Author Topic: divide minus intermediates  (Read 13053 times)
« Reply #15 on: November 21, 2003, 09:38:45 AM »
dan,
Anything can be done given enough Time and MONEY. :D
Here is the Draw Line code commented.
As per your request, I'll need another picture :)  (eliminates so much ambiguity)
  ;; draw the Mulls
  (repeat (1- paneCnt)
    (setq MullPt (polar mullPt 0 paneWidth))
    ;; draw left outer vertical line
    (command "_line" mullPt (polar mullPt up mullHt) "")
    ;;Draw the left inner vertical line offset .75" to right
    (command "_line"
    (polar mullPt 0 0.75)
    (polar (polar mullPt 0 0.75) up mullHt)
    ;;  move the pointer right by the mullion width
    (setq mullPt (polar mullPt 0 mullWidth))
    ;; draw the right outer vertical line
    ;;  draw the right inner vertical line offset .75 to left
    (command "_line"
    (polar mullPt left 0.75)
    (polar (polar mullPt left 0.75) up mullHt)
  ) ; end repeat
ELOQUINTET
« Reply #16 on: November 21, 2003, 10:36:29 AM »
cab not sure what this code is for. the mull code does exactly what i want for that canopy. i was wondering if something similar could be done for a glass wall. i'll upload a drawing to the pond shortly showing what i mean. thanks
dan
« Reply #17 on: November 21, 2003, 10:40:57 AM »
Dan, what are you loking for? Are you just looking for someone to create an application for you or are you trying to complete this application your self?
ELOQUINTET
« Reply #18 on: November 21, 2003, 10:53:00 AM »
ok it's uploaded to the pond. i'm trying to do something similar to the mull lisp. say i was given the overall size. i would like to be able to pick one corner then the opposite and number of panes. then it would divide the glass into equals and trim in between the panes like shown here. se7en i'm trying to pick this stuff up little by little and understand parts of the codes you guys have written for me. i would like to take a class or maybe really study some of the tutorials here but unfortunately i don't have much free time. i have downloaded the lisp bible from dsxcad but haven't had time yet to delve into it to much. i'm trying to learn believe me if i didn't want to know how to do this i wouldn't be here.
dan
« Reply #19 on: November 21, 2003, 10:59:17 AM »
Ok.
« Reply #20 on: November 30, 2003, 03:10:37 PM »
Dan,
Gap between panes is hard coded at 1/8 inch.
(defun C:Pane (/ p1 p2 x1 x2 y1 y2 Pa Pb wWidth PaneHt PLL
      paneCnt PaneWidth paneWidth PanePt Up left
      Gap usercmd useros)
  (setvar "CMDECHO" 0)
  (setq useros (getvar "osmode"))
  (setvar "osmode" 175)
  (Setq Up   (* pi 0.5)
left pi
  (setq p1     (getpoint "\nPick glass corner")
p2     (getpoint p1 "\nPick diaganal glass corner")
x1     (car p1)
x2     (car p2)
y1     (cadr p1)
y2     (cadr p2)
Pa     (list x1 y2)
Pb     (list x2 y1)
wWidth (distance p1 pb) ; window width
PaneHt (distance p1 pa) ; window Hight
PLL    (list (if (< x1 x2)x1 x2) ; PLL point Lower Left corner
(if (< y1 y2) y1 y2)
  (initget 7)
  (setq paneCnt (getint "\nEnter number of panes.  "))
  (initget 7)
  (setq Gap 0.128) ; preset at 1/8 inch
  (setq paneWidth (/ (- wWidth (* (1- paneCnt) Gap)) paneCnt)
PanePt  PLL
  (setvar "osmode" 0)
  (command "undo" "begin")
  ;; draw the Glass Panes
  (repeat  paneCnt
    (command "_rectang" PanePt (strcat "@" (rtos PaneWidth 2) "," (rtos PaneHt 2)))
    (setq PanePt (polar PanePt 0 (+ PaneWidth Gap)))
  ) ; end repeat
;;;==========  Exit Sequence  ============
  (command "undo" "end")
  (setvar "osmode" useros)
  (setvar "CMDECHO" usercmd)
;;; Exit quietly
) ; end defun
(prompt "\nWindow Pane routine loaded. Enter Pane to run")
ELOQUINTET
« Reply #21 on: December 01, 2003, 08:11:11 AM »
thanks cab works great exactly what the doctor ordered. preesh
dan
ELOQUINTET
« Reply #22 on: December 01, 2003, 08:44:46 AM »
hey cab i overlooked something. is there a way to make it subtract an 1/8 from each end before it divides it into equal panes so you have caulk joints at the ends as well. thanks man
dan
« Reply #23 on: December 01, 2003, 12:28:16 PM »
dan,
      Gap usercmd useros)
  (Setq Up   (* pi 0.5)
left pi
  (setq p1     (getpoint "\nPick glass frame corner")
x1     (car p1)
x2     (car p2)
y1     (cadr p1)
y2     (cadr p2)
Pa     (list x1 y2)
Pb     (list x2 y1)
  (initget 7)
  (initget 7)
  (setq paneWidth (/ (- wWidth (* (1+ paneCnt) Gap)) paneCnt)
PanePt  (polar PLL 0 gap)
  (setvar "osmode" 0)
  (repeat  paneCnt
  ) ; end repeat
;;; Exit quietly
) ; end defun
ELOQUINTET
« Reply #24 on: December 01, 2003, 12:46:28 PM »
hmmm how is this one different from the last post? i tried it and it didn't do what i wanted which is to give me an 1/8 gap on each vertical end. so based on the glass size i pick it would offset in an 1/8 each side then divide that distance equally. do you get what i'm sayin? thanks for trying though  :D
dan
« Reply #25 on: December 01, 2003, 01:04:36 PM »
I think i get what you are saying. :shock:
These lines are differant:
Did you try the code?
Did you zoom in on the left and right margins?
Did you not see a 1/8" gap?
 :roll: CAB :roll:
ELOQUINTET
« Reply #26 on: December 01, 2003, 01:14:00 PM »
ok it's cool now. i thought i had overwritten the old one with the new but i hadn't it works great now thank ya thank ya kind sir
dan
