Author Topic: TabSort.lsp  (Read 88681 times)
Re: TabSort.lsp
« Reply #105 on: September 19, 2009, 09:21:56 PM »
Thanks, I'll give it a try later tonight or tomorrow.
Re: TabSort.lsp
« Reply #106 on: September 20, 2009, 10:31:43 AM »
First post updated to Version 1.7 to include the features as listed  ;-)
gile
  • Marseille, France
Re: TabSort.lsp
« Reply #107 on: September 20, 2009, 02:37:57 PM »
Hi Lee,
Back to ArchSort, it seems there's something wrong with the routine in Version 1.7
(setq lst '("A1.03.5" "A1.20.25" "A1.03.15" "A1.12.4" "A1.01.5" "A1.0.5"))
(archsort lst)
returns:
("A1.0.5" "A1.01.5" "A1.12.4" "A1.03.15" "A1.20.25" "A1.03.5")
instead of:
("A1.0.5" "A1.01.5" "A1.03.15" "A1.03.5" "A1.12.4" "A1.20.25")
I think it's due to the StrBrk routine
Here's one which seems to work.
(defun SplitStr (str / lst test rslt num tmp)
  (setq lst  (vl-string->list str)
test (chr (car lst))
  (if (< 47 (car lst) 58)
    (setq num T)
  (while (setq lst (cdr lst))
    (if num
((= 46 (car lst))
          (if (and (cadr lst)
                   (setq tmp (strcat "0" "." (chr (cadr lst))))
                   (numberp (read tmp))
            (setq rslt (cons (read test) rslt)
                  test tmp
                  lst  (cdr lst)
                  test "."
                  num  nil
((< 47 (car lst) 58)
(setq test (strcat test (chr (car lst))))
(T
       num  nil
(setq rslt (cons test rslt)
      num  T
  (if num
    (setq rslt (cons (read test) rslt))
    (setq rslt (cons test rslt))
  (reverse rslt)
(defun ArchSort (lst / comparable)
  (defun comparable (e1 e2)
    (or (and (numberp e1) (numberp e2))
        (= 'STR (type e1) (type e2))
        (not e1)
        (not e2)
  (mapcar
    (function
      (lambda (x)
        (nth x lst)
    (vl-sort-i
      (mapcar 'SplitStr lst)
      (function
        (lambda (x1 x2 / n1 n2 comp)
          (while
            (and
              (setq comp (comparable (setq n1 (car x1)) (setq n2 (car x2))))
              (= n1 n2)
             (setq x1 (cdr x1)
                   x2 (cdr x2)
          (if comp
            (< n1 n2)
            (numberp n1)
« Last Edit: September 20, 2009, 02:46:15 PM by gile »
Re: TabSort.lsp
« Reply #108 on: September 20, 2009, 04:40:13 PM »
Nice Gile - I hadn't accounted for the multiple decimals, with my previous routine:
(StrBrk "A1.2.3")  Returns:  ("A" 1)
As 1.2.3 will return nil upon reading.
Whereas yours:
(SplitStr "A1.2.3") Returns: ("A" 1 0.2 0.3)
Which is much more helpful for sorting  8-)
Re: TabSort.lsp
« Reply #109 on: September 20, 2009, 05:09:31 PM »
Gile I have Updated the first post with Version 1.7.1 ~ which includes your version of the Archsort function (with credit given  ;-) )
I have also modified your SplitStr function to only display numbers, for use with my NumSort function  :wink:
Thanks for all your help with this.  :-)
Re: TabSort.lsp
« Reply #110 on: September 20, 2009, 06:08:45 PM »
OK where is the HELP button to explain all this?  :evil:
Re: TabSort.lsp
« Reply #111 on: September 21, 2009, 05:24:43 AM »
Hehe good point  - but tbh, I didn't really want a help button... I wanted to keep the number of buttons to a minimum so as not to clutter it too much... I think it is all pretty self explanatory really :P
Re: TabSort.lsp
« Reply #112 on: September 21, 2009, 09:42:54 AM »
True but some users will still need some hand holding. :)
Here is an experiment using an almost hidden button which is accessed via the H key.
Re: TabSort.lsp
« Reply #113 on: September 21, 2009, 10:30:56 AM »
Nice idea!
On my screen, the button shows as just a small "bar", is this the same on yours? But this is not very noticeable, unless you know where to look  ;-)
I also like the way that you have incorporated the Dialog title as a key - makes it easier to remember when you notch it up a version  8-)
I think I will include this feature - help if you need it, but non-obtrusive for those who know what they are doing  :-)
Re: TabSort.lsp
« Reply #114 on: September 21, 2009, 12:50:12 PM »
Glad you like it. Yes a small bar which you can click on too if you knew about it. :)
Re: TabSort.lsp
« Reply #115 on: September 21, 2009, 12:50:31 PM »
I have updated the first post to include Version 1.8, my thanks to CAB for his idea for the help button  8-)
alanjt
  • Standby for witty remark...
Re: TabSort.lsp
« Reply #116 on: September 21, 2009, 02:32:30 PM »
Talk about 'out of control'. LoL
Very nice Lee.
Dropbox
alanjt
Re: TabSort.lsp
« Reply #117 on: September 21, 2009, 03:29:55 PM »
Received an error when I tried to rename tab.
Command:
TABSORT Backtrace:
[0.93] (VL-BT)
[1.89] (*ERROR* "bad argument type: numberp: -")
[2.84] (_call-err-hook #<SUBR @1e913d48 *ERROR*> "bad argument type: numberp:
[3.78] (sys-error "bad argument type: numberp: -")
:ERROR-BREAK.73 "bad argument type: numberp: -"
[4.70] (ABS -)
[5.65] (#<SUBR @1e44458c -lambda-> "tabs" "1" "" 4 75 14)
[6.56] (#<SUBR @173399ec -application-envelope->)
:ENTRY-NAMESPACE.53 (:ENTRY-NAMESPACE)
[7.50] (#<SUBR @17339a14 -unwind-protect->)
[8.47] (_lisplet-apply #<Document-LISPLET> #<SUBR @173399ec
-application-envelope-> nil nil)
[9.39] (_lisplet-app-apply #<Document-LISPLET> #<SUBR @1e44458c -lambda->
("tabs" "1" "" 4 75 14))
[10.32] (dcl-call-back ("tabs" "1" "" 4 75 14) T)
:DCL-ACTION.26 (((:DCL-ACTION "tabsort" "tabs" 4)))
[11.23] (START_DIALOG)
[12.19] (C:TABSORT)
[13.15] (#<SUBR @1e444550 -rts_top->)
[14.12] (#<SUBR @1733435c veval-str-body> "(C:TABSORT)" T #<FILE internal>)
:CALLBACK-ENTRY.6 (:CALLBACK-ENTRY)
:ARQ-SUBR-CALLBACK.3 (nil 0)
** Error: bad argument type: numberp: - **
Dropbox
Re: TabSort.lsp
« Reply #118 on: September 21, 2009, 07:06:37 PM »
Thanks Alan  8-)
I can't quite follow the backtrace too well - when exactly did it crash, and what did you try to rename the tab to (if you got that far)?
Re: TabSort.lsp
« Reply #119 on: September 21, 2009, 07:16:45 PM »
My guess would be line 186
(< (abs (read (rtos (- #en #st) 2 10))) 0.0000011667))Maybe the read returned the minus sign and no number to evaluate.
