Author Topic: (Challenge) To draw the shortest lwpolyline  (Read 126536 times)
mailmaverick
Re: (Challenge) To draw the shortest lwpolyline
« Reply #120 on: March 26, 2019, 07:43:15 AM »
Hi All
Out of the various routines given by various people, which one is the latest / fastest / best ?
ribarm
  • Marko Ribar, architect
« Reply #121 on: March 26, 2019, 08:20:25 AM »
Hi All
Hi, I am finally using CADSTUDIO's SHORTPATH.VLX with my additional LISP that calls it and then checks for intersecting lines with Evgeniy's method and prompts total length of path in 15 decimal places precision...
M.R. on Youtube
« Reply #122 on: March 26, 2019, 08:23:38 AM »
Hi All
The latest is right before your post  :-P .. the solutions in here vary based on the length of the list being processed. You'll have to test to see what works for you.
ribarm
« Reply #123 on: May 22, 2020, 03:17:16 PM »
Hi there...
Long time I haven't played with TSP...
I decided to post my latest version to see if someone will reply and give me any comments... For now it proved the most comprehensive for me... Only problem I see is that it's slow with minimal input options... For example if you use depth 1 and 1 solution attempt per depth iteration it is still very slow... The point now is that if you input depth smaller than maximum (number of free points inside convex hull), you can watch lwpolyline changing its shape until routine finishes task... So for speed computation and with best quality/speed I still recommend shortpath.vlx... This is only if you have specific task to do and you must be sure result is perfect - so you specify maximal input options (greatest depth allowed and all solution attempts <all> and then <100%> as percentage of attempts per depth iterations)... If you have more than 10 free points inside convex hull, you'll have to wait for a very long time, but if you have less than 10, then I suggest depending on PC that you input maximal values and still wait until it finishes... This is very complex problem and it requires very long computations, so just for fun and experimentation you may use this code, but at your own risk that you'll loose el. energy and time if PC is with low performances like my PC (old over 20 years)...
  1. (defun c:TSP-2D-MR-LATEST-NEW ( / LM:ConvexHull-ptsonHull LM:Clockwise-p sort processpt depth _do-events cmde ss n m j i p ppp pl pll plll pllll lw lwx lil k ilil pre mid suf dmin d ti )
  2.
  3.   ;; Convex Hull  -  Lee Mac
  4.   ;; Implements the Graham Scan Algorithm to return the Convex Hull of a list of points.
  5.
  6.   (defun LM:ConvexHull-ptsonHull ( lst / ch p0 lstl )
  7.     (cond
  8.       ( (< (length lst) 4) lst)
  9.       ( (setq p0 (car lst))
  10.         (foreach p1 (cdr lst)
  11.           (if (or (< (cadr p1) (cadr p0))
  12.                   (and (= (cadr p1) (cadr p0)) (< (car p1) (car p0)))
  13.               )
  14.               (setq p0 p1)
  15.           )
  16.         )
  17.         (setq lst (vl-remove p0 lst))
  18.         (setq lst (append (list p0) lst))
  19.         (setq lst
  20.           (vl-sort lst
  21.             (function
  22.               (lambda ( a b / c d )
  23.                 (if (or (equal (setq c (angle p0 a)) (setq d (angle p0 b)) 1e-8) (and (or (equal c 0.0 1e-8) (equal c (* 2 pi) 1e-8)) (or (equal d 0.0 1e-8) (equal d (* 2 pi) 1e-8))))
  24.                   (< (distance (list (car p0) (cadr p0)) a) (distance (list (car p0) (cadr p0)) b))
  25.                   (< c d)
  26.                 )
  27.               )
  28.             )
  29.           )
  30.         )
  31.         (setq lstl (vl-remove-if-not (function (lambda ( x ) (equal (angle p0 (last lst)) (angle p0 x) 1e-8))) lst))
  32.         (setq lst (vl-remove-if (function (lambda ( x ) (equal (angle p0 (last lst)) (angle p0 x) 1e-8))) lst))
  33.         (setq lstl (vl-sort lstl (function (lambda ( a b ) (> (distance p0 a) (distance p0 b))))))
  34.         (setq lst (append lst lstl))
  35.         (setq ch (list (cadr lst) (car lst)))
  36.         (foreach pt (cddr lst)
  37.           (setq ch (cons pt ch))
  38.           (while (and (caddr ch) (LM:Clockwise-p (caddr ch) (cadr ch) pt))
  39.             (setq ch (cons pt (cddr ch)))
  40.           )
  41.         )
  42.         (reverse ch)
  43.       )
  44.     )
  45.   )
  46.
  47.   ;; Clockwise-p  -  Lee Mac
  48.   ;; Returns T if p1,p2,p3 are clockwise oriented or [s]collinear[/s]
  49.
  50.   (defun LM:Clockwise-p ( p1 p2 p3 )
  51.     (<  (-  (* (- (car  p2) (car  p1)) (- (cadr p3) (cadr p1)))
  52.             (* (- (cadr p2) (cadr p1)) (- (car  p3) (car  p1)))
  53.         )
  54.         0.0
  55.     )
  56.   )
  57.
  58.   (defun sort ( l )
  59.     (vl-sort l (function (lambda ( a b ) (< (apply (function +) (mapcar (function (lambda ( c d ) (distance c d))) a (append (cdr a) (list (car a))))) (apply (function +) (mapcar (function (lambda ( c d ) (distance c d))) b (append (cdr b) (list (car b)))))))))
  60.   )
  61.
  62.   (defun processpt ( ppp p j / ppl pll plll pllll )
  63.     (gc)
  64.     (if j
  65.       (progn
  66.         (foreach pp ppp
  67.           (setq ppl (append (member pp ppp) (reverse (cdr (member pp (reverse ppp))))))
  68.           (setq pll (append (list pp) (list p) (cdr ppl)))
  69.           (setq plll (cons pll plll))
  70.         )
  71.         (setq plll (sort plll))
  72.         (repeat j
  73.           (if (car plll)
  74.             (setq pllll (cons (car plll) pllll))
  75.           )
  76.           (setq plll (cdr plll))
  77.         )
  78.       )
  79.       (progn
  80.         (foreach pp ppp
  81.           (setq ppl (append (member pp ppp) (reverse (cdr (member pp (reverse ppp))))))
  82.           (setq pll (append (list pp) (list p) (cdr ppl)))
  83.           (setq plll (cons pll plll))
  84.         )
  85.         (setq pllll plll)
  86.       )
  87.     )
  88.     pllll
  89.   )
  90.
  91.   (defun depth ( plll m / unique trimbynum trimbyperc ff plr pllll )
  92.
  93.     (defun unique ( l / x ll f1 f2 )
  94.
  95.       (defun f1 ( a b ) (equal a b 1e-6))
  96.
  97.       (defun f2 ( y ) (vl-every (function f1) y (member (car y) x)))
  98.
  99.       (gc)
  100.       (while (setq x (car l))
  101.         (setq ll (cons x ll)
  102.               x  (append x x)
  103.               l  (vl-remove-if (function f2) (cdr l))
  104.         )
  105.       )
  106.       ll
  107.     )
  108.
  109.     (defun trimbynum ( l m / ll )
  110.       (if (< m (length l))
  111.         (progn
  112.           (repeat m
  113.             (setq ll (cons (car l) ll))
  114.             (setq l (cdr l))
  115.           )
  116.           (setq ll (reverse ll))
  117.         )
  118.         (setq ll l)
  119.       )
  120.       ll
  121.     )
  122.
  123.     (defun trimbyperc ( l m / ll )
  124.       (if (< m 100)
  125.         (progn
  126.           (repeat (fix (* (length l) (/ m 100.0)))
  127.             (setq ll (cons (car l) ll))
  128.             (setq l (cdr l))
  129.           )
  130.           (setq ll (reverse ll))
  131.         )
  132.         (setq ll l)
  133.       )
  134.       ll
  135.     )
  136.
  137.     (defun ff ( x )
  138.       (vl-position x lww)
  139.     )
  140.
  141.     (if m
  142.       (progn
  143.         (setq plll (unique plll))
  144.         (if (= (type m) 'INT)
  145.           (foreach lww (trimbynum (if (< m (length plll)) (sort plll) plll) m)
  146.             (setq plr (vl-remove-if (function ff) pl))
  147.             (foreach p plr
  148.               (setq pllll (append (processpt lww p j) pllll))
  149.             )
  150.           )
  151.           (foreach lww (trimbyperc (if (< m 100) (sort plll) plll) m)
  152.             (setq plr (vl-remove-if (function ff) pl))
  153.             (foreach p plr
  154.               (setq pllll (append (processpt lww p j) pllll))
  155.             )
  156.           )
  157.         )
  158.       )
  159.       (foreach lww (unique plll)
  160.         (setq plr (vl-remove-if (function ff) pl))
  161.         (foreach p plr
  162.           (setq pllll (append (processpt lww p j) pllll))
  163.         )
  164.       )
  165.     )
  166.     pllll
  167.   )
  168.
  169.   (defun _do-events nil
  170.     (gc)
  171.     (repeat 2 (vl-cmdf "_.DELAY" 0) (princ ""))
  172.   )
  173.
  174.   (setq cmde (getvar 'cmdecho))
  175.   (setvar 'cmdecho 0)
  176.   (if
  177.     (and
  178.       (princ "\nSelect points, blocks or circles in WCS...")
  179.       (setq ss (ssget '((0 . "POINT,CIRCLE,INSERT"))))
  180.     )
  181.     (progn
  182.       (repeat (setq i (sslength ss))
  183.         (setq p (cdr (assoc 10 (entget (ssname ss (setq i (1- i)))))))
  184.         (setq pl (cons (mapcar (function +) '(0 0) p) pl))
  185.       )
  186.       (setq pll (LM:ConvexHull-ptsonHull pl))
  187.       (setq lw
  188.         (entmakex
  189.           (append
  190.             (list
  191.               '(0 . "LWPOLYLINE")
  192.               '(100 . "AcDbEntity")
  193.               '(100 . "AcDbPolyline")
  194.               (cons 90 (length pll))
  195.               (cons 70 (1+ (* 128 (getvar 'plinegen))))
  196.               '(38 . 0.0)
  197.             )
  198.             (mapcar (function (lambda ( x ) (cons 10 x))) pll)
  199.             '((210 0.0 0.0 1.0))
  200.           )
  201.         )
  202.       )
  203.       (setq lwx (entget lw))
  204.       (setq pl (vl-remove-if (function (lambda ( x ) (vl-position x pll))) pl))
  205.       (initget 6)
  206.       (setq n (getint (strcat "\nSpecify depth number - positive integer - from 1 to " (itoa (length pl)) " - preferable 3 <" (itoa (length pl)) "> : ")))
  207.       (if (null n)
  208.         (setq n (length pl))
  209.       )
  210.       (while (> n (length pl))
  211.         (prompt "\nYou specified number greater than : ") (princ (length pl))
  212.         (initget 6)
  213.         (setq n (getint (strcat "\nSpecify depth number - positive integer - from 1 to " (itoa (length pl)) " - preferable 3 <" (itoa (length pl)) "> : ")))
  214.         (if (null n)
  215.           (setq n (length pl))
  216.         )
  217.       )
  218.       (if (/= n (length pl))
  219.         (progn
  220.           (initget 4)
  221.           (setq i (getreal "\nIncremental depth - preferable 0 <1> - you can specify 1.5, 0.5, 0.33333334, 0.25 : "))
  222.           (if (null i)
  223.             (setq i 1)
  224.           )
  225.           (while (or (and (minusp (- (length pl) n n)) (> i 0)) (> i (- (length pl) n n) 0))
  226.             (prompt "\nYou specified number greater than : ") (if (minusp (- (length pl) n n)) (prompt "0 - you must specify \"0\"") (princ (- (length pl) n n)))
  227.             (initget 4)
  228.             (setq i (getreal "\nIncremental depth - preferable 0 <1> - you can specify 1.5, 0.5, 0.33333334, 0.25 : "))
  229.             (if (null i)
  230.               (setq i 1)
  231.             )
  232.           )
  233.         )
  234.       )
  235.       (initget 6)
  236.       (setq m (getint (strcat "\nSpecify number of solution attempts per depth iteration - preferable " (itoa (fix (/ 1600.0 (length pl)))) " <all> : ")))
  237.       (if (null m)
  238.         (progn
  239.           (initget 6)
  240.           (setq m (getreal "\nSpecify percentage of solution attempts per depth iteration <100%> : "))
  241.           (while (and m (> m 100))
  242.             (prompt "\nYou specified number greater than 100...")
  243.             (initget 6)
  244.             (setq m (getreal "\nSpecify percentage of solution attempts per depth iteration <100%> : "))
  245.           )
  246.         )
  247.       )
  248.       (initget 6)
  249.       (setq j (getint "\nSpecify number of list length processed by (processpt) sub function - preferable 2 <all> : "))
  250.       (setq ti (car (_vl-times)))
  251.       (setq ppp pll)
  252.       (while pl
  253.         (if (not (equal ppp pll))
  254.           (setq n (+ n i))
  255.         )
  256.         (foreach p pl
  257.           (setq plll (append (processpt ppp p j) plll))
  258.         )
  259.         (setq pllll plll)
  260.         (repeat (if (<= (fix n) (length pl)) (1- (fix n)) (1- (length pl)))
  261.           (setq pllll (depth pllll m))
  262.         )
  263.         (setq dmin 1e+308)
  264.         (foreach xxx pllll
  265.           (if (and xxx (< (setq d (apply (function +) (mapcar (function (lambda ( a b ) (distance a b))) xxx (append (cdr xxx) (list (car xxx)))))) dmin))
  266.             (setq dmin d pllll xxx)
  267.           )
  268.         )
  269.         (entupd
  270.           (cdr
  271.             (assoc -1
  272.               (entmod
  273.                 (setq lwx
  274.                   (append
  275.                     (subst (cons 90 (length pllll)) (assoc 90 lwx) (reverse (cdr (member (assoc 10 lwx) (reverse lwx)))))
  276.                     (mapcar (function (lambda ( x ) (cons 10 x))) pllll)
  277.                   )
  278.                 )
  279.               )
  280.             )
  281.           )
  282.         )
  283.         (setq pl (vl-remove-if (function (lambda ( x ) (vl-position x pllll))) pl))
  284.         (setq ppp pllll)
  285.         (_do-events)
  286.         (redraw lw)
  287.         (setq plll nil pllll nil)
  288.       )
  289.       (setq pl (mapcar (function cdr) (vl-remove-if (function (lambda ( x ) (/= (car x) 10))) lwx)))
  290.       (setq lil (mapcar (function list) pl (append (cdr pl) (list (car pl)))))
  291.       (setq k -1)
  292.       (while (and (< (setq k (1+ k)) (length lil)) (setq a (nth k lil)))
  293.         (setq ilil (vl-some (function (lambda ( b / ip ) (setq ip (inters (car a) (cadr a) (car b) (cadr b))) (if (and ip (setq ip (mapcar (function +) '(0 0) ip)) (or (and (or (equal ip (car a) 1e-6) (equal ip (cadr a) 1e-6)) (not (equal ip (car b) 1e-6)) (not (equal ip (cadr b) 1e-6))) (and (or (equal ip (car b) 1e-6) (equal ip (cadr b) 1e-6)) (not (equal ip (car a) 1e-6)) (not (equal ip (cadr a) 1e-6))) (and (not (equal ip (car a) 1e-6)) (not (equal ip (cadr a) 1e-6)) (not (equal ip (car b) 1e-6)) (not (equal ip (cadr b) 1e-6))))) (list a b)))) (vl-remove a lil)))
  294.         (if ilil
  295.           (progn
  296.             (setq pre (reverse (cdr (member (car ilil) (reverse lil)))))
  297.             (setq mid (cdr (member (car ilil) lil)))
  298.             (setq mid (cdr (member (cadr ilil) (reverse mid))))
  299.             (setq mid (mapcar (function reverse) mid))
  300.             (setq suf (cdr (member (cadr ilil) lil)))
  301.             (setq lil (append pre (list (list (car (car ilil)) (car (cadr ilil)))) mid (list (list (cadr (car ilil)) (cadr (cadr ilil)))) suf))
  302.             (setq pre nil mid nil suf nil)
  303.             (setq pl (mapcar (function car) lil))
  304.             (entupd
  305.               (cdr
  306.                 (assoc -1
  307.                   (entmod
  308.                     (append
  309.                       (reverse (cdr (member (assoc 10 lwx) (reverse lwx))))
  310.                       (mapcar (function (lambda ( x ) (cons 10 x))) pl)
  311.                     )
  312.                   )
  313.                 )
  314.               )
  315.             )
  316.             (_do-events)
  317.             (redraw lw)
  318.             (setq ilil nil k -1)
  319.           )
  320.         )
  321.       )
  322.     )
  323.   )
  324.   (setvar 'cmdecho cmde)
  325.   (prompt "\nDistance : ") (princ (rtos (apply (function +) (mapcar (function distance) pl (append (cdr pl) (list (car pl))))) 2 20))
  326.   (prompt "\nElapsed time : ") (princ (rtos (- (car (_vl-times)) ti) 2 20)) (prompt " milliseconds...")
  327.   (princ)
  328. )
  329.
Stay well and be healthy my friends...
M.R.
 :-) :wink:
« Last Edit: June 24, 2020, 10:03:40 AM by ribarm »
M.R. on Youtube
ribarm
« Reply #124 on: May 26, 2020, 07:39:03 AM »
I see there is no comment for my code...
Just a thought, wouldn't be nice if someone would convert LISP into some faster language... I mean - this is TSP problem, so it needs boosting in speed of calculations... However I am not educated in other than LISP... Maybe if Daniel could see it, or Gilles (.NET)... But I need it for A2018, so maybe I am old with my wishes, but that's the problem with other languages (ObjectARX, C#, ... )... It would be the best if it could work faster than LISP, but compatible with all AutoCAD releases...
This is just my thought, no one replied, so I had to step in again...
Thanks for attention, M.R.
[EDIT : If someone succeds to translate LISP, just don't give some stupid command names for execution like : "DOIT", "TEST", ... It would be nice something like : "TSP-2D-LSP-CONVERTED" or similar...]
« Last Edit: May 26, 2020, 07:59:04 AM by ribarm »
M.R. on Youtube
VovKa
  • Ukraine
« Reply #125 on: May 26, 2020, 08:16:34 AM »
because the code is long and rather difficult to read and understand
i'm pretty sure it could be optimized more
at least some simple things as
(setq mid (reverse (cdr (member (cadr ilil) (reverse mid)))))
(setq mid (reverse mid))
ribarm
« Reply #126 on: May 26, 2020, 11:29:10 AM »
I see...
So instead of those 2 lines, just replace them in my code (lastly portion - lines 298 and 299) with :
But this is really nothing in overall performance... I mean that we need boost in speed with *.arx or maybe *.dll that will replicate functionality of above posted LISP...
Thanks for reply, anyway...
[EDIT : Corrected my above posted code...]
« Last Edit: June 17, 2020, 07:51:21 AM by ribarm »
M.R. on Youtube
ribarm
« Reply #127 on: May 26, 2020, 04:57:12 PM »
Just to inform...
I've changed (processpt) sub function to be more efficient... To me the code looks now without evident lacks and ready for further process of translating/converting into faster programming language...
Regards...
M.R. on Youtube
ribarm
« Reply #128 on: May 28, 2020, 09:59:30 AM »
I have a problem LISP crashed in BricsCAD with this message :
; ----- LISP : Call Stack -----
; [0]...C:TSP-2D-MR-LATEST-NEW
; [1].....DEPTH
; [2].......UNIQUE # 1108 <<--
; ----- Error around expression -----
; (EQUAL A B 1.0e-06)
; error : out of LISP 'Heap' memory at [gc]
Then I've changed this portion :
  1. ...
  2.   (defun depth ( plll m / unique sort trimbynum trimbyperc plr pllll )
  3.
  4.     (defun unique ( l )
  5.       (gc)
  6.       (if l (cons (car l) (unique (vl-remove-if (function (lambda ( x ) (vl-every (function (lambda ( a b ) (equal a b 1e-6))) x (member (car x) (append (car l) (car l)))))) l))))
  7.     )
  8. ...
  9.
As you can see I've added (gc) in recursive sub function...
But still I run it and it crashes at about the same place with this error message :
: TSP-2D-MR-LATEST-NEW
Select entities:
Opposite Corner:
Entities in set: 40
Select entities:
Specify depth number - positive integer - from 0 to 32 <32> :
Specify number of solution attempts per depth iteration - preferable 50 <all> : 100
Specify number of list length processed by (processpt) sub function - preferable 2 <all> : 4
; [1].....DEPTH
; [2].......UNIQUE # 1130 <<--
; (CAR L)
So how can I fix it?
M.R. on Youtube
ribarm
« Reply #129 on: May 28, 2020, 10:13:13 AM »
Sorry it was my mistake, I forgot to owerwrite correct LISP which has (gc) added with old one which was loaded...
I am testing it again, we'll see how will it go...
M.R. on Youtube
ribarm
« Reply #130 on: May 28, 2020, 10:31:36 AM »
No it won't pass...
Now I have this :
Select entities:
Opposite Corner:
Entities in set: 40
Select entities:
; [1].....DEPTH
; [2].......UNIQUE # 897 <<--
; (GC)
Can someone fix it?
M.R. on Youtube
ribarm
« Reply #131 on: May 28, 2020, 01:43:53 PM »
It worked and in BricsCAD with those inputs... It looks like BricsCAD don't like recursions... So I've replaced (unique) with iterative version and it worked well...
  1. ...
  3.
  4.     (defun unique ( l / x ll )
  5.       (while (setq x (car l))
  6.         (setq ll (cons x ll))
  7.         (setq l (vl-remove-if (function (lambda ( y ) (vl-every (function (lambda ( a b ) (equal a b 1e-6))) y (member (car y) (append x x))))) l))
  8.       )
  9.       ll
  10.     )
  11. ...
  12.
Regards, M.R.
M.R. on Youtube
VovKa
  • Ukraine
« Reply #132 on: May 28, 2020, 07:40:27 PM »
this is true
but the devil is in the detail
i think you should spend more time on optimizing
(defun unique3 (l / x ll f1 f2)
  (defun f1 (a b) (equal a b 1e-6))
  (defun f2 (y) (vl-every 'f1 y (member (car y) x)))
  x  (append x x)
  l  (vl-remove-if 'f2 (cdr l))
  ll
your algorithm is unchanged but it is written in a more 'optimized' way
and i believe it will run a bit faster
ribarm
« Reply #133 on: May 29, 2020, 01:16:24 AM »
But those are minimal improvements...
  1. (defun c:test ( / l t0 t1 k f )
  2.   (repeat 10
  3.     (setq l (append l (atoms-family 1)))
  4.   )
  5.   (setq t0 (car (_vl-times)))
  6.   (foreach a l
  7.     (princ "")
  8.   )
  9.   (setq t1 (car (_vl-times)))
  10.   (prompt "\nElapsed time for (foreach a l) : ") (princ (rtos (- t1 t0) 2 20)) (prompt " milliseconds...")
  11.   (setq t0 (car (_vl-times)))
  12.   (while (setq a (car l))
  13.     (princ "")
  15.   )
  16.   (setq t1 (car (_vl-times)))
  17.   (prompt "\nElapsed time for (while (setq a (car l))) : ") (princ (rtos (- t1 t0) 2 20)) (prompt " milliseconds...")
  18.   (repeat 10
  19.     (setq l (append l (atoms-family 1)))
  20.   )
  21.   (setq k -1)
  22.   (setq t0 (car (_vl-times)))
  23.   (while (and (setq k (1+ k)) (< k (length l)) (setq a (nth k l)))
  24.     (princ "")
  25.   )
  26.   (setq t1 (car (_vl-times)))
  27.   (prompt "\nElapsed time for (while (and (setq k (1+ k)) (< k (length l)) (setq a (nth k l)))) : ") (princ (rtos (- t1 t0) 2 20)) (prompt " milliseconds...")
  28.   (setq t0 (car (_vl-times)))
  29.   (mapcar (function (lambda ( x ) (princ ""))) l)
  30.   (setq t1 (car (_vl-times)))
  31.   (prompt "\nElapsed time for (mapcar (function (lambda ( x ) (princ \"\"))) l) : ") (princ (rtos (- t1 t0) 2 20)) (prompt " milliseconds...")
  32.   (setq t0 (car (_vl-times)))
  33.   (defun f ( x ) (princ ""))
  34.   (mapcar (function f) l)
  35.   (setq t1 (car (_vl-times)))
  36.   (prompt "\nElapsed time for (mapcar (function f) l) : ") (princ (rtos (- t1 t0) 2 20)) (prompt " milliseconds...")
  37.   (princ)
  38. )
  39.
  40. ;;; On BricsCAD
  41. ;|
  42. : TEST
  43.
  44. Elapsed time for (foreach a l) : 2187 milliseconds...
  45. Elapsed time for (while (setq a (car l))) : 2312 milliseconds...
  46. Elapsed time for (while (and (setq k (1+ k)) (< k (length l)) (setq a (nth k l)))) : 8219 milliseconds...
  47. Elapsed time for (mapcar (function (lambda ( x ) (princ ""))) l) : 2235 milliseconds...
  48. Elapsed time for (mapcar (function f) l) : 2219 milliseconds...
  49. |;
  50.
M.R. on Youtube
Marc'Antonio Alessi
  • Marco
« Reply #134 on: May 29, 2020, 03:19:13 AM »
; [1].....DEPTH
<clip>
Keep in mind that the list with atoms-family  is at the limit of the memory (also in AutoCAD) and depends on your starting atoms-family length:
(length(atoms-family 1)) => 5519
:(progn
(_> (gc)
(_> (setq aList (atoms-family 1))
(_> (repeat 11 (setq aList (append aList aList)))
(_> (prompt "\nLength: ") (princ (length aList))
(_> (princ)
(_> )
Length: 11302912
: (progn
(_> (gc)
(_> (repeat 12 (setq aList (append aList aList)))
(_> (princ)
(_> )
; (APPEND ALIST ALIST)
