; error: no function definition: nil
Yes it is. None of them lisps work, regardless of printer. I think it is a problem with the code before the command "-plot"
autoplotdell17100811model
OK so in 2006 I setup all the machines in the office and went through the routine a million times. Maybe now in 2010 I'm forgetting a simple step???1) I pointed my support path to look at the folder where the LCC_Autoplots.lsp file is saved 2) I appload the LCC_Autoplots.lsp file3) I insert the title block4) I click the button with the applicable macro or enter at the command line Code: [Select]autoplotdell17100811modeland i get on the command line ; error: no function definition: nilAnybody see something I'm missing?Is it working for everybody else in 2010?
(defun *error* (msg) (vl-bt))
'VLAX-ENAME->VLA-OBJECT
