Author Topic: (Challenge) Create a barcode generator  (Read 8901 times)
  • Custom Title
« on: October 08, 2009, 08:21:20 AM »
Using PLINES create a barcode generator.
http://en.wikipedia.org/wiki/Code_128
Good luck!! 8-)
Re: (Challenge) Create a barcode generator
« Reply #1 on: October 08, 2009, 09:06:46 AM »
Interesting read Mark.
Thanks 8-)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #2 on: October 08, 2009, 10:09:34 AM »
Good luck!! 8-)
Hello Mark! :)
You wished to tell, code in the width lwpolyline?
The program should make a columns of vertical polylines of different width?
« Reply #3 on: October 08, 2009, 10:13:32 AM »
I found this interesting too. Although not the 128 code still a good read.
http://www.barcodeisland.com/code39.phtml
« Reply #4 on: October 08, 2009, 10:16:33 AM »
This will give you an idea of options needing to be addressed.
http://www.morovia.com/free-online-barcode-generator/
  • Custom Title
« Reply #5 on: October 08, 2009, 10:45:12 AM »
Good luck!! 8-)
Hello Mark! :)
Yes, to both questions.
TimSpangler
  • CAD Naked!!
« Reply #6 on: October 08, 2009, 11:10:08 AM »
Well I played with this long enough. I actually have work to do this morning
****NOT FULLY TESTED***
;;;    BARCODE.LSP
;;;    Copyright © October, 2009
;;;    Timothy G. Spangler
;;;    Permission to use, copy, modify, and distribute this software
;;;    for any purpose and without fee is hereby granted, provided
;;;    that the above copyright notice appears in all copies and
;;;    that both that copyright notice and the limited warranty and
;;;    restricted rights notice below appear in all supporting
;;;    documentation.
;;; Description:
;;; Creates a barcode from a piece of text
(defun C:BARCODE (/ BarCodeText BarCodeList BarList TextLength Counter Char Bar OldLunits)
;; Set units to decimal
(setq OldLunits (getvar "LUNITS"))
(setvar "LUNITS" 2)
;; Get string to barcode
(if (= "" (setq BarCodeText (getstring "\n Enter text to barcode:<TEST>")))
(setq BarCodeText "TEST")
;; Set the barcode list 128B
(setq BarCodeList
(list
(cons "" 212222 )(cons "!" 222122)(cons "\"" 222221)(cons "#" 121223)
(cons "$" 121322)(cons "%" 131222)(cons "&" 122213)(cons "\'" 122312)
(cons "\(" 132212)(cons "\)" 221213)(cons "*" 221312)(cons "\+" 231212)
(cons "\," 112232)(cons "\-" 122132)(cons "\." 122231)(cons "\/" 113222)
(cons "0" 123122)(cons "1" 123221)(cons "2" 223211)(cons "3" 221132)
(cons "4" 221231)(cons "5" 213212)(cons "6" 223112)(cons "7" 312131)
(cons "8" 311222)(cons "9" 321122)(cons "\:" 321221)(cons "\;" 312212)
(cons "\<" 322112)(cons "\=" 322211)(cons "\>" 212123)(cons "\?" 212321)
(cons "@" 232121)(cons "A" 111323)(cons "B" 131123)(cons "C" 131321)
(cons "D" 112313)(cons "E" 132113)(cons "F" 132311)(cons "G" 211313)
(cons "H" 231113)(cons "I" 231311)(cons "J" 112133)(cons "K" 112331)
(cons "L" 132131)(cons "M" 113123)(cons "N" 113321)(cons "O" 133121)
(cons "P" 313121)(cons "Q" 211331)(cons "R" 231131)(cons "S" 213113)
(cons "T" 213311)(cons "U" 213131)(cons "V" 311123)(cons "W" 311321)
(cons "X" 331121)(cons "Y" 312113)(cons "Z" 312311)(cons "[" 332111)
(cons "\\" 314111)(cons "\]" 221411)(cons "^" 431111)(cons "_" 111224)
(cons "`" 111422)(cons "a" 121124)(cons "b" 121421)(cons "c" 141122)
(cons "d" 141221)(cons "e" 112214)(cons "f" 112412)(cons "g" 122114)
(cons "h" 122411)(cons "i" 142112)(cons "j" 142211)(cons "k" 241211)
(cons "l" 221114)(cons "m" 413111)(cons "n" 241112)(cons "o" 134111)
(cons "p" 111242)(cons "q" 121142)(cons "r" 121241)(cons "s" 114212)
(cons "t" 124112)(cons "u" 124211)(cons "v" 411212)(cons "w" 421112)
(cons "x" 421211)(cons "y" 212141)(cons "z" 214121)(cons "{" 412121)
(cons "|" 111143)(cons "}" 111341)(cons "~" 131141)
;; Start Barcode
(setq BarList (cons 211214 BarList))
;; Start Counter
(setq Counter 1)
;; Step throught text and create barcode list from it
(repeat (strlen BarCodeText)
(setq Char (substr BarCodeText Counter 1))
(setq Bar (cdr(assoc Char BarCodeList)))
(setq BarList (cons Bar BarList))
(setq Counter (1+ Counter))
;; End Barcode
(setq BarList (cons 2331112 BarList))
;; Reverse bar list
(setq BarList (reverse BarList))
;; Draw Bar
(DRAW_BAR BarList)
;; Reet units
(setvar "LUNITS" OldLunits)
;; Echo to the command line
(princ (strcat "\n Bar Code create for \"" BarCodeText "\""))
;; Quiet exit
(defun DRAW_BAR (BarList / StartPoint BarPoint Counter BarCodeGroup Loop DrawBar BarChr )
;; Define start pont for  barcode
(setq StartPoint (getpoint "\n Define starting point for barcode:"))
;; Start Counter
(setq Counter 0)
;; Step through barlist and draw barcodes
(repeat (length BarList)
;; Convert number to string
(setq BarCodeGroup (rtos (nth Counter BarList)2 0))
;; Start loop counter
(setq Loop 1)
;; Start with a bar
(setq DrawBar T)
;; Step through the bar code group
(repeat (strlen BarCodeGroup)
;; Break the bargroup down into bars
(setq BarChr (substr BarCodeGroup Loop 1))
;; Set the first point of charater
(setq BarPoint (polar StartPoint 0.0 (* 0.5 (atoi BarChr))))
(setq StartPoint (polar StartPoint 0.0 (atoi BarChr)))
;; Draw Bar
(if DrawBar
;; Draw the pline
(BAR_PLINE (list BarPoint (polar BarPoint (/ pi 2.0) 60.0)) (atoi BarChr))
;; Turn off draw bar
(setq DrawBar nil)
;; Turn on draw bar
(setq DrawBar T)
;; Add to the loop
(setq Loop (1+ Loop))
;; Add to the counter
;; Draw pline for bar code
(defun BAR_PLINE (PointList Width / Group10List PolyLineList)
(setq PolyLineList
(list
(cons 0 "LWPOLYLINE")
(cons 100 "AcDbEntity")
(cons 100 "AcDbPolyline")
(cons 6 "Continuous")
(cons 8 "0")
(cons 43 Width)
(cons 90 (length PointList))
(cons 70 0)
(setq Group10List (mapcar '(lambda (Coord) (cons 10 Coord)) PointList))
(setq PolyLineList (append PolyLineList Group10List))
(entmakex PolyLineList)
;;; Echos to the command line
(princ "\nBarCode v1.0© \n Timothy Spangler, \n  October, 2009....loaded.")
(print)
;;; End echo
*** Fixed Protected symbol error
« Last Edit: October 09, 2009, 07:48:03 AM by TimSpangler »
ACA 2015 - Windows 7 Pro
  • Custom Title
« Reply #7 on: October 08, 2009, 11:22:43 AM »
****NOT FULLY TESTED****
That is awesome Tim. 8-)
TimSpangler
  • CAD Naked!!
« Reply #8 on: October 08, 2009, 11:23:47 AM »
Just found that it only does single words, ie NO SPACES.
I will fix it later, after some other entries arrive   :evil:
Andrea
« Reply #9 on: October 08, 2009, 11:52:27 AM »
Hi Tim...Nice one !
I just found an protected function error..
....(/ BarCodeText BarCodeList BarList TextLength Counter Chr Bar OldLunits)
I have change the variable names.. and it work great.
« Last Edit: October 08, 2009, 12:00:35 PM by Andrea »
Keep smile...
TimSpangler
  • CAD Naked!!
« Reply #10 on: October 08, 2009, 12:02:05 PM »
Thanks Andrea,
Updated code above.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #11 on: October 08, 2009, 12:04:50 PM »
my version:
(defun c:barcod ( / A I L S X Y)
 ;; By ElpanovEvgeniy
 ;; barcod-128
 (setq l '((32 . 212222) (33 . 222122) (34 . 222221) (35 . 121223) (36 . 121322)
           (37 . 131222) (38 . 122213) (39 . 122312) (40 . 132212) (41 . 221213)
           (42 . 221312) (43 . 231212) (44 . 112232) (45 . 122132) (46 . 122231) (47 . 113222)
           (48 . 123122) (49 . 123221) (50 . 223211) (51 . 221132) (52 . 221231) (53 . 213212)
           (54 . 223112) (55 . 312131) (56 . 311222) (57 . 321122) (58 . 321221) (59 . 312212)
           (60 . 322112) (61 . 322211) (62 . 212123) (63 . 212321) (64 . 232121) (65 . 111323)
           (66 . 131123) (67 . 131321) (68 . 112313) (69 . 132113) (70 . 132311) (71 . 211313)
           (72 . 231113) (73 . 231311) (74 . 112133) (75 . 112331) (76 . 132131) (77 . 113123)
           (78 . 113321) (79 . 133121) (80 . 313121) (81 . 211331) (82 . 231131) (83 . 213113)
           (84 . 213311) (85 . 213131) (86 . 311123) (87 . 311321) (88 . 331121) (89 . 312113)
           (90 . 312311) (91 . 332111) (92 . 314111) (93 . 221411) (94 . 431111) (95 . 111224)
           (96 . 111422) (97 . 121124) (98 . 121421) (99 . 141122) (100 . 141221) (101 . 112214)
           (102 . 112412) (103 . 122114) (104 . 122411) (105 . 142112) (106 . 142211) (107 . 241211)
           (108 . 221114) (109 . 413111) (110 . 241112) (111 . 134111) (112 . 111242) (113 . 121142)
           (114 . 121241) (115 . 114212) (116 . 124112) (117 . 124211) (118 . 411212) (119 . 421112)
           (120 . 421211) (121 . 212141) (122 . 214121) (123 . 412121) (124 . 111143) (125 . 111341)
           (126 . 131141) (0 . 211214) (128 . 2331112))
       s (apply
          (function strcat)
          (cons (itoa (cdr (assoc 0 l)))
                (reverse (cons (itoa (cdr (assoc 128 l)))
                               (reverse (mapcar (function (lambda (a) (itoa (cdr (assoc a l)))))
                                                (vl-string->list (getstring "\n Enter text:\t"))
                                        ) ;_  mapcar
                               ) ;_  reverse
                         ) ;_  cons
                ) ;_  reverse
          ) ;_  cons
         ) ;_  apply
       y (getpoint "\n Start point")
       x (car y)
       y (cadr y)
       i nil
 ) ;_  setq
 (while (/= (setq a (substr s 1 1)) "")
  (if (setq a (atoi a)
            i (not i)
      ) ;_  setq
   (entmakex (list '(0 . "LWPOLYLINE")
                   '(100 . "AcDbEntity")
                   '(100 . "AcDbPolyline")
                   (cons 43 a)
                   '(90 . 2)
                   (list 10 (+ x (/ a 2.)) y)
                   (list 10 (+ x (/ a 2.)) (+ y 50))
             ) ;_  list
   ) ;_  entmakex
  ) ;_  if
  (setq x (+ a x)
        s (substr s 2)
  ) ;_  setq
 ) ;_  while
« Last Edit: October 08, 2009, 12:17:51 PM by ElpanovEvgeniy »
Andrea
« Reply #12 on: October 08, 2009, 12:20:54 PM »
well....nice ElpanovEvgeniy ..and Tim..
but we got diffrent result on start code..
Keep smile...
TimSpangler
  • CAD Naked!!
« Reply #13 on: October 08, 2009, 12:25:19 PM »
That is a differance in either 128A - Elpanov and 128B - Me
TimSpangler
  • CAD Naked!!
« Reply #14 on: October 08, 2009, 12:27:54 PM »
From the Wiki
128A - ASCII characters 00 to 95 (0-9, A-Z and control codes) and special characters
128B - ASCII characters 32 to 127 (0-9, A-Z, a-z) and special characters
128C - 00-99 (double density encoding of numeric only data) and FNC1
Andrea
« Reply #15 on: October 08, 2009, 12:32:10 PM »
oh ..I see..
thanks.
Now,..I'll try to make a barcode reader. (if (not (already done))....
Keep smile...
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #16 on: October 08, 2009, 03:17:07 PM »
It is my error!
I as used barcod-128b, but by mistake, the beginning code has put barcod-128a
The code has already been corrected, but you have written the answer earlier.
« Reply #17 on: October 08, 2009, 03:39:24 PM »
Here is my 128B with the check character.
Specification
A Code 128 barcode will have six sections:
    * Quiet Zone
    * Start Character
    * Encoded Data
    * Check Character
    * Stop Character
    * Quiet Zone
The check character is calculated from a weighted sum (modulo 103) of all the characters.
;;  CAB 10.08.09  Code 128B
(defun c:BarCode (/
                  str
                              ;BarWidthUnits
                              ;BarHeight
                  QuietZoneWidth
                  pt
  (and
    (setq str (getstring t "\nEnter text for Barcode: "))
    ;;  may need to trim leading & trailing spaces or tabs?
    (or BarWidthUnits
        (setq BarWidthUnits (getint "\nEnter Unit width for each one Bar: "))
    (or BarHeight (setq BarHeight (getdist "\nEnter Height of Barcode: ")))
    (setq QuietZoneWidth 0.25)
    (setq pt (getpoint "\nPick insert point, lower left."))
    (AddBarCode str BarWidthUnits BarHeight QuietZoneWidth pt)
(defun AddBarCode (str BarWidthUnits BarHeight QuietZoneWidth pt /
                   code letter codelist CheckDigitW CheckDigit BCdata idx )
  (setq BCdata
        '((" " 212222)("!" 222122)("\"" 222221)("#" 121223)("$" 121322)("%" 131222)("&" 122213)
          ("\'" 122312)("(" 132212)(")" 221213)("*" 221312)("+" 231212)("," 112232)("-" 122132)
          ("\." 122231)("/" 113222)("0" 123122)("1" 123221)("2" 223211)("3" 221132)("4" 221231)
          ("5" 213212)("6" 223112)("7" 312131)("8" 311222)("9" 321122)(":" 321221)(";" 312212)
          ("<" 322112)("=" 322211)(">" 212123)("?" 212321)("@" 232121)("A" 111323)("B" 131123)
          ("C" 131321)("D" 112313)("E" 132113)("F" 132311)("G" 211313)("H" 231113)("I" 231311)
          ("J" 112133)("K" 112331)("L" 132131)("M" 113123)("N" 113321)("O" 133121)("P" 313121)
          ("Q" 211331)("R" 231131)("S" 213113)("T" 213311)("U" 213131)("V" 311123)("W" 311321)
          ("X" 331121)("Y" 312113)("Z" 312311)("[" 332111)("\\" 314111)("]" 221411)("^" 431111)
          ("_" 111224)("`" 111422)("a" 121124)("b" 121421)("c" 141122)("d" 141221)("e" 112214)
          ("f" 112412)("g" 122114)("h" 122411)("i" 142112)("j" 142211)("k" 241211)("l" 221114)
          ("m" 413111)("n" 241112)("o" 134111)("p" 111242)("q" 121142)("r" 121241)("s" 114212)
          ("t" 124112)("u" 124211)("v" 411212)("w" 421112)("x" 421211)("y" 212141)("z" 214121)
          ("{" 412121)("|" 111143)("}" 111341)("~" 131141) (95 114113) (96 114311) (97 411113)
          (98  411311)(99  113141) (100 114131) (101 311141)(102 411131) ))
  (setq CodeList (mapcar (function(lambda(x)
                            (setq CheckDigitW (cons (vl-position (assoc (chr x) BCdata) BCData) CheckDigitW))
                            (cadr(assoc (chr x) BCdata)) )) (vl-string->list str)))
  (defun MakeBar (letter / width code BarFlag)
    (setq BarFlag t)
    (foreach code (vl-string->list (itoa Letter))
      (setq code  (atoi (chr code))
            width (* code BarWidthUnits))
      (if BarFlag
          (entmakex
                   (cons 43 width)
                   '(90 . 2)
                   (cons 10 (polar pt 0 (/ width 2.)))
                   (cons 10 (polar (polar pt 0 (/ width 2.)) (/ pi 2) BarHeight))
      (setq pt (polar pt 0 width)
            BarFlag (not BarFlag)
  (setq CheckDigitW (reverse CheckDigitW))
  (makebar 211214) ; Start 128B
  (setq CheckDigit 104)  ; Start 128B
  (setq idx 1)
  (foreach letter CodeList
     (makebar letter)
    (setq CheckDigit (+ CheckDigit (* idx (nth (1- idx) CheckDigitW))))
    (setq idx (1+ idx))
  (setq CheckDigit (rem CheckDigit 103))
  (makebar (cadr (nth CheckDigit BCdata)))  ; add the Check Character
  (makebar 2331112) ; Stop
<edit: bug in check character fixed, I think>
« Last Edit: October 09, 2009, 05:06:40 PM by CAB »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #18 on: October 09, 2009, 01:57:27 AM »
Gymnastics with a cup of morning coffee...  :-)
(defun c:b2 (/ A S X Y)
 ;; barcod-128-B
 (setq s '(212222    222122    222221    121223    121322    131222    122213    122312
           132212    221213    221312    231212    112232    122132    122231    113222
           123122    123221    223211    221132    221231    213212    223112    312131
           311222    321122    321221    312212    322112    322211    212123    212321
           232121    111323    131123    131321    112313    132113    132311    211313
           231113    231311    112133    112331    132131    113123    113321    133121
           313121    211331    231131    213113    213311    213131    311123    311321
           331121    312113    312311    332111    314111    221411    431111    111224
           111422    121124    121421    141122    141221    112214    112412    122114
           122411    142112    142211    241211    221114    413111    241112    134111
           111242    121142    121241    114212    124112    124211    411212    421112
           421211    212141    214121    412121    111143    111341    131141
       s (strcat "211214"
                 (apply (function strcat)
                        (mapcar (function (lambda (a) (itoa (nth (- a 32) s))))
                                (vl-string->list (getstring "\n Enter text:  "))
                        ) ;_  mapcar
                 ) ;_  apply
                 "2331112"
         ) ;_  strcat
       y (getpoint "\n Start point:  ")
       x (car y)
       y (cadr y)
 ) ;_  setq
 (repeat (1+ (/ (strlen s) 2))
  (if (setq a (atoi (substr s 1 1)))
                   (cons 43 a)
                   '(90 . 2)
             ) ;_  list
   ) ;_  entmakex
  ) ;_  if
  (setq x (+ a x (atoi (substr s 2 1)))
        s (substr s 3)
  ) ;_  setq
 ) ;_  repeat
« Last Edit: October 09, 2009, 02:14:22 AM by ElpanovEvgeniy »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #19 on: October 09, 2009, 03:25:55 AM »
Has added Check Digit Calculation
 ;; barcod-128-B
 ;; add check character
           421211    212141    214121    412121    111143    111341    131141    114113
           114311    411113    411311    113141    114131    311141    411131
       x 104
       y 0
       s (strcat "211214"
                        (mapcar (function (lambda (a / i)
                                           (setq i (if (< a 145)
                                                    32
                                                    145
                                                   ) ;_  if
                                                 y (1+ y)
                                                 x (+ x (* (- a i) y))
                                           ) ;_  setq
                                           (itoa (nth (- a i) s))
                                          ) ;_  lambda
                                ) ;_  function
                        ) ;_  mapcar
                 ) ;_  apply
                 (itoa (nth (rem x 103) s))
                 "2331112"
         ) ;_  strcat
       x (car y)
       y (cadr y)
 ) ;_  setq
                   (cons 43 a)
                   '(90 . 2)
             ) ;_  list
   ) ;_  entmakex
  ) ;_  if
        s (substr s 3)
  ) ;_  setq
 ) ;_  repeat
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #20 on: October 09, 2009, 04:02:56 AM »
In your code a bug.
It in check ' Check Digit Calculation.
The good help
« Reply #21 on: October 09, 2009, 09:24:55 AM »
Some amazing code Evgeniy. 8-)
As for the check character, I thought I followed this correctly but I'll go back a review my code.
Code 128
The  check character  calculation method  is described  in the  article Code128
Specification.  We assume  that you  want to  find the  check digits  of string
MRV9012. Here is how it works:
Step One: Start with the first character in the message, assign weight  starting
with 1. The start character also has a weight of 1. since the actual encoding is
(START-A)(M)(R)(V)(CODE-C)(90)(12), we have total  7 characters in the  message.
Move from the left to right, and increment the weight by one. The value of  each
character can be found here.
Index     N/A       1      2      3     4        5      6
character START-A   M      R      V     CODE-C   90     12
value     103       45     50     54    99       90     12
weight    1         1      2      3     4        5      6
Step Two: Multiply the character value by weight and add the results together. (103*1+45*1+50*2+54*3+99*4+90*5+12*6)=1328
Step Three: Divide the total result by 103; get the remainder: 1328 mod 103 = 92
Step Four: Reverse look up the Code128 encoding table; since the second part  is
encoded in character C, we should look up on the character C set. The result  is
character (92).
« Last Edit: October 09, 2009, 09:28:35 AM by CAB »
« Reply #22 on: October 09, 2009, 09:32:58 AM »
OK I think I found my mistake. Added where I should multiply & Multiplied where I should add.
More testing before I correct the code. 8-)
« Reply #23 on: October 09, 2009, 09:36:26 AM »
My code does not agree with you code.  :-o
I updated my code.
« Reply #24 on: October 09, 2009, 10:05:28 AM »
OK, found another error, code corrected.
Should never have doubted you. :oops:
I'd like to have some of that coffee you're drinking.  :-)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #25 on: October 09, 2009, 03:13:44 PM »
Main not quality, but quantity!
My size - 1.5 litres  :-)
For comparison, background - a disk dvd
VovKa
  • Ukraine
« Reply #26 on: October 09, 2009, 04:06:32 PM »
that could be the first doping scandal among programmers :)
« Reply #27 on: October 09, 2009, 04:16:53 PM »
Now that's a Man Size cup. :-)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #28 on: October 12, 2009, 07:02:09 AM »
Good luck!! 8-)
Hello, Mark! :)
Show your decision...
