Author Topic: Osnaps with Shift & Right Mouse Button  (Read 4040 times)
ML
« on: November 05, 2004, 09:02:11 AM »
Hello,
For some reason I am not able to shift + right mouse button to access my Osnaps anymore. I tried reloading The ACAD menu but that didn't help either. That leads me to believe that there is a variable that controls that but I can not find it. Does anyone know why this may be happening and what the solution is?
Thank you
Dommy2Hotty
« Reply #1 on: November 05, 2004, 10:47:52 AM »
Open the ACAD.MNS.  Right around line 32 is the AUX2 section.  It should read:
***AUX2
$P0=SNAP $p0=*
$P0=SNAP $p0=*
Right around line 42 is the ***POP0 section.  it should read:
***POP0
**SNAP
               [&Object Snap Cursor Menu]
ID_Tracking    [Temporary trac&k point]_tt
ID_From        [&From]_from
ID_MidTwoPts   [Mid Bet&ween 2 Points]_m2p
ID_MnPointFi   [->Poin&t Filters]
ID_PointFilx     [.X].X
ID_PointFily     [.Y].Y
ID_PointFilz     [.Z].Z
ID_PointFixy     [.XY].XY
ID_PointFixz     [.XZ].XZ
ID_PointFiyz     [<-.YZ].YZ
ID_OsnapEndp   [&Endpoint]_endp
ID_OsnapMidp   [&Midpoint]_mid
ID_OsnapInte   [&Intersection]_int
ID_OsnapAppa   [&Apparent Intersect]_appint
ID_OsnapExte   [E&xtension]_ext
ID_OsnapCent   [&Center]_cen
ID_OsnapQuad   [&Quadrant]_qua
ID_OsnapTang   [Tan&gent]_tan
ID_OsnapPerp   [&Perpendicular]_per
ID_OsnapPara   [Para&llel]_par
ID_OsnapNode   [No&de]_nod
ID_OsnapInse   [In&sert]_ins
ID_OsnapNear   [Nea&rest]_nea
ID_OsnapNone   [&None]_non
ID_Osnap       [&Osnap Settings...]'_+dsettings 2
Check that out...
PDJ
« Reply #2 on: November 05, 2004, 12:35:58 PM »
Have you checked to make sure something didn't get switched in your preferences?? Check tool, options, user preferences and then click on right-click customization, make sure short cut menu is selected for all three modes.
Sometimes strange things get reset when using lisp routines and other programs.
Dommy2Hotty
« Reply #3 on: November 05, 2004, 12:43:54 PM »
Quote from: PDJ
Even if shortcut menus are turned off, you still have the function of shift+right click (AUX2).
ML
« Reply #4 on: November 05, 2004, 12:44:59 PM »
Hey Dommy,
Thanks for the answer but I do have the code there (see below) and it is still not working????
Hey PD, I did check all of the Options
Anymore ideas?
***AUX2
$P0=SNAP $p0=*
$P0=SNAP $p0=*
***AUX3
$P0=SNAP $p0=*
***AUX4
$P0=SNAP $p0=*
***POP0
**SNAP
ID_PointFilx     [.X].X
ID_PointFily     [.Y].Y
ID_PointFilz     [.Z].Z
ML
« Reply #5 on: November 05, 2004, 12:50:26 PM »
I think that I switched a system variable but don't recall which one, it is driving me nuts
ML
« Reply #6 on: November 05, 2004, 02:23:37 PM »
OK, I don't know why I didn't think of this earlier but I had previously saved out my profile. I simply reloaded it and all is well now.
Evidentally profiles save system variable settings as well
I highly recommend every one saving out profiles
Thanks again
Andrew H
« Reply #7 on: November 08, 2004, 05:25:56 PM »
mbuttonpan
Controls the shift+scroll wheel behavior.
Andrew H
« Reply #8 on: November 08, 2004, 05:29:18 PM »
Sorry, I ment controls the scroll wheel (not the shift+scroll wheel).
Andrew H
« Reply #9 on: November 08, 2004, 05:34:04 PM »
You might want to play with the "osnapcoord" settings to see if that has something to do with it.
What is it doing when you shift+right click?
ML
« Reply #10 on: November 08, 2004, 06:23:47 PM »
Well, right now it is working perfect because I re imported my profile that I had previously saved out but I don't know what what cause that to happen except for a system variable that I may have screwed with and forgot to switch back
Andrew H
« Reply #11 on: November 08, 2004, 06:25:20 PM »
Sometimes bad lisp writers change system variables without realizing it. Did you resently start using a new lisp?
Bob Garner
« Reply #12 on: November 08, 2004, 06:38:00 PM »
SHORTCUTMENU VARIABLE?
Bobber
ML
« Reply #13 on: November 09, 2004, 09:54:07 AM »
Nope that doesn't do it but it is OK
I say my profile out like once every few weeks. May be I should do it weekly as much as I screw around.
I do have a test profile for that very purpose also
