Thanks Alan I can't quite follow the backtrace too well - when exactly did it crash, and what did you try to rename the tab to (if you got that far)?
Good point CAB - I notice the ABS in the backtrace and I believe that is the only line that uses it.Did AJ maybe double click too fast
(abs (read (rtos -1.01887e-006 2 10)))
((<[color=red]=[/color] (setq dcTag (load_dialog fname)) 0)
((< (setq dcTag (load_dialog fname)) 0)
I have not been able to reproduce the error.
I have not been able to reproduce the error.BTW Lee, The = is causing the DCL not to fire the first time when it is createdCode: [Select]((<[color=red]=[/color] (setq dcTag (load_dialog fname)) 0)should be Code: [Select]((< (setq dcTag (load_dialog fname)) 0)
Quote from: CAB on September 21, 2009, 09:19:54 PMI have not been able to reproduce the error.Odd, I'll have to try it when I can get back on the PC (wife is using it). Perhaps it was an isolated incident. I did only run it one session; should have restarted AutoCAD.
Quote from: CAB on September 21, 2009, 09:19:54 PMI have not been able to reproduce the error.BTW Lee, The = is causing the DCL not to fire the first time when it is createdCode: [Select]((<[color=red]=[/color] (setq dcTag (load_dialog fname)) 0)should be Code: [Select]((< (setq dcTag (load_dialog fname)) 0)Thats funny - the equals makes no difference to mine - but I shall change it anyway.Quote from: alanjt on September 21, 2009, 09:23:20 PMQuote from: CAB on September 21, 2009, 09:19:54 PMI have not been able to reproduce the error.Odd, I'll have to try it when I can get back on the PC (wife is using it). Perhaps it was an isolated incident. I did only run it one session; should have restarted AutoCAD.I couldn't reproduce the error either, unless your DATE sys var is somehow "corrupted", I can't think of any other explanation...
Ahhh of couse!Ok, then I suppose an easy fix would be to just set the DIMZIN to say 0, and reset it after program completion
Bug Squashed First post updated to Version 1.8.1 to include the bug fixes for the two Alans
Quote from: Lee Mac on September 22, 2009, 07:37:32 AMQuote from: CAB on September 21, 2009, 09:19:54 PMI have not been able to reproduce the error.BTW Lee, The = is causing the DCL not to fire the first time when it is createdCode: [Select]((<[color=red]=[/color] (setq dcTag (load_dialog fname)) 0)should be Code: [Select]((< (setq dcTag (load_dialog fname)) 0)Thats funny - the equals makes no difference to mine - but I shall change it anyway.Maybe it's ACAD2000 but the help says negative numbers signal failure so zero is returned on my system.
