Author Topic: Mlisp vs Field ??  (Read 14439 times)
CHulse
Re: Mlisp vs Field ??
« Reply #30 on: October 03, 2009, 10:56:01 AM »
(length (layoutlist))
haha good example  :wink:
:) Thought you'd like that.
Ha Ha, where have I seen that one before?  :wink:
I can't wait to try this...  8-)
Did you see my solution. ;)
No, I hadn't. ...running to look now....
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
Andrea
« Reply #31 on: October 05, 2009, 06:32:10 PM »
ok...
there it is...
MLISP v.1.0
this is my first draft...
command: MLISP  <- create a MTEXT allowing LISP.
command: MLISPEDIT  <- edit MTEXT who have LISP inside.
by pressing ShiftKey...you can see the code inside without editing the MTEXT. :kewl:
need tester..
thanks.  :-)
Keep smile...
SteveK
« Reply #32 on: October 05, 2009, 07:05:40 PM »
Been waiting all week for this  :-) Pretty neat, thanks Andrea.
Aerdvark
« Reply #33 on: October 06, 2009, 02:02:14 AM »
Hi Andrea,
Funny to say, maybe even a little  :ugly: but I can not think of any use for this program.
It looks cool and I wonder how to apply it any time.
I'm following this threat so I am on it...
Andrea
« Reply #34 on: October 06, 2009, 08:31:14 AM »
no problem guys...
I'm just sharing the code to free my head a little bit.. :laugh:
Keep smile...
Sebb77
« Reply #35 on: October 06, 2009, 10:02:47 AM »
 :angel:  Really really nice Andrea.
Idea:  your program will be really useful to me, in order to code what shall be an "Auto-Updating Legend" , which i've been thinking about for a couple months.
I'll inform you on the development later down the road. Thanks!
keep lispin'
SteveK
« Reply #36 on: October 06, 2009, 10:09:30 PM »
I just think it is a clever tool, somethin different. And I'll be able to learn things from the code.
If I was to use it in projects it would need a function to update all mlisps instead of having to edit each one individually.
And having it for attributes would be very handy, but not sure if that's doable...
Andrea
« Reply #37 on: October 07, 2009, 09:20:59 AM »
Allready done..in test at the moment.. :roll:
Keep smile...
alanjt
  • Standby for witty remark...
« Reply #38 on: October 07, 2009, 12:27:30 PM »
Now we're talking. :)
Dropbox
Andrea
« Reply #39 on: October 07, 2009, 02:00:26 PM »
update 1
MLISP v.1.1
New Function:
MLISPUPDATE  <- allow to update existing MLISP entity
Command: mlispupdate
(S)elect Entity or (*) for All <*>: S
Select MTEXT entity...
or * to select all
Enjoy !
Keep smile...
SteveK
« Reply #40 on: October 07, 2009, 05:30:27 PM »
Great, thanks  :-)
mkweaver
« Reply #41 on: October 08, 2009, 12:13:24 AM »
Now that is cool!
I'm going to have to spend some time with this.
Thanks for sharing.
Aerdvark
« Reply #42 on: October 08, 2009, 01:58:13 AM »
No very often I felt so  :? for I really can't think of the use... I know, due to my lack of knowledge... :oops:
What you are trying to say with the last gif, is that a drawing list that can be updated if one of the titleblocks is modified?
ie.: the dwg itself contains 5 identical title blocks with 5 identical attribute tags.
The attribute values differ of course.
Can you put these values (like E001 E002 etc) in the mlisp?
If so, then YES I and many others will have great use for it!
Creating drawing list!
If you'd need a tester for that, I'm here!
Andrea
« Reply #43 on: October 08, 2009, 01:05:40 PM »
Absolutely...you can do what LISP can make.
In ObjectDBX you can retreive theses Values..
But for the Gif Exemble...I only take the DWG list drawing name in the curent folder.
YES !
Thanks...
If you have any experimental problem...please let me know.
Enjoy !
Keep smile...
