Author Topic: TabSort.lsp  (Read 88652 times)
Re: TabSort.lsp
« Reply #120 on: September 21, 2009, 07:27:28 PM »
Good point CAB - I notice the ABS in the backtrace and I believe that is the only line that uses it.
Did AJ maybe double click too fast  :evil:
alanjt
  • Standby for witty remark...
Re: TabSort.lsp
« Reply #121 on: September 21, 2009, 08:32:33 PM »
Thanks Alan  8-)
I can't quite follow the backtrace too well - when exactly did it crash, and what did you try to rename the tab to (if you got that far)?
I couldn't get past the double-click.
Dropbox
alanjt
Re: TabSort.lsp
« Reply #122 on: September 21, 2009, 08:33:15 PM »
LoL
I'm fast, but not that fast. I tried it several times, just to make sure.
Dropbox
Re: TabSort.lsp
« Reply #123 on: September 21, 2009, 08:41:40 PM »
I think CAB is correct about the read statement not returning a valid number - but I cannot see why it is failing...
Just out of curiosity, try this at the command line... :P
(abs (read (rtos -1.01887e-006 2 10)))
Re: TabSort.lsp
« Reply #124 on: September 21, 2009, 09:19:54 PM »
I have not been able to reproduce the error.
BTW Lee, The = is causing the DCL not to fire the first time when it is created
((<[color=red]=[/color] (setq dcTag (load_dialog fname)) 0)should be
((< (setq dcTag (load_dialog fname)) 0)
alanjt
Re: TabSort.lsp
« Reply #125 on: September 21, 2009, 09:23:20 PM »
Odd, I'll have to try it when I can get back on the PC (wife is using it). Perhaps it was an isolated incident. I did only run it one session; should have restarted AutoCAD.
Dropbox
Re: TabSort.lsp
« Reply #126 on: September 22, 2009, 07:37:32 AM »
Thats funny - the equals makes no difference to mine  :? - but I shall change it anyway.
I couldn't reproduce the error either, unless your DATE sys var is somehow "corrupted", I can't think of any other explanation...  :-(
alanjt
Re: TabSort.lsp
« Reply #127 on: September 22, 2009, 08:32:01 AM »
It's the dimzin variable. We use dimzin 12 to remove leading and trailing zeros. As a result, read returns only a '-' and abs freaks out.
Dropbox
Re: TabSort.lsp
« Reply #128 on: September 22, 2009, 08:41:48 AM »
Ahhh of couse!
Ok, then I suppose an easy fix would be to just set the DIMZIN to say 0, and reset it after program completion  ;-)
alanjt
Re: TabSort.lsp
« Reply #129 on: September 22, 2009, 08:53:46 AM »
Ahhh of couse!
It's an easy-to-squash bug.
Dropbox
Re: TabSort.lsp
« Reply #130 on: September 22, 2009, 09:01:59 AM »
Bug Squashed  8-)
First post updated to Version 1.8.1 to include the bug fixes for the two Alans  :-)
alanjt
Re: TabSort.lsp
« Reply #131 on: September 22, 2009, 09:14:18 AM »
Bug Squashed  8-)
We're buggy people.  :-o :lol:
Dropbox
Re: TabSort.lsp
« Reply #132 on: September 22, 2009, 09:25:58 AM »
Maybe it's ACAD2000 but the help says negative numbers signal failure so zero is returned on my system.
Re: TabSort.lsp
« Reply #133 on: September 22, 2009, 09:33:50 AM »
True, but then zero is neither positive or negative - I just err'd on the wrong side thats all  :-)
VovKa
  • Ukraine
Re: TabSort.lsp
« Reply #134 on: September 23, 2009, 12:39:39 PM »
1 delete all layouts
2 reset
3 done
4 error
