Author Topic: TabSort.lsp  (Read 87531 times)
TabSort.lsp
« on: September 13, 2009, 02:53:03 PM »
Just a project I was working on recently, written for a bit of fun.
TabSort.lsp
Version 2.2
;;--------------------=={ TabSort.lsp }==---------------------;;
;;  A program designed with the intention to aid in the       ;;
;;  organisation of layout tabs in a drawing.                 ;;
;;  The program enables the user to organise each layout tab  ;;
;;  using buttons to move the tabs up, down, to the top, and  ;;
;;  to the bottom of a list.                                  ;;
;;  The user may rename any layout by double clicking on it,  ;;
;;  and can also add a Prefix and/or Suffix to selected/every ;;
;;  layout tab.                                               ;;
;;  The program offers the facility to add and delete a       ;;
;;  layout tab, and also sort the tabs alphabetically,        ;;
;;  numerically, architecturally; or reverse the order in     ;;
;;  which they appear.                                        ;;
;;  A Find and Replace function is incorporated to allow the  ;;
;;  user to quickly replace a text string in multiple tabs.   ;;
;;  The user can also Copy a layout tab, and set the Selected ;;
;;  layout tab as the current tab.                            ;;
;;  The Help Dialog can be access by pressing "H" at the Main ;;
;;  Dialog.                                                   ;;
;;  FUNCTION SYNTAX:  TABSORT                                 ;;
;;  Notes:-                                                   ;;
;;  The Reset button will reset Tab Order and Tab Names, but  ;;
;;  will not affect newly created tabs and will not recreate  ;;
;;  deleted tabs.                                             ;;
;;  In the case that multiple tabs are selected, the Current  ;;
;;  button will set the tab with the lowest index (highest in ;;
;;  the list) as the current tab.                             ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  With Thanks To:                                           ;;
;;  Gilles Chanteau (Gile)                                    ;;
;;  For his fantastic contribution to the list manipulation   ;;
;;  required for multiple DCL selections, and effort towards  ;;
;;  the Architectural Sort functions.                         ;;
;;  Charles Alan Butler (CAB)                                 ;;
;;  For his excellent idea to incorporate the Help button for ;;
;;  those who need it.                                        ;;
;;  Version:                                                  ;;
;;  1.0    -  13th September 2009                             ;;
;;  First Release                                             ;;
;;  1.1    -  14th September 2009                             ;;
;;  Added Mnemonics to Tiles                                  ;;
;;  Added text to notify of double-click availability         ;;
;;  Added option to only pref/suff selected tab               ;;
;;  1.2    -  15th September 2009                             ;;
;;  Added Numerical Sort                                      ;;
;;  General Bug Fixes                                         ;;
;;  1.3    -  15th September 2009                             ;;
;;  Multi-tab Selection Functionality                         ;;
;;  1.4    -  16th September 2009                             ;;
;;  Added Button to Set Current Tab                           ;;
;;  Added Copy Tab Functionality                              ;;
;;  1.5    -  17th September 2009                             ;;
;;  Fixed Bug to Copy Layout Plot Settings                    ;;
;;  1.6    -  18th September 2009                             ;;
;;  Modified Action_Tile Stmts ~ Thanks VovKa                 ;;
;;  Added Architectural Sort Button                           ;;
;;  1.6.1  -  19th September 2009                             ;;
;;  Fixed Bugs ~ Thanks for feedback CAB                      ;;
;;  1.7    -  20th September 2009                             ;;
;;  Added Find & Replace Functionality                        ;;
;;  Organised buttons/Added Sort Dialog                       ;;
;;  1.7.1  -  20th September 2009                             ;;
;;  Replaced StrBrk sub with SplitStr (Gile)                  ;;
;;  1.8    -  21st September 2009                             ;;
;;  Added hidden Help Button (CAB)                            ;;
;;  Added Help Dialog Definition                              ;;
;;  1.8.1  -  22nd September 2009                             ;;
;;  1.8.2  -  23rd September 2009                             ;;
;;  Fixed Bug causing crash when Deleting all                 ;;
;;  Tabs ~ thanks VovKa                                       ;;
;;  1.9    -     2nd October 2009                             ;;
;;  Modified Reverse function to only apply to selected Tabs. ;;
;;  Altered Help Dialog to ok_only button                     ;;
;;  2.0    -       22nd July 2010                             ;;
;;  Fixed Bug with Find/Replace.                              ;;
;;  2.1    -    9th December 2010                             ;;
;;  Fixed Bug with Double Reversal                            ;;
;;  2.2    -        16th May 2011                             ;;
;;  Program completely rewritten to update formatting.        ;;
;;  Upgraded Find & Replace engine to allow for               ;;
;;  self-referencing find and replace terms and improved      ;;
;;  visual feedback.                                          ;;
;;  Updated list manipulation subfunctions.                   ;;
Program Controls:
Top: Move selected Tabs to the top of the list.
Up: Move selected Tabs up one notch in the list.
Down: Move selected Tabs down one notch in the list.
Bottom: Move selected Tabs to the bottom of the list.
Sort: Opens the Sort Dialog:
Alphabetical: Sort Tabs alphabetically:
Hence ~
("A23" "C22" "B3" "E7")Becomes ~
("A23" "B3" "C22" "E7")
Numerical:  Sort Tabs numerically:
Hence ~
("B3" "E7" "C22" "A23")
Architectural:  Use an Architectural Sorting Method:
Hence ~
("A-1A" "B-3" "A-10C" "B-1.2" "B-1")Becomes ~
("A-1A" "A-10C" "B-1" "B-1.2" "B-3")
Reverse:  Reverse the Tab order of Selected Tabs.
Pref/Suff:  Opens the Prefix/Suffix Dialog to allow the user to add a Prefix and/or Suffix to selected/all Tabs.
Add:  Add a new layout Tab.
Delete:  Deletes selected Tabs.
Copy:  Copies the selected Tabs.
Current:  Makes the selected Tab the Current Tab.
Find:  Allows the user to perform a Find & Replace:
Done: Finished sorting Tabs, will implement sorting.
Reset:  Will reset Tab names and Tab order  ~ will not reset deleted/added Tabs.
Screenshot:
Your comments/criticism is always welcome, and, of course, the inevitable bug reports!  8-)
Enjoy!  :-)
Lee
Full Description here
« Last Edit: May 17, 2011, 08:47:48 AM by Lee Mac »
Re: TabSort.lsp
« Reply #1 on: September 13, 2009, 03:23:40 PM »
Nice job Lee.
Here is my old routine: http://www.theswamp.org/index.php?topic=6511.0
Need to update it as this sort does a better job with Architectural tab names.
http://www.theswamp.org/index.php?topic=6474.0
Re: TabSort.lsp
« Reply #2 on: September 13, 2009, 04:45:04 PM »
Thanks Alan  8-)
I thought that someone would have done this already - but I had fun in making it  ;-)
alanjt
  • Standby for witty remark...
Re: TabSort.lsp
« Reply #3 on: September 13, 2009, 04:50:56 PM »
Nice functionality. I like all the options.
Comments:
1. Add a piece of text to the dialog to inform the user of the option to rename by double-clicking.
2. Utilizes a few of the bonus tool, I mean express tool functions. You could have a check at the beginning to ensure ET is loaded.
3. vla-get-activedocument and vlax-get-acad-object are called a few times.
4. You have a lot of subs that are not localized, not really a problem, except that I've noticed the DCL_Write function used by you quite a bit. If a user is running another program utilizing DCL_Write, problems are going to occur.
With that being said, I will, again say that I really like the program and will be adding it to my tool belt. Thanks for sharing.
Dropbox
Re: TabSort.lsp
« Reply #4 on: September 13, 2009, 05:51:06 PM »
Lee the double click is a great feature. I also like the prefix/suffix options.
I'll have to add those to my TabMover! :)
Notice on mine you may select a group of tabs. This would be useful when adding prefix/suffix to a selected group.
Re: TabSort.lsp
« Reply #5 on: September 13, 2009, 06:54:35 PM »
Thanks Alan - I had a bit of help with the double click from Andrea in the other recent thread - but I'm surprised that the list_box doesn't have an attribute already in place to aid with this functionality - all I could find was allow_accept...
I think the multiple selection of tabs is the next logical step for this - although it may mean a major overhaul in the coding... but thanks for the comments :-)
Thanks Al  8-)
Good idea, I was thinking the same thing - I didn't want to spoil the "clean" look of the dialog, but I think it should be added.
There is a check at the top of the LISP - using the variable "et:wink:
I only call it once actually, and use lexical scoping (got that term from Se7en :P ) to prevent calling it loads of times  :-)
Ahh, yes - that could cause a problem, I may include the DCL_Write function within the Main Function definition and localise it.
Thanks Alan, I feel honoured  8-)
Willie
  • Going nowhere slowly
Re: TabSort.lsp
« Reply #6 on: September 13, 2009, 07:07:32 PM »
Nicely done Lee!!  Very handy
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8  64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
alanjt
Re: TabSort.lsp
« Reply #7 on: September 13, 2009, 07:18:52 PM »
Lee Response #:
1. Yeah, I don't know where you would put it. Just a thought.
2 & 3. I stand corrected, completely overlooked.
4. No reason not to, or at least add a prefix/suffix 'TabMover' to it.
Seriously, nice work.
Thanks Al  8-)
There is a check at the top of the LISP - using the variable "et"  :wink:
Dropbox
Re: TabSort.lsp
« Reply #8 on: September 13, 2009, 08:52:00 PM »
Thanks Willie  :-)
Lee Response #:
Cheers Alan, I'll see to those improvements :-)
I'm glad you like it mate  :-)
alanjt
Re: TabSort.lsp
« Reply #9 on: September 13, 2009, 10:01:17 PM »
Thanks Willie  :-)
Lee Response #:
This will be strike 3 for me today, I went back and looked at Alan's (Cab) Dcl2Lisp and you are working on the same principals. I found and have been using his since 07, without any issues. Just ignore what I've said. Probably just that I like to localize as many of my functions as possible. I do have a folder of them (ones I've written for day-to-day use) that I have loaded at every startup. That way, I can act as if they're additional commands in Autocad (sadly, you can't register lisp subs in Vlide), everything gets to use the most updated version of the sub. and I don't have to place them in each program file.
I forgot to mention it, but the ability to add a new layout was genius (should switch to newly created one though).
Hmm, that brings up an interesting question: I wonder if it's possible to replicate the 'copy layout' option (probably not in Lisp). I think I'll do a little research and digging.
Dropbox
Aerdvark
Re: TabSort.lsp
« Reply #10 on: September 14, 2009, 04:27:30 AM »
Hi Lee,
This is a great piece of coding ! Thank you for sharing it with us.You know I'm not that great of a programmer so I will only judge it by the functionality.
First of all I wonder; how did you come up with the idea? I know you study math and you are no drafter. Are you inspecting the screen for items to modify in a rondom way?  :lol:
95% of my project (*.dwg's) contain more than 3 layouts. Some of them contain like 20 layouts and I know there are people amongst us that go far beyond 20  :ugly:. Whenever I want to sort or rename it takes time. Therefore this routine comes in handy, ie. if in modelspace, it stays in modelspace.
In fact I have no comments on the routine itself. You might add some functions, like:
1. the use of the "CTRL" key so one can select multiple layouts to edit / sort.
2. I made myself a routine that helps adding template layouts. You might want to put that in yours too for that is mighty handy!!
(defun c:nlay( / size name)
(setq size (getstring (strcat "\nWhat size do you want your new layout to be ?? :  ")))
(setq name (getstring T (strcat "\nPlease give a name for the new layout :  ")))
(command "-layout" "t" "standards.dwg" size)
(command "-layout" "r" size name)
Well, first there should be a dwg called "standards.dwg" in a supported path. Next: the file itself should contain several layouts as you want them to be. Name the various layouts ie. ISOA1 or ISOA2...  :|... me telling you how it works...
If you would add it, it would be great to have a drop down list in wich all the available "sizes" (layouts in the standards.dwg) are selectable, maybe even multiple selection...
3. A "cancel" button to finish the dialog?
Re: TabSort.lsp
« Reply #11 on: September 14, 2009, 07:41:37 AM »
Thanks Alan - I think I'll make that change also.
I think you would have to manually copy all the objects from the layout space into the new layout... I don't think there would be an elegant solution to it.  :|
Re: TabSort.lsp
« Reply #12 on: September 14, 2009, 07:47:54 AM »
Hey Marco, thanks for your comments, I'm glad you like the program  :-)
I'm not sure how I came up with the idea.. I find ideas hard to come by, and, like most things in programming - its all been done before (as CAB has demonstrated above...). So when an idea does pops into my head, I write it for a bit of fun.  ;-)
Yes, I think this is the next step for this program - but it will be a lot more work I think...
I considered this...  but some of the changes (eg the delete tab option) occur as soon as the user has confirmed it - so I would have to implement the UNDO command quite a lot...
Re: TabSort.lsp
« Reply #13 on: September 14, 2009, 09:56:11 AM »
Code in first post updated to reflect Version 1.1 ~ changes noted  :-)
Re: TabSort.lsp
« Reply #14 on: September 14, 2009, 10:29:37 AM »
Just updated a minor bug in the code to switch to the new tab when the user clicks "Add".
