Author Topic: Upgraded Text 2 MText  (Read 22534 times)
« on: September 27, 2009, 02:20:28 PM »
Text-2-MText Upgraded
Version 2.0
Program will allow the user to amalgamate several separate DTEXT & MTEXT entities into a single MTEXT entity, with all formatting kept in tact.
Text will take on the layer of the first text entity chosen (as in the txt2mtxt.lsp), but will keep its colour if not set to BYLAYER.
There are two modes: "Same Line" "New Line", which can be switched by pressing space between selections.
Shift-Clicking on Text will keep the original Text in place, and pressing "u" between selections will undo the previous selections.
Example:
Your thoughts are welcome  :-)
Code updated to Version 2.0
Code available here.
« Last Edit: November 14, 2010, 08:09:46 PM by Lee Mac »
Re: Upgraded Text 2 MText
« Reply #1 on: September 27, 2009, 03:46:12 PM »
Interesting but no use for me in my environment.
« Reply #2 on: September 27, 2009, 04:16:08 PM »
I wasn't sure how many people really use the txt2mtxt function, I just thought I'd toy with the idea as it suddenly came to me when I was playing around with your new toy  :-)
« Reply #3 on: September 27, 2009, 05:50:34 PM »
I have updated the first post, you can switch modes by pressing space during text selection  :-)
Andrea
« Reply #4 on: September 27, 2009, 08:16:16 PM »
wow ! Lee !!  I can't beleive it..
That was one of my project list !! OMG..
But you did better than i was thinking of..
Nice one !!
Yes, Me and some user here are interested about it. this will be very useful here.
Thanks for sharing. :-)
Keep smile...
« Reply #5 on: September 28, 2009, 05:04:18 AM »
Nice one !!
I thought that might be coming... we seem to come up with the same ideas quite frequently...   :wink:
Thanks Andrea  :-)
mkweaver
« Reply #6 on: September 29, 2009, 07:23:41 AM »
Just a preview of what I am working on currently - wasn't sure if it was worth continuing with...
(snippage)
I can certainly use this.  Thanks for sharing!
Mike
Krushert
  • FREE BEER Tomorrow!!
« Reply #7 on: September 29, 2009, 11:51:14 AM »
Same here for me.  Thanks.
Two questions.
One; could this be made to work on MText as well as Dtext?   I have a bunch of users that places little pieces of Mtext (objects)  :pissed: instead of placing all of them in one Mtext object.  It would save the step of exploding the objects to Dtext.
And two; what format code are using for "hard character return"?   When viewed in properties pallet it shows up as squares instead of "\P".
« Reply #8 on: September 29, 2009, 01:59:10 PM »
(snippage)
Mike
Thanks Mike, not a problem  :-)
Two questions.
One: You should be able to use it to amalgamate MTEXT & DTEXT into a single MTEXT entity, with all the formatting in tact  :wink:
Two: I use "\n" for the new line, but I shall look into "\P" instead.
Thanks Mr Krush :-)
Matt__W
  • I like my water diluted.
« Reply #9 on: September 29, 2009, 02:06:38 PM »
*Matt runs off to Google "amalgamate"...*
Autodesk Expert Elite
Krushert
« Reply #10 on: September 29, 2009, 02:22:16 PM »
« Reply #11 on: September 29, 2009, 02:24:52 PM »
Krushert
« Reply #12 on: September 29, 2009, 02:43:18 PM »
Returns the following at the command line when I go to select the second Mtext Object when in "NewLine" Mode.
Command: T2M
Initializing...
ø¤º°`°º¤ø  Text2MText2.lsp ~ Copyright © by Lee McDonnell  ø¤º°`°º¤ø
   ~¤~              ...Type "T2M" to Invoke...                ~¤~
Select Text:
øø Current Mode: New Line øø; error: An error has occurred inside the *error*
functionAutomation Error. Object was erased
Command:
I tried to watch it and see where it was breaking with the debug tools but the vlisp editor is always whited out.
« Reply #13 on: September 29, 2009, 03:30:12 PM »
I shall investigate Krushert - thanks for the feedback mate  :wink:
« Reply #14 on: September 29, 2009, 03:43:17 PM »
Krushert,
I haven't been able to replicate your error when testing - but I have updated the code to make it slightly more robust - it may not fix the issue, but it should make the error more transparent.  :wink:
Lee
