Author Topic: Offset Existing Surface Profile  (Read 19886 times)
Willie
  • Going nowhere slowly
« on: September 30, 2009, 09:40:06 PM »
Is it possible to offset an existing surface profile?  I think my method is not the correct way of doing it.
This is what I am doing now.
1.  Explode profile view with the existing surface profile in it.
2.  Copy the explode profile view with the existing profile that I would like to offset.
3.  Undo to get the profile view back.
4.  Paste the copied profile view and explode the blocks.
5.  Create a polyline from exploded profile.
6.  Superimpose the polyline profile unto the profile view and move it to the required height.
My question:
Is there not a better way to offset existing surface profiles is Civil 3D?
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8  64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
jugglerbri
Re: Offset Existing Surface Profile
« Reply #1 on: September 30, 2009, 11:50:00 PM »
Yup, change the profiles update status to static and move it.  Check out the video.
http://screencast.com/t/SaZ8Kffq
Willie
« Reply #2 on: October 01, 2009, 12:20:07 AM »
Cool!!!
Thanks for that!!!
« Reply #3 on: October 01, 2009, 08:54:45 AM »
Willie,
it think you would be happier with the 'easy way' to offset a(n) existing ground profile
Export the alignment and Profile using XML
Edit the XML file, change the alignment and profile name, and the profile type (LAYOUT)
then reimport and raise or lower at will...
or you can strip out ONLY the profile information from that Exported XML file (save it as TXT), and then use the Create Profile From File option, and then raise or lower the resultant
I do this as I would rather NOT sample my exisitng ground twice, and I do not want one of those resultant profiles to be Static for any purpose.  It would be too easy to forget the need to update the static ones; and then folks would think something was wrong with the data.
« Last Edit: October 01, 2009, 09:10:47 AM by mjfarrell »
« Reply #4 on: October 01, 2009, 09:22:24 AM »
also Willie, may I ask why you are doing this?
because there is probably another way
« Reply #5 on: October 01, 2009, 09:51:56 AM »
What I find interesting is that you accept the DEFECT in the application that will NOT allow the user to define the profile as STATIC at the time it is sampled (created).
Willie
« Reply #6 on: October 02, 2009, 01:51:16 AM »
I am dong a widening on a road and the widening is to go between 1.5% and 4.5% below the profile on the edge of the bitumen. The road is in a residential area.
This is what I do.
1.  Create a alignment and profile on the saw joint where the bitumen is going the be cut and the widening is going to start.
2.  Then I create two profiles below the saw joint profile.  One profile is 1.5% lower than the saw joint profile and the other is 4.5% lower.
3.  Then I create a new design profile between the 1.5% and 4.5% profiles.  The idea is to get a smooth kerb line, which is between the 1.5% and 4.5% grades.
4.  My assmebly then targets the new designed profile.
Willie
« Reply #7 on: October 02, 2009, 01:52:37 AM »
Willie,
Thanks Micheal.  I give it a shot.
ChristopherF
« Reply #8 on: October 02, 2009, 02:01:47 AM »
I find it interesting that people accept training from people who do NOT know all the capabilities of the program.  :-)
Check out the video: http://screencast.com/t/ncSskblnb0LU
« Reply #9 on: October 02, 2009, 09:51:59 AM »
Me too.....
I do know it's annoying that you can't Name the surface that is being sampled until after....perhaps that is what I was really hating on...
« Last Edit: October 02, 2009, 10:07:23 AM by mjfarrell »
butzers09silverado
« Reply #10 on: November 15, 2012, 01:52:48 PM »
i've attached an xml file, but i can't figure out what part i need, can somebody clip it out this first time so i can figure it out myself next time.  I want to make a profile from a file, i.e. text.  thanks
« Reply #11 on: November 15, 2012, 11:09:09 PM »
way down near the bottom of the XML file you will find the profile data.
take that and place it in space delimited file...
enderprime
« Reply #12 on: November 22, 2012, 10:39:23 AM »
Trying to write a custom command to solve this exact problem is how I stumbled into theswamp.. Without writing code though, the only real option we have is to <create profile from file..> since we can't create one from a polyline (thanks Autodesk). After some trial and error I figured out that the file needs to be *.txt with only 2 columns, station and elevation, separated by a space.
The easiest way to get this data is to run a <sta-elev> or <vPI> report on the profile you want to copy/offset (depending on your C3D version) and then dump it into a text file. Just keep in mind the station-elevation text file used to make the new profile should only include numeric values with no special formatting, so do a <find..replace> on the data you get from the report and remove any [ + ] or [ ' ] characters if needed.
The new profile will be static, and not dynamic, and this is because the new profile is not tied to any surface or other data source. But this is still a decent method because that station-elevation text file can be kicked to another user so he can do the same thing even though he may not have any of the same alignment or surface data in his drawings.
If you want to tackle this problem with code instead and streamline things a bit let me know, I couldn't rest until I solved it with LISP  :kewl:
« Reply #14 on: November 22, 2012, 01:15:29 PM »
If you 'solved' this with LISP, why do you not simply post the code for others to use right here?
Although there is a way to use a polyline, if I think about it one would need to draw that profile in a side view,
then use a MAP query to extract the coordinates of the vertices. (this is untested at this time)
