I have a user that has sent me some data that we will be reviewing together in the AM.
To the point, the attached image shows the results of the Intersection Wizard performing a FAIL at using the user specified
Offset Alignments.
To be clear, the user has created and is using their own Offset alignment(s) for the Left and Right Edge of pavement,
however the Wizard fails to assign those alignments to the corridor regions. Yes it makes the regions for the intersection correctly, and one can then edit the regions and attach the correct alignments and rebuilding the corridor 'fixes' the failed offset alignment assignments. I take this to indicate that his assembly is correcct, or the lane edge would not follow the offset alignment after editing the region(s)
Can anyone else verify that the New tool is indeed this badly broken?
Also it seems that one can also NOT assign user defined curb return alignments, and or profiles during the intersection wizard process? This seems to be a couple of interesting defects if the functions are as described.
