Author Topic: List Operation Driving me up the wall...  (Read 7441 times)
« on: September 15, 2009, 02:35:31 PM »
Ok, I'm not normally the one to come asking for help without slaving over it myself... but this has been driving me up the wall.
I am in the process of making my TabSort.lsp program compatible with a multi-tab selection and have accomplished everything except for the "up" and "down" buttons - which have kept me puzzled all day...  :|
If I focus on the "Up" button, I can just reverse the process for the "Down" button...
So here is my dilemma:
I need to pass the function an index list of items to be moved, and for it to return a new list with those items moved.
The items at the specific indexes need to be moved "up" a position [to the (n-1)th position], but there are some exceptions.
I'll provide a few examples:
Say we have a list:
(setq lst '[color=red](0 1 2 3 4 5)[/color])
(list_up '(2 3) lst)  [color=navy]Returns:[/color] (0 [color=red]2 3[/color] 1 4 5)
(list_up '(0 3) lst) [color=navy] Returns:[/color] ([color=red]0[/color] 1 [color=red]3[/color] 2 4 5)
(list_up '(0 1 4 5) lst)  [color=navy]Returns:[/color]  ([color=red]0 1[/color] 2 [color=red]4 5[/color] 3)
As you can see from the examples, the elements need to move up, except when they are consecutively in positions 0 1 2 3... etc
I have had a stab at it, but I really am getting nowhere and its driving me c r a z y   :ugly:
Here is my attempt:
(defun List_up (ilst rlst)
  (defun Remove_nth (i lst / j)
    (setq j -1)
    (vl-remove-if
      (function
        (lambda (x)
          (eq i (setq j (1+ j))))) lst))
  (defun Put_j_at_i (j i lst / r lst)
    (setq r (nth j lst) i (1+ i))
    (mapcar
      (function
        (lambda (x y)
          (cond ((zerop (setq i (1- i))) r)
                ((minusp i) y) (x))))
      lst (cons nil (remove_nth j lst))))
  (foreach x ilst
    (setq rlst
      (if (zerop x) rlst
        (cond ((vl-position (1- x) ilst) rlst)
              (Put_j_at_i x (1- x) rlst)))))
  rlst)
Any help/advice is appreciated,
Lee
uncoolperson
Re: List Operation Driving me up the wall...
« Reply #1 on: September 15, 2009, 03:00:50 PM »
(defun reorder_up (item remainlist)
  (cond ((= item (car (cdr remainlist)))
(cons
item
(cons
(car remainlist)
(reorder_up item (cddr remainlist))
(remainlist
(cons (car remainlist) (reorder_up item (cdr remainlist))))
(defun multireorder_up (items alist)
  (foreach item items
    (setq alist (reorder item alist)))
  alist)
(defun multireorder_down (items alist)
  (reverse (multireorder_up item (reverse alist))))
(defun reorder_down (item alist)
  (reverse (reorder_up item (reverse alist))))
_$ (setq lst '(0 1 2 3 4 5))
(0 1 2 3 4 5)
_$ (reorder_up '(2 3) lst)
(0 1 2 3 4 5)
_$ (multireorder_up '(2 3) lst)
(0 2 3 1 4 5)
(0 1 2 3 4 5)
(0 2 3 1 4 5)
_$ (multireorder_up '(0 3) lst)
(0 1 3 2 4 5)
_$ (multireorder_up '(0 1 4 5) lst)
(1 0 2 4 5 3)
didn't really read into the tabs thing, but had to have some fun
(scratch that, didn't like the last one)
« Last Edit: September 15, 2009, 03:36:10 PM by uncoolperson »
alanjt
  • Standby for witty remark...
« Reply #2 on: September 15, 2009, 03:14:12 PM »
This is ugly, but I wanted to play.
(defun at_up (nL L / i L1 L2)
  (setq i -1)
  (foreach x L
    (or (member (setq i (1+ i)) nL)
        (setq L2 (cons x L2))
    ) ;_ or
  ) ;_ foreach
  (setq i -1)
  (foreach x nL
    (setq L1 (cons (nth x L) L1))
  ) ;_ foreach
  (append (reverse L1) (reverse L2))
) ;_ defun
Dropbox
gile
  • Marseille, France
« Reply #3 on: September 15, 2009, 03:41:06 PM »
Something like this ?
(defun list_up (ind lst)
    ((or (null ind) (null lst)) lst)
    ((= 0 (car ind))
     (cons (car lst) (list_up (cdr (mapcar '1- ind)) (cdr lst)))
    ((= 1 (car ind))
     (cons (cadr lst) (list_up (cdr (mapcar '1- ind)) (cons (car lst) (cddr lst)))
    (T (cons (car lst) (list_up (mapcar '1- ind) (cdr lst))))
VovKa
  • Ukraine
« Reply #4 on: September 15, 2009, 03:48:32 PM »
sounds like a "dismissed!" command to me.
now i'm free to go to sleep
thanks, gile
ps it's cool :)
« Reply #5 on: September 15, 2009, 04:00:27 PM »
Hey Guys,
Many thanks for all your responses - a lot to look at and dissect  :-)
Gile - that is absolutely brilliant, works perfectly  :-)
So, I spend all day (well, maybe not all day) racking my brain on this one, and within an hour or less, Mr Gile comes up with a perfect recursive solution... you guys still amaze me.  :lol:
Thanks,
Lee
« Last Edit: September 15, 2009, 05:05:10 PM by Lee Mac »
gile
  • Marseille, France
« Reply #6 on: September 15, 2009, 04:09:26 PM »
You're welcome, I had fun :wink:
« Reply #7 on: September 15, 2009, 04:11:42 PM »
I'm having fun trying to get my head around it  :evil:
Maverick®
« Reply #8 on: September 15, 2009, 04:12:58 PM »
I wonder where "drive up the wall" originated?
« Reply #9 on: September 15, 2009, 05:04:25 PM »
Thanks Gile - I managed to make a list_down based on your example:
(defun list_down (ind lst)
  (reverse
    (list_up
      (reverse
        (mapcar
          (function
            (lambda (x)
              (- (1- (length lst)) x))) ind))
      (reverse lst))))
gile
  • Marseille, France
« Reply #10 on: September 15, 2009, 05:42:36 PM »
Another way using an iterative (while) process avoid using a reverse on the result list (maybe a little faster with long lists)
(defun list_down (ind lst / len rslt)
  (setq len (length lst)
        ind (reverse (mapcar (function (lambda (x) (- len x))) ind))
        lst (reverse lst)
  (while lst
      ((= 1 (car ind))
       (setq ind (cdr (mapcar '1- ind))
             rslt (cons (car lst) rslt)
             lst  (cdr lst)
      ((= 2 (car ind))
             rslt (cons (cadr lst) rslt)
             lst  (cons (car lst) (cddr lst))
      (T
       (setq ind  (mapcar '1- ind)
             lst  (cdr lst)
  rslt
« Last Edit: September 15, 2009, 05:51:11 PM by gile »
« Reply #11 on: September 15, 2009, 05:46:33 PM »
I suppose the same logic could be applied to the list_up function?  I assume a While is faster than recursion...
gile
  • Marseille, France
« Reply #12 on: September 15, 2009, 06:00:43 PM »
Yes, most of the time while is faster than recursion (on long lists)
But in list_up we don't need any reverse and the recursive callings stops when the index list is empty (the remaining list is returned "as is"). With a while statement, you have to continue the loop while the list is empty or use a call to append which is slow.
So if the greatest index is closed to to the last item of the list, a while statement should be a little faster otherwise it probably won't.
In all cases, if you're using these routines while an user input, the speed difference doesn't mean anything: the user will always be slower than the routine...
« Reply #13 on: September 15, 2009, 06:08:19 PM »
Interesting stuff, thanks Gile.
I always find it interesting to know what functions/processes are faster than others, like, for instance: I use vl-position over member for pretty much everything, just for that small speed difference.
That said, I didn't realise that reverse was a slow process...
« Reply #14 on: September 15, 2009, 06:15:04 PM »
Just for kicks, not sure if this is really a "valid" test, but:
(defun rev-erse (lst / x result)
  (while (setq x (car lst))
    (setq result (cons x result) lst (cdr lst)))
  result)
{ ^^ Best alternative to reverse I could think of }
  (setq lst '(0 1 2 3 4 5 6 7 8 9 0))
  (Benchmark
      (reverse lst)
      (rev-erse lst)
Elapsed milliseconds / relative speed for 32768 iteration(s):
    (REVERSE LST)......1810 / 1.47 <fastest>
    (REV-ERSE LST).....2652 / 1.00 <slowest>
