Author Topic: TabSort.lsp  (Read 88245 times)
Willie
  • Going nowhere slowly
Re: TabSort.lsp
« Reply #45 on: September 16, 2009, 06:36:55 PM »
Very impressive Lee.
Re: TabSort.lsp
« Reply #46 on: September 16, 2009, 06:41:52 PM »
Thanks Willie  :-)
I think I'm just about done with this one - not sure what else to add without making it look cluttered...  :|
Lee
haustab
Re: TabSort.lsp
« Reply #47 on: September 17, 2009, 01:30:18 AM »
Thanks Lee,
Great job(s)
(like the other stuff you published)
jmcshane
Re: TabSort.lsp
« Reply #48 on: September 17, 2009, 04:02:29 AM »
Your comments/criticism is always welcome, and, of course, the inevitable bug reports!
Lee,
This just gets better and better.
One thing though, The copy function, while it does copy the tab, does not copy the page setup information
as it does when copying the tab manually.
I hate to be picky considering the amount of work you have put into this, and there is now way you can keep everybody happy,
but I thought you would want to know.
John.
Civil 3D 2021. Windows 10
Re: TabSort.lsp
« Reply #49 on: September 17, 2009, 05:41:30 AM »
Lee,
No worries John, I am happy for the criticism - that way things can be improved on  :-)
I shall definitely look into it, thanks for the comment.
Lee
Re: TabSort.lsp
« Reply #50 on: September 17, 2009, 06:26:25 AM »
I have updated the first post to version 1.5, this should resolve the issue with copying Plot settings.
Re: TabSort.lsp
« Reply #51 on: September 17, 2009, 06:45:15 AM »
Not sure whether this is necessary or not, but, with each version of the program, a DCL file is written to the AutoCAD filepath - if you want to clean the excess TabSort DCL files from the filepath, they are stored in the same location as the ACAD.pat file.
You can do a search for that file and delete the old DCL versions manually, else, I have written this short function that will clean it for you:
(defun c:TabSortClean (/ wPath)
  (if (setq wPath (findfile "ACAD.PAT"))
      (setq wPath (vl-filename-directory wPath))
      (or (eq "\\" (substr wPath (strlen wPath)))
          (setq wPath (strcat wPath "\\")))
      (foreach file (vl-directory-files wPath "TabSortV1.*.dcl" 1)
        (initget "Yes No")
        (if (/= "No" (getkword (strcat "\nDelete file: " file " ? [Yes/No] <Yes> : ")))
          (vl-file-delete (strcat wPath file))))))
  (princ))
Authorisation is required before each deletion, so it won't just wipe them all at once  :wink:
Willie
Re: TabSort.lsp
« Reply #52 on: September 17, 2009, 07:30:26 AM »
Hi Lee,
Can't you delete the temp dcl file when you close the dialog?
jmcshane
Re: TabSort.lsp
« Reply #53 on: September 17, 2009, 07:38:07 AM »
Sorted.
Thanks Lee.
John.
Re: TabSort.lsp
« Reply #54 on: September 17, 2009, 08:23:25 AM »
Lee,
FYI, In architectural DWGs the tab names need to be sorted like this:
A1
A2
A3
A10
Re: TabSort.lsp
« Reply #55 on: September 17, 2009, 09:02:47 AM »
Hi Lee,
I could do - but I felt it was better to write the file, and check if the file existed on the second time of invoking the function - instead of writing it every time the user invoked the command.
Re: TabSort.lsp
« Reply #56 on: September 17, 2009, 09:04:07 AM »
Lee,
A1
A2
A3
A10
My #Sort should sort them like that  :-)
Re: TabSort.lsp
« Reply #57 on: September 17, 2009, 09:31:11 AM »
I don't think so. :evil:
Re: TabSort.lsp
« Reply #58 on: September 17, 2009, 10:25:33 AM »
Gliderider
Re: TabSort.lsp
« Reply #59 on: September 17, 2009, 11:31:44 AM »
Thanks Lee, I found it quite useful today!
