Author Topic: Mixed/Managed C++ dll's, passing objects.  (Read 14763 times)
Re: Mixed/Managed C++ dll's, passing objects.
« Reply #30 on: November 09, 2009, 04:54:37 AM »
Thanks Daniel, I wont get a chance to test for a day or so as I have other commitments but it looks good.
I'm squeesing this coding in between jobs so I really appreciate your help here, I feel a bit guilty for not putting in the study learning the clr stuff but I really only need these few pieces to get me through so again, thanks heaps, I owe you a beer or three :)
cheers.
- John Carmack
- J.R.R. Tolkien
« Reply #31 on: November 10, 2009, 09:37:35 PM »
Thanks Daniel, works a treat now, cheers :)
Kerry, I'll send you something soon ;)
- John Carmack
- J.R.R. Tolkien
« Reply #32 on: November 10, 2009, 09:56:27 PM »
Take your hurry. (translated : in your own time ... I used to have an Irish neighbour when I was a kid.)
Thanks Mick.
« Reply #33 on: November 10, 2009, 10:30:10 PM »
Great! please send beer or black licorice to:
Lane 99 PuMing Rd. Bldg #26 Apt#1403
Shanghai, China, 200120
 JK :-D
« Reply #34 on: November 11, 2009, 02:58:27 AM »
Never mind, I just found a small box of Good&Plenty, an extremely rare item in this part of the world.. ah bliss  :love:
« Reply #35 on: November 11, 2009, 03:27:13 AM »
I'll get some Darell Lee in to a bag :)
.. and some Rocklea Road ??
« Reply #36 on: November 11, 2009, 05:54:45 AM »
Ah YES! Please send me the bill too  :wink:
« Reply #37 on: November 12, 2009, 03:38:19 AM »
The carton is packed and addressed  ... in the mail tomorrow.
there is a bonus of some earwax flavoured jelly beans to try :)
.. will take a couple of days to reach you.
In appreciation !
« Reply #38 on: November 13, 2009, 05:13:38 AM »
Wow! Awesome! Thank you!
I will reciprocate with goodies I have found over here!   :kewl:
csharpbird
« Reply #39 on: November 15, 2009, 02:56:51 AM »
Hi,Daniel
How to covert a managed ResultBuffer object to an unmanaged resbuf?
How to covert an unmanaged resbuf object to a managed ResultBuffer?
« Reply #40 on: November 15, 2009, 03:56:45 AM »
Pretty much the same way, if wrapper derives from Autodesk.AutoCAD.Runtime.DisposableWrapper, you can use the methods Create and get_UnmanagedObject
resbuf *pRb = reinterpret_cast<resbuf*>(resultBuffer->UnmanagedObject.ToPointer());
//and
ResultBuffer ^resultBuffer =
  dynamic_cast<ResultBuffer^>(DisposableWrapper::Create(ResultBuffer::typeid,(IntPtr)pRb,false));
« Reply #41 on: January 14, 2010, 09:05:02 PM »
Hi Dan,
I've been pulling my hair out wondering why I can't get this finished :(
then I started looking at what I was passing around, I removed all the managed params and it worked fine so I looked a bit closer at what the conversion macros provided in the sdk were doing and I was getting mixed results.
Anyway, I've decided to do these conversions myself so I started with the snippet above but it errors out with 'UnManagedObject is not a member of .....blah blah'
Here's what I have
AcGePoint3d* p1 = reinterpret_cast<AcGePoint3d*>(pnt1->UnmanagedObject.ToPointer());
where pnt1 is passed in as Point3d^
the macro from adsk is -
#define GETPOINT3D(point3d) (*reinterpret_cast<AcGePoint3d*>(&(point3d)))
If I pass it a straight Point3d it spits out 0,0,0 regardless of point data, if I use a Point3d^ it spits out something like 33568899003 (a memory address or garbage??).
So, how is the best way to convert it to native, thanks.
- John Carmack
- J.R.R. Tolkien
« Reply #42 on: January 14, 2010, 09:54:15 PM »
Doh!!
I changed it to Point3d (without the ^) in my params and the arx macros works fine.
Sheesh, some consistency would be nice :roll:
- John Carmack
- J.R.R. Tolkien
« Reply #43 on: January 14, 2010, 10:14:24 PM »
 :lol:  well I made these for you
void Wrapper::NativeToManaged()
   AcGePoint3d npnt(1,1,1);//stack
   AcGePoint3d *pnpnt = new AcGePoint3d(2,2,2);//heap
   Point3d mpnt1 =  ToPoint3d( npnt );
   acutPrintf(_T("\n%g,%g,%g"),mpnt1.X,mpnt1.Y,mpnt1.Z);
   Point3d mpnt2 =  ToPoint3d( *pnpnt );
   acutPrintf(_T("\n%g,%g,%g"),mpnt2.X,mpnt2.Y,mpnt2.Z);
   Point3d ^pmpnt1 =  %ToPoint3d( npnt );
   acutPrintf(_T("\n%g,%g,%g"),pmpnt1->X,pmpnt1->Y,pmpnt1->Z);
   Point3d ^pmpnt2 =  %ToPoint3d( *pnpnt );
   acutPrintf(_T("\n%g,%g,%g"),pmpnt2->X,pmpnt2->Y,pmpnt2->Z);
   delete pnpnt;
 void Wrapper::ManagedToNative()
   Point3d mpnt(3,3,3); //stack
   Point3d ^pmpnt = gcnew  Point3d(4,4,4);//heap
   AcGePoint3d npnt1 =  GETPOINT3D( mpnt );
   acutPrintf(_T("\n%g,%g,%g"),npnt1.x,npnt1.y,npnt1.z);
   AcGePoint3d npnt2 =  GETPOINT3D( (Point3d)*pmpnt );
   acutPrintf(_T("\n%g,%g,%g"),npnt2.x,npnt2.y,npnt2.z);
   AcGePoint3d *pnpnt1 =  &GETPOINT3D( mpnt );
   acutPrintf(_T("\n%g,%g,%g"),pnpnt1->x,pnpnt1->y,pnpnt1->z);
   AcGePoint3d *pnpnt2 =  &GETPOINT3D( (Point3d)*pmpnt );
   acutPrintf(_T("\n%g,%g,%g"),pnpnt2->x,pnpnt2->y,pnpnt2->z);
« Reply #44 on: January 14, 2010, 10:21:39 PM »
I would try to keep those value types on the stack so you're not running into pinning pointers and stuff.
