I thought this would be easy, just compare all the dimvars against the dimstyle, right? nope. Things like textstyles are not stored in dim vars, and there are many other things as well. So, the question is this, is there anyway to check a dimension against the dimstyle that it is assigned to?
I saw a couple of things like "Audit" and "Compare To" and "Equals" in the functions for dimension object, but haven't got a clue on how to use them or that's what they will do. I'll give it a try, but decided to post it here at the same time and see if I get any help.
Thanks,
Viktor.
