Author Topic: :paragraph formatting  (Read 8897 times)
hmspe
« on: September 25, 2009, 09:55:02 AM »
I have an existing DCL box that I'm trying to add to.  The addition is optional, so I want to add text next to a textbox with instructions.  When I use :paragraph there's a lot of white space added to the end of the text_part labels which is changing the width of the overall dcl box.  I've been through afralisp and several other tutorials but find nothing related to this.  Width settings don't seem to help.  To see the original DCL box comment out the :boxed_column section that's about 30 lines from the end.  I've spent a couple of hours trying different things and I'm making no progress. Am I missing something, or is this just a quirk of DCL?
dcl_settings : default_dcl_settings { audit_level = 3; }
faultCUAL: dialog {
                    label = "Fault Calculations" ;
                    :column
                      :row
                        :boxed_column
                          label = "AFC" ;
                          : edit_box
                            key = "AFC" ;
                            action = "(setq AFC $value) (test_vals)" ;
                        :boxed_column
                          label = "Voltage" ;
                          : edit_box
                            key = "volts" ;
                            action = "(setq voltage $value) (test_vals)" ;
                        :boxed_column
                          label = "Length" ;
                          : edit_box
                            key = "clen" ;
                            action = "(setq conduit_length $value) (test_vals)" ;
                      :row
                        :column
                          :boxed_radio_row
                            label = "Conductors" ;
                            fixed_width = true ;
                            width = 29;
                            key = "type" ;
                            :radio_button
                                key = "CU" ;
                                width = 13 ;
                                label = "Copper" ;
                                value = "1" ;
                            : radio_button
                                key = "AL" ;
                                width = 13 ;
                                label = "Aluminum" ;
                          :boxed_radio_row
                            label = "Phase" ;
                            width = 29;
                            key = "phases" ;
                            :radio_button
                                key = "1ph" ;
                                width = 13 ;
                                label = "Single" ;
                            : radio_button
                                key = "3ph" ;
                                width = 13 ;
                                label = "Three" ;
                                value = "1" ;
                        :boxed_radio_column
                          label = "Conduit" ;
                          width = 13;
                          key = "conduit" ;
                          : radio_button
                              key = "steel" ;
                              label = "Steel" ;
                          : radio_button
                              key = "PVC" ;
                              label = "PVC" ;
                              value = "1" ;
                          : radio_button
                              key = "cable" ;
                              label = "Cable" ;
                      :row
                        :boxed_radio_column
                          label = "Sets" ;
                          width = 13;
                          key = "sets" ;
                          : radio_button
                              key = "set1" ;
                              label = "1 set" ;
                              value = "1" ;
                              action = "(set_small 1)" ;
                          : radio_button
                              key = "set2" ;
                              label = "2 sets" ;
                              action = "(set_small 2)" ;
                          : radio_button
                              key = "set3" ;
                              label = "3 sets" ;
                              action = "(set_small 3)" ;
                          : radio_button
                              key = "set4" ;
                              label = "4 sets" ;
                              action = "(set_small 4)" ;
                          : radio_button
                              key = "set5" ;
                              label = "5 sets" ;
                              action = "(set_small 5)" ;
                          : radio_button
                              key = "set6" ;
                              label = "6 sets" ;
                              action = "(set_small 6)" ;
                          : radio_button
                              key = "set7" ;
                              label = "7 sets" ;
                              action = "(set_small 7)" ;
                        :boxed_column
                          label = "AWG or KCMIL" ;
                          width = 29;
                          :row
                            :radio_column
                              key = "AWGcol1" ;
                              : radio_button
                                  key = "ws14" ;
                                  label = "#14 " ;
                                  action = "(set_radios $key)" ;
                              : radio_button
                                  key = "ws12" ;
                                  label = "#12" ;
                              : radio_button
                                  key = "ws10" ;
                                  label = "#10" ;
                              : radio_button
                                  key = "ws8" ;
                                  label = "#8" ;
                              : radio_button
                                  key = "ws6" ;
                                  label = "#6" ;
                              : radio_button
                                  key = "ws4" ;
                                  label = "#4" ;
                              : radio_button
                                  key = "ws3" ;
                                  label = "#3" ;
                              : radio_button
                                  key = "ws2" ;
                                  label = "#2" ;
                            :radio_column
                              key = "AWGcol2" ;
                              : radio_button
                                  key = "ws1" ;
                                  label = "#1" ;
                              : radio_button
                                  key = "ws0" ;
                                  label = "#1/0" ;
                              : radio_button
                                  key = "ws00" ;
                                  label = "#2/0" ;
                              : radio_button
                                  key = "ws000" ;
                                  label = "#3/0" ;
                              : radio_button
                                  key = "ws0000" ;
                                  label = "#4/0" ;
                                spacer_1;
                                spacer_1;
                                spacer_1;
                                spacer_1;
                                spacer_1;
                                spacer_1;
                            :radio_column
                              key = "AWGcol3" ;
                              : radio_button
                                  key = "ws250" ;
                                  label = "250" ;
                              : radio_button
                                  key = "ws300" ;
                                  label = "300" ;
                              : radio_button
                                  key = "ws350" ;
                                  label = "350" ;
                              : radio_button
                                  key = "ws400" ;
                                  label = "400" ;
                              : radio_button
                                  key = "ws500" ;
                                  label = "500" ;
                              : radio_button
                                  key = "ws600" ;
                                  label = "600" ;
                              : radio_button
                                  key = "ws750" ;
                                  label = "750" ;
                              : radio_button
                                  key = "ws1000" ;
                                  label = "1000" ;
// comment from here
                    :boxed_column
                      label = "Voltage drop";
                      :row
                        : paragraph
                          : text_part
                            label = "To calculate voltage drop" ;
                          : text_part
                            label = "enter the maximum amperage" ;
                        :column
                          fixed_width = true;
                          width = 13 ;
                          : edit_box
                            key = "amps" ;
                            action = "(setq amps $value) (test_vals)" ;
// comment to here
                    ok_cancel ;
"Science is the belief in the ignorance of experts." - Richard Feynman
adalea03
Re: :paragraph formatting
« Reply #1 on: January 13, 2010, 01:49:57 PM »
You'll prolly want to reformat , but see if this fits the bill.
//dcl_settings :default_dcl_settings  {audit_level=3;}
faultCUAL:dialog  {label="Fault Calculations";
:column {
:row {
:boxed_column {label="AFC";
:edit_box {key="AFC"; action="(setq AFC $value) (test_vals)";}}
:boxed_column {label="Voltage";
:edit_box {key="volts"; action="(setq voltage $value) (test_vals)";}}
:boxed_column {label="Length";
:edit_box {key="clen"; action="(setq conduit_length $value) (test_vals)";}}}
:row {
:column {
:boxed_radio_row {label="Conductors"; fixed_width=true; width=29; key="type";
:radio_button {key="CU"; width=13; label="Copper"; value="1";}
:radio_button {key="AL"; width=13; label="Aluminum";}}
:boxed_radio_row {label="Phase"; fixed_width=true; width=29; key="phases";
:radio_button {key="1ph"; width=13; label="Single";}
:radio_button {key="3ph"; width=13; label="Three"; value="1";}}}
:boxed_radio_column {label="Conduit"; fixed_width=true; width=13; key="conduit";
:radio_button {key="steel"; label="Steel";}
:radio_button {key="PVC"; label="PVC"; value="1";}
:radio_button {key="cable"; label="Cable";}}}
:row
 {:boxed_radio_column {label="Sets"; fixed_width=true; width=13; key="sets";
:radio_button {key="set1"; label="1 set"; value="1"; action="(set_small 1)";}
:radio_button {key="set2"; label="2 sets"; action="(set_small 2)";}
:radio_button {key="set3"; label="3 sets"; action="(set_small 3)";}
:radio_button {key="set4"; label="4 sets"; action="(set_small 4)";}
:radio_button {key="set5"; label="5 sets"; action="(set_small 5)";}
:radio_button {key="set6"; label="6 sets"; action="(set_small 6)";}
:radio_button {key="set7"; label="7 sets"; action="(set_small 7)";}}
:boxed_column {label="AWG or KCMIL"; fixed_width=true; width=29;
:row
 {:radio_column {key="AWGcol1";
:radio_button {key="ws14"; label="#14 "; action="(set_radios $key)";}
:radio_button {key="ws12"; label="#12"; action="(set_radios $key)";}
:radio_button {key="ws10"; label="#10"; action="(set_radios $key)";}
:radio_button {key="ws8"; label="#8"; action="(set_radios $key)";}
:radio_button {key="ws6"; label="#6"; action="(set_radios $key)";}
:radio_button {key="ws4"; label="#4"; action="(set_radios $key)";}
:radio_button {key="ws3"; label="#3"; action="(set_radios $key)";}
:radio_button {key="ws2"; label="#2"; action="(set_radios $key)";}}
:radio_column {key="AWGcol2";
:radio_button {key="ws1"; label="#1"; action="(set_radios $key)";}
:radio_button {key="ws0"; label="#1/0"; action="(set_radios $key)";}
:radio_button {key="ws00"; label="#2/0"; action="(set_radios $key)";}
:radio_button {key="ws000"; label="#3/0"; action="(set_radios $key)";}
:radio_button {key="ws0000"; label="#4/0"; action="(set_radios $key)";}
spacer_1; spacer_1; spacer_1; spacer_1; spacer_1; spacer_1;}
:radio_column {key="AWGcol3";
:radio_button {key="ws250"; label="250"; action="(set_radios $key)";}
:radio_button {key="ws300"; label="300"; action="(set_radios $key)";}
:radio_button {key="ws350"; label="350"; action="(set_radios $key)";}
:radio_button {key="ws400"; label="400"; action="(set_radios $key)";}
:radio_button {key="ws500"; label="500"; action="(set_radios $key)";}
:radio_button {key="ws600"; label="600"; action="(set_radios $key)";}
:radio_button {key="ws750"; label="750"; action="(set_radios $key)";}
:radio_button {key="ws1000"; label="1000"; action="(set_radios $key)";}}}}}}
:boxed_column {label="Voltage drop";
:row {
:column {
:row {
:text_part {label="To calculate voltage drop";}}
:row {
:text_part {label="enter the maximum amperage";}}}
:column {fixed_width=true; width=13;
:edit_box {key="amps"; action="(setq amps $value) (test_vals)";}}}}
// comment to here
ok_cancel;}
Tony
xyp1964
« Reply #2 on: February 04, 2011, 10:51:41 AM »
VIEW
« Last Edit: February 04, 2011, 10:55:09 AM by xyp1964 »
xiaxiang
« Reply #3 on: February 23, 2011, 01:41:02 AM »
Nice one,院长.
