Author Topic: region2pl  (Read 4741 times)
taner
region2pl
« on: October 05, 2009, 11:53:42 AM »
Dear all,
Can anyone write some codes to convert all kinds of regions to polylines?
Thanks in advance.
gile
  • Marseille, France
Re: region2pl
« Reply #1 on: October 05, 2009, 12:22:49 PM »
Hi
It is not possible to convert "all kind" of regions into polylines. Polylines have only lines and arcs.
Here's a routine which convert valid selected regions (which countains onlt lines and arcs) into polylines
;;; R2PL -Gilles Chanteau- 01/01/07
;;; Transforme les régions sélectionnées en polylignes.
(defun c:r2pl (/ *error* arcbugle acdoc space
ss n reg norm expl olst
blst dlst plst tlst blg pline
  (defun *error* (msg)
    (if (/= msg "Function cancelled")
      (princ (strcat "\nError: " msg))
    (vla-EndUndoMark
      (vla-get-ActiveDocument (vlax-get-acad-object))
  (defun arcbulge (arc)
    (/ (sin (/ (vla-get-TotalAngle arc) 4))
       (cos (/ (vla-get-TotalAngle arc) 4))
  (setq acdoc (vla-get-ActiveDocument (vlax-get-acad-object))
space (if (= 1 (getvar "CVPORT"))
  (vla-get-PaperSpace acdoc)
  (vla-get-ModelSpace acdoc)
  (if (ssget '((0 . "REGION")))
      (vla-StartUndoMark acdoc)
      (vlax-for reg (setq ss (vla-get-ActiveSelectionSet acdoc))
(setq norm (vlax-get reg 'Normal)
      expl (vlax-invoke reg 'Explode)
(if (vl-every '(lambda (x)
(or
   (= (vla-get-ObjectName x) "AcDbLine")
   (= (vla-get-ObjectName x) "AcDbArc")
      expl
    (vla-delete reg)
    (setq olst (mapcar '(lambda (x)
  (list x
(vlax-get x 'StartPoint)
(vlax-get x 'EndPoint)
       expl
    (while olst
      (setq blst nil)
      (if (= (vla-get-ObjectName (caar olst)) "AcDbArc")
(setq blst (list (cons 0 (arcbulge (caar olst)))))
      (setq plst (cdar olst)
    dlst (list (caar olst))
    olst (cdr olst)
      (while
(setq
  tlst
   (vl-member-if
     '(lambda (x)
(or (equal (last plst) (cadr x) 1e-9)
    (equal (last plst) (caddr x) 1e-9)
     olst
(if (equal (last plst) (caddar tlst) 1e-9)
   (setq blg -1)
   (setq blg 1)
   (= (vla-get-ObjectName (caar tlst)) "AcDbArc")
    (setq
      blst
       (cons (cons (1- (length plst))
   (* blg (arcbulge (caar tlst)))
     blst
(setq plst (append plst
    (if (minusp blg)
      (list (cadar tlst))
      (list (caddar tlst))
       dlst (cons (caar tlst) dlst)
       olst (vl-remove (car tlst) olst)
      (setq pline
     (vlax-invoke
       Space
       'addLightWeightPolyline
       (apply 'append
(setq x (trans x 0 Norm))
(list (car x) (cadr x))
      (reverse (cdr (reverse plst)))
      (vla-put-Closed pline :vlax-true)
      (mapcar
'(lambda (x) (vla-setBulge pline (car x) (cdr x)))
blst
      (vla-put-Elevation
pline
(caddr (trans (car plst) 0 Norm))
      (vla-put-Normal pline (vlax-3d-point Norm))
      (mapcar 'vla-delete dlst)
  (mapcar 'vla-delete expl)
      (vla-delete ss)
      (vla-EndUndoMark acdoc)
« Last Edit: October 05, 2009, 12:30:12 PM by gile »
taner
Re: region2pl
« Reply #2 on: October 05, 2009, 08:22:05 PM »
Hi
Thanks very much Sir.
Beekee
  • Mosquito
Re: region2pl
« Reply #3 on: June 26, 2016, 03:43:32 PM »
Hello, I would like to use this routine as sub-function...
I have my routine in LISP and I need to convert a regular selection set of regions to polylines. I can't figure out how to adjust this (vlax-for reg (setq ss (vla-get-ActiveSelectionSet acdoc)) loop... to use my selection set (created by (ssadd)). I tried to add (sssetfirst nil sel) before, but you know, it did not work...
Thanks in advance.
gile
  • Marseille, France
Re: region2pl
« Reply #4 on: June 27, 2016, 01:04:44 AM »
Hi
Replace:
with:
  1. (repeat (setq i (sslength sel))
  2.   (setq reg (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
and remove:
This should do the trick (not tested).
lamarn
Re: region2pl
« Reply #5 on: June 27, 2016, 05:18:55 AM »
Edit: It works!
Design is something you should do with both hands. My 2d hand , my 3d hand ..
Beekee
  • Mosquito
Re: region2pl
« Reply #6 on: June 27, 2016, 10:32:33 AM »
Hi and thank you, gile! It works nicely!
(just for the record... ss and sel should be the same.. )
Hi
Replace:
with:
  2.   (setq reg (vlax-ename->vla-object (ssname sel (setq i (1- i)))))
and remove:
dexus
Re: region2pl
« Reply #7 on: July 14, 2023, 05:11:15 AM »
I was looking for a function to convert regions into polylines.
The ones that use PEDIT do not work on regions that are perpendicular to the UCS.
I made one myself but it was a lot slower than this one. If only I found this earlier, thanks for sharing gile!
This one didn't work on combined regions like when you use "Union" on two regions that are not connected.
So I made a modification for that and thought I would share it back to the community.
Here is the function:
  1. ;;-----------------------------------;;
  2. ;; region->polyline                  ;;
  3. ;;-----------------------------------;;
  4. ;; Gilles Chanteau - 01/01/07        ;;
  5. ;; Small changes by dexus - 14/07/23 ;;
  6. ;;-----------------------------------;;
  7. (defun region->polyline (ent / n reg norm expl olst blst dlst plst tlst blg space pline prop _arcbulge)
  8.   (defun _arcbulge (arc)
  9.     (/
  10.       (sin (/ (vla-get-TotalAngle arc) 4))
  11.       (cos (/ (vla-get-TotalAngle arc) 4))
  12.     )
  13.   )
  14.   (if
  15.     (and
  16.       (setq reg (cond ((= (type ent) 'vla-object) ent) ((= (type ent) 'ename) (vlax-ename->vla-object ent))))
  17.       (= (vla-get-ObjectName reg) "AcDbRegion")
  18.     )
  19.     (progn
  20.       (setq prop (mapcar (function (lambda (p) (vlax-get reg p))) '(Layer LineType Color))
  21.             norm (vlax-get reg 'Normal)
  22.             expl (vlax-invoke reg 'Explode)
  23.             space (vlax-get (LM:acdoc) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace)))
  24.       (cond
  25.         ((vl-every (function (lambda (x) (or (= (vla-get-ObjectName x) "AcDbLine") (= (vla-get-ObjectName x) "AcDbArc")))) expl)
  26.           (vla-delete reg)
  27.           (setq olst (mapcar (function (lambda (x) (list x (vlax-get x 'StartPoint) (vlax-get x 'EndPoint)))) expl))
  28.           (while olst
  29.             (setq blst nil)
  30.             (if (= (vla-get-ObjectName (caar olst)) "AcDbArc")
  31.               (setq blst (list (cons 0 (_arcbulge (caar olst)))))
  32.             )
  33.             (setq plst (cdar olst)
  34.                   dlst (list (caar olst))
  35.                   olst (cdr olst))
  36.             (while (setq tlst (vl-member-if (function (lambda (x) (or (equal (last plst) (cadr x) 1e-9) (equal (last plst) (caddr x) 1e-9)))) olst))
  37.               (if (equal (last plst) (caddar tlst) 1e-9)
  38.                 (setq blg -1)
  39.                 (setq blg 1)
  40.               )
  41.               (if (= (vla-get-ObjectName (caar tlst)) "AcDbArc")
  42.                 (setq blst (cons (cons (1- (length plst)) (* blg (_arcbulge (caar tlst)))) blst))
  43.               )
  44.               (setq plst
  45.                       (append plst
  46.                         (if (minusp blg)
  47.                           (list (cadar tlst))
  48.                           (list (caddar tlst))
  49.                         )
  50.                       )
  51.                     dlst (cons (caar tlst) dlst)
  52.                     olst (vl-remove (car tlst) olst))
  53.             )
  54.             (setq pline (vlax-invoke space 'addLightWeightPolyline (apply 'append (mapcar (function (lambda (x) (setq x (trans x 0 Norm)) (list (car x) (cadr x)))) (reverse (cdr (reverse plst)))))))
  55.             (vla-put-Closed pline :vlax-true)
  56.             (mapcar (function (lambda (x) (vla-setBulge pline (car x) (cdr x)))) blst)
  57.             (vla-put-Elevation pline (caddr (trans (car plst) 0 Norm)))
  58.             (vla-put-Normal pline (vlax-3d-point Norm))
  59.             (mapcar (function (lambda (p v) (vlax-put pline p v))) '(Layer LineType Color) prop)
  60.             (mapcar 'vla-delete dlst)
  61.           )
  62.           (if pline (list pline))
  63.         )
  64.         ((vl-every (function (lambda (x) (= (vla-get-ObjectName x) "AcDbRegion"))) expl)
  65.           (vla-delete reg)
  66.           (apply 'append (mapcar 'region->polyline expl))
  67.         )
  68.         ((mapcar 'vla-delete dlst))
  69.       )
  70.     )
  71.   )
  72. )
Could be used like this:
  1. ;; Active Document - Lee Mac
  2. ;; Returns the VLA Active Document Object
  3. (defun LM:acdoc nil
  4.   (LM:acdoc)
  5. )
  6.
  7. ;; SelectionSet -> VLA Objects - by Lee Mac
  8. (defun LM:ss->vla ( ss / i l )
  9.   (if ss
  10.     (repeat (setq i (sslength ss))
  11.       (setq l (cons (vlax-ename->vla-object (ssname ss (setq i (1- i)))) l))
  12.     )
  13.   )
  14. )
  15.
  16. (defun c:r2pl nil
  17.   (mapcar 'region->polyline (lm:ss->vla (ssget '((0 . "REGION")))))
  18.   (princ)
  19. )
« Last Edit: July 17, 2023, 02:32:10 AM by dexus »
ribarm
  • Marko Ribar, architect
Re: region2pl
« Reply #8 on: July 14, 2023, 10:16:11 AM »
@dexus,
I've found some lacks in your posted code, so I corrected them...
I hope that now it should perform well...
  1. (defun c:r2pl ( / LM:ss->vla LM:acdoc region->polyline )
  2.
  3.   ;; SelectionSet -> VLA Objects - by Lee Mac
  4.   (defun LM:ss->vla ( ss / i l )
  5.     (if ss
  6.       (repeat (setq i (sslength ss))
  7.         (setq l (cons (vlax-ename->vla-object (ssname ss (setq i (1- i)))) l))
  8.       )
  9.     )
  10.   )
  11.
  12.   ;; Active Document  -  Lee Mac
  13.   ;; Returns the VLA Active Document Object
  14.
  15.   (defun LM:acdoc nil
  16.     (LM:acdoc)
  17.   )
  18.
  19.   ;;-----------------------------------;;
  20.   ;; region->polyline                  ;;
  21.   ;;-----------------------------------;;
  22.   ;; Gilles Chanteau - 01/01/07        ;;
  23.   ;; Small changes by dexus - 14/07/23 ;;
  24.   ;;-----------------------------------;;
  25.   (defun region->polyline (ent / n reg norm expl olst blst dlst plst tlst blg space pline prop alst mlst mp pos _arcbulge)
  26.     (defun _arcbulge (arc)
  27.       (/
  28.         (sin (/ (vla-get-TotalAngle arc) 4))
  29.         (cos (/ (vla-get-TotalAngle arc) 4))
  30.       )
  31.     )
  32.     (if
  33.       (and
  34.         (setq reg (cond ((= (type ent) 'vla-object) ent) ((= (type ent) 'ename) (vlax-ename->vla-object ent))))
  35.         (= (vla-get-ObjectName reg) "AcDbRegion")
  36.       )
  37.       (progn
  38.         (setq prop (mapcar (function (lambda (p) (vlax-get reg p))) '(Layer LineType Color))
  39.               norm (vlax-get reg 'Normal)
  40.               expl (vlax-invoke reg 'Explode)
  41.               space (vlax-get (LM:acdoc) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace)))
  42.         (cond
  43.           ((vl-every (function (lambda (x) (or (= (vla-get-ObjectName x) "AcDbLine") (= (vla-get-ObjectName x) "AcDbArc")))) expl)
  44.             (vla-delete reg)
  45.             (setq olst (mapcar (function (lambda (x) (list x (vlax-get x 'StartPoint) (vlax-get x 'EndPoint)))) expl))
  46.             (while olst
  47.               (setq blst nil)
  48.               (if (= (vla-get-ObjectName (caar olst)) "AcDbArc")
  49.                 (setq blst (list (cons 0 (_arcbulge (caar olst)))))
  50.               )
  51.               (setq plst (cdar olst)
  52.                     dlst (list (caar olst))
  53.                     olst (cdr olst))
  54.               (while (setq tlst (vl-member-if (function (lambda (x) (or (equal (last plst) (cadr x) 1e-9) (equal (last plst) (caddr x) 1e-9)))) olst))
  55.                 (if (equal (last plst) (caddar tlst) 1e-9)
  56.                   (setq blg -1)
  57.                   (setq blg 1)
  58.                 )
  59.                 (if (= (vla-get-ObjectName (caar tlst)) "AcDbArc")
  60.                   (setq blst (cons (cons (1- (length plst)) (* blg (_arcbulge (caar tlst)))) blst))
  61.                 )
  62.                 (setq plst
  63.                         (append plst
  64.                           (if (minusp blg)
  65.                             (list (cadar tlst))
  66.                             (list (caddar tlst))
  67.                           )
  68.                         )
  69.                       dlst (cons (caar tlst) dlst)
  70.                       olst (vl-remove (car tlst) olst))
  71.               )
  72.               (setq pline (vlax-invoke space 'addLightWeightPolyline (apply 'append (mapcar (function (lambda (x) (setq x (trans x 0 Norm)) (list (car x) (cadr x)))) (reverse (cdr (reverse plst)))))))
  73.               (vla-put-Closed pline :vlax-true)
  74.               (vla-put-Elevation pline (caddr (trans (car plst) 0 Norm)))
  75.               (vla-put-Normal pline (vlax-3d-point Norm))
  76.               (setq alst (vl-remove-if-not (function (lambda (x) (= (vla-get-ObjectName x) "AcDbArc"))) dlst))
  77.               (setq mlst (mapcar (function (lambda (x) (vlax-curve-GetPointAtParam x (/ (+ (vlax-curve-GetStartParam x) (vlax-curve-GetEndParam x)) 2.0)))) alst))
  78.               (mapcar (function (lambda (x) (vla-setBulge pline (car x) (cdr x)))) blst)
  79.               (while (setq mp (vl-some (function (lambda (x) (if (not (vlax-curve-GetParamAtPoint pline x)) x))) mlst))
  80.                 (setq pos (vl-position mp mlst))
  81.                 (vla-SetBulge pline (car (nth pos blst)) (- (cdr (nth pos blst))))
  82.                 (setq mp nil)
  83.               )
  84.               (mapcar (function (lambda (p v) (vlax-put pline p v))) '(Layer LineType Color) prop)
  85.               (mapcar 'vla-delete dlst)
  86.             )
  87.             (if pline (list pline))
  88.           )
  89.           ((vl-every (function (lambda (x) (= (vla-get-ObjectName x) "AcDbRegion"))) expl)
  90.             (vla-delete reg)
  91.             (apply 'append (mapcar 'region->polyline expl))
  92.           )
  93.           ((mapcar 'vla-delete dlst))
  94.         )
  95.       )
  96.     )
  97.   )
  98.
  99.   (mapcar 'region->polyline (lm:ss->vla (ssget "_:L" '((0 . "REGION")))))
  100.   (princ)
  101. )
  102.
Regards, M.R.
M.R. on Youtube
ScottMC
Re: region2pl
« Reply #9 on: July 14, 2023, 11:13:32 PM »
Boundary [selective]?
dexus
Re: region2pl
« Reply #10 on: July 17, 2023, 03:20:49 AM »
@dexus,
  2.
  5.     (if ss
  8.       )
  9.     )
  10.   )
  11.
  14.
  16.     (LM:acdoc)
  17.   )
  18.
  27.       (/
  30.       )
  31.     )
  32.     (if
  33.       (and
  36.       )
  37.       (progn
  42.         (cond
  46.             (while olst
  47.               (setq blst nil)
  50.               )
  56.                   (setq blg -1)
  57.                   (setq blg 1)
  58.                 )
  61.                 )
  62.                 (setq plst
  63.                         (append plst
  67.                           )
  68.                         )
  71.               )
  82.                 (setq mp nil)
  83.               )
  86.             )
  88.           )
  92.           )
  94.         )
  95.       )
  96.     )
  97.   )
  98.
  100.   (princ)
  101. )
  102.
Regards, M.R.
Thanks for the addition Marko.
Could you explain what the change does?
As far as I can tell you get all the midpoints of arcs, and if they do not exist on the polyline you try flip the bulge.
Edit: The while loop sets mp to the output of vl-some. Which will return T or Nil.
Then tries to find the vl-position of T, which will not exist in mlst returning Nil.
And Nil is not a valid argument for nth.
So when it does find a arc that is flipped the wrong way, it will return a bad argument type error.
« Last Edit: July 17, 2023, 03:58:07 AM by dexus »
dexus
Re: region2pl
« Reply #11 on: July 17, 2023, 03:55:00 AM »
I'm not sure if I'm not using the boundary function incorrectly, but I cant seem to get it to work when the lines are not flat on the ucs.
ribarm
Re: region2pl
« Reply #12 on: July 17, 2023, 07:53:39 AM »
So when it does find a arc that is flipped the wrong way, it'll flip it with negative bulge right way...
M.R. on Youtube
dexus
Re: region2pl
« Reply #13 on: July 17, 2023, 09:11:10 AM »
How does it know which one?
It does find the arc, but then it saves True to the mp variable.
Because vl-some doesn't return the variable from the lambda function, it only returns True or Nil.
Which doesn't have a position in mlst, therefore it doesn't know which one to flip.
Am I missing something here?
ribarm
Re: region2pl
« Reply #14 on: July 17, 2023, 09:24:13 AM »
Yes, you are missing the fact that (vl-some) not always return T or nil... In our particular case it returns variable mp which is mid point of exploded arc...
So if polyline at some position where is placed arc don't have parameter at mp - meaning that exploded arc don't pass - overlap with pline, at that position bulge should be negative from that that was calculated through (_arcbulge) sub...
M.R. on Youtube
