'MakeX 'value
    (setq ocmd (getvar "cmdecho")) (setvar "cmdecho" 0)
    (setq ActDoc (vla-get-ActiveDocument (vlax-get-ACAD-Object)))
    (vlax-invoke-method ActDoc 'StartUndoMark)
    (setvar "errno" 0)
    (while
        (and
            (not Ent)
            (/= (getvar "errno") 52)
        (setq Ent (entsel "\n Select first note object: "))
            (and
                Ent
                (or
                    (= (value 0 (entget (car Ent))) "TEXT")
                    (= (value 0 (entget (car Ent))) "ATTDEF")
                (not (redraw (car Ent) 3))
                (if (not (setq SpaceRatio (getdist "\n Enter ratio of typical distance between text objects [1.0]: ")))
                    (setq SpaceRatio 1.0)
                    T
                (setq Obj (MakeX (car Ent)))
                (if (= (vla-get-Alignment Obj) 0)
                    (setq InsPt (safearray-value (variant-value (vla-get-InsertionPoint Obj))))
                    (setq InsPt (safearray-value (variant-value (vla-get-TextAlignmentPoint Obj))))
                (setq TxtHt (vla-get-Height Obj))
                (setq TxtRot (vla-get-Rotation Obj))
                (setq TxtSty (vla-get-StyleName Obj))
                (setq CurSty (vla-get-ActiveTextStyle ActDoc))
                (setq StyList (vla-get-TextStyles ActDoc))
                (vlax-for item StyList
                    (if (= (vla-get-Name item) TxtSty)
                            (setq StyObj item)
                            (setq DftHt (vla-get-Height item))
                            (vla-put-Height item 0.0)
                (vla-put-ActiveTextStyle ActDoc StyObj)
                (command "_.text" InsPt TxtHt TxtRot "N")
                (setq temp1 (entlast))
                (command "_.text" "" "N")
                (setq temp2 (entlast))
                (setq Dis1 (* SpaceRatio (distance (value 10 (entget temp1)) (value 10 (entget temp2)))))
                (vla-Delete (MakeX temp1))
                (vla-Delete (MakeX temp2))
                (if (setq ss (ssget '((0 . "TEXT,ATTDEF"))))
                        (setq TxtList (tmw:ss->Objlist ss))
                        (setq TxtList
                            (vl-sort
                                TxtList
                                '(lambda (a b)
                                        (cadr (tmw:Var->Safe (vla-get-InsertionPoint a)))
                                        (cadr (tmw:Var->Safe (vla-get-InsertionPoint b)))
                        (foreach item TxtList
                            (setq InsPt (list (car InsPt) (- (cadr InsPt) Dis1) (caddr InsPt)))
                            (setq NewInsPt (vlax-3d-point InsPt))
                            (if (= (vla-get-Alignment item) 0)
                                (vla-put-InsertionPoint item NewInsPt)
                                (vla-put-TextAlignmentPoint item NewInsPt)
    (setvar "cmdecho" ocmd)
    (if Ent
            (redraw (car Ent) 4)
            (vla-put-Height StyObj DftHt)
            (vla-put-ActiveTextStyle ActDoc CurSty)
    (vlax-invoke-method ActDoc 'EndUndoMark)
(defun MakeX (entname)
(vlax-ename->vla-object entname)
(defun tmw:ss->Objlist (ss / RtnList temp1)
(while (setq temp1 (ssname ss 0))
(setq RtnList (cons (vlax-ename->vla-object temp1) RtnList))
(ssdel temp1 ss)
RtnList
(defun tmw:Var->Safe (VariantValue /)
(if (= (type VariantValue) 'variant)
(safearray-value (variant-value VariantValue))
(defun VALUE (num ent /)
(cdr (assoc num ent))
Krushert
« Reply #10 on: October 12, 2009, 01:59:18 PM »
And I will give that one a try too.
« Reply #11 on: October 13, 2009, 07:21:09 AM »
Still haven't got internet at home yet, but got some time to upload the code I have so far  ;-) - see the first post  :-)
Bug reports/Criticism/Comments are of course welcome.
Enjoy,
Lee
Andrea
« Reply #12 on: October 13, 2009, 02:17:40 PM »
Nice one Lee...!!
your Idea concept is cool !   :ugly:
Keep Lispin !
Keep smile...
Andrea
« Reply #13 on: October 13, 2009, 02:47:14 PM »
maybe you can add something like...a rotation ?
[color=grey]
  (setq bPt (vlax-get obj prop))
                       (if (setq iPt (inters pt data (polar bPt *tx 1) bPt nil))
                         (vlax-put Obj prop iPt))[/color]
[color=blue]
        (if (and (findfile "AcetUtil.arx") not acet-sys-shift-down)
          (arxload (findfile "AcetUtil.arx"))
        (if (acet-sys-shift-down)
          (vla-put-rotation obj (+ (angle pt data) 1.5708))
[/color]
[color=grey] ) t)
                  (  (= 2 code)
                     (cond  (  (= 13 data) nil)
                            (  (= 32 data) nil)[/color]
Keep smile...
Hugo
« Reply #14 on: October 13, 2009, 03:12:03 PM »
Hallo Lee
ein fester Winkel mit 90 oder 0 Grad wäre auch toll.
Danke
