Author Topic: Double Click in a List_Box  (Read 13405 times)
« on: September 09, 2009, 08:29:50 AM »
In my current project I would like to be able to double click on an item in a DCL list_box and have another dialog open with this action, however the only way I have found to have a double click is the "allow_accept" attribute.
But this would follow the action of the tile with the "accept" key. Therefore I considered having an arbitrary tile with the "accept" key to perform the actions I wanted, but this would mean a superfluous tile on the dialog (unless such things can be hidden?)
I am a bit stumped as to how to approach this one - but I do believe it to be possible, as I have seen a similar thing in action in MP's axprops.fas application (a very nice piece of work indeed).
Any help is appreciated,
Thanks,
Lee
Andrea
Re: Double Click in a List_Box
« Reply #1 on: September 09, 2009, 09:26:12 AM »
Hi Lee..
Maybe this can Help..
Not very elegant...but it work.
(defun c:test (/ mylist dcl_id)
  (createleemacdialog)
  (setq dcl_id (load_dialog (strcat (getvar "SAVEFILEPATH") "test.dcl")))
  (if (not (new_dialog "test" dcl_id))
    (exit)
  (setq mylist (list "Electrical" "Structural" "Plumbing" "Foundation"))
  (start_list "LB1" 3)
  (mapcar 'add_list mylist)
  (end_list)
  (action_tile
    "LB1"
    "(setq readlist (get_tile \"LB1\"))
    (if (eq (nth (atoi readlist) myList) firstitem)
    (alert (nth (atoi readlist) myList))
    (setq firstitem nil)
    (setq firstitem (nth (atoi readlist) myList))
  ;;ACTION
  (action_tile "accept" "(done_dialog) (setq userclick T)")
  (action_tile "cancel" "(done_dialog) (setq userclick nil)")
  (start_dialog)
  (unload_dialog dcl_id)
(defun createleemacdialog (/ dialf)
  (setq dialf (open (strcat (getvar "SAVEFILEPATH") "test.dcl") "w"))
  (write-line
    "test  : dialog {
          label = \"test double click\" ;
: column {
: spacer {}
: boxed_column {
: spacer {}
label = \"ListBox :\";
: list_box {
        key = \"LB1\";
: spacer {}
        : text {
        label = \"For LeeMac Only ! ;-)\";
        : row {
  children_alignment = top ;
: spacer {}
        ok_cancel ;
"   dialf
  (close dialf)
Keep smile...
« Reply #2 on: September 09, 2009, 09:34:28 AM »
Nice idea Andrea,
Thats a good substitute for the double click action - it doesn't emulate it exactly, as there can be an indefinite delay between the two clicks, but its pretty close  :-)
Thanks,
Lee
Andrea
« Reply #3 on: September 09, 2009, 10:07:47 AM »
maybe by adding this..
    (exit)
  (end_list)
  (action_tile
    "LB1"
    (setq start# (getvar \"date\"))
    (if (and
        (eq (nth (atoi readlist) mylist) firstitem)
        (< (abs (read (rtos (- end# start#) 2 10))) 0.0000011667)
      (progn (alert (nth (atoi readlist) mylist))
      (setq end# (getvar \"date\"))
      (setq firstitem (nth (atoi readlist) mylist))
  ;;ACTION
  (start_dialog)
(rtos (getvar  "date") 2 8)
  (write-line
    "test  : dialog {
: column {
: spacer {}
: boxed_column {
: spacer {}
: list_box {
        key = \"LB1\";
: spacer {}
        : text {
        : row {
: spacer {}
        ok_cancel ;
"   dialf
  (close dialf)
Keep smile...
« Reply #4 on: September 09, 2009, 10:14:41 AM »
Haven't tried your most recent post yet - but I had a dabble with this:
(defun c:test (/ mylist dcl_id ptr acptr)
    (exit)
  (end_list)
  (action_tile "accept" "(or (and acPtr
                                  (not (alert (nth (atoi acPtr) mylist)))
                                  (not (setq acPtr nil)))
                             (done_dialog))")
  (action_tile "LB1"    "(or (and (eq ptr $value)
                                  (not (setq acPtr ptr ptr nil)))
                             (setq ptr $value))")
  (action_tile "cancel" "(done_dialog)")
  (start_dialog)
  (write-line
    "test  : dialog {
: column {
: spacer {}
: boxed_column {
: spacer {}
: list_box {
        key = \"LB1\";
        allow_accept = true;
: spacer {}
        : text {
        label = \"For LeeMac + Andrea Only ! ;-)\";
        : row {
: spacer {}
        ok_cancel ;
"   dialf
  (close dialf)
« Reply #5 on: September 09, 2009, 10:16:29 AM »
Very nice Andrea! - I like your thinking... when I said there was an indefinite about of time between clicks, you took this literally and put a cap on that time... nice thinking  8-)
Andrea
« Reply #6 on: September 09, 2009, 10:22:24 AM »
Thanks !   :angel:
that way you will be able to set double-click delay. :ugly:
Keep smile...
« Reply #7 on: September 09, 2009, 10:31:49 AM »
A slightly tider action statement:
(action_tile "LB1"
    "(setq start# (getvar \"date\"))
     (if (and (eq ptr $value)
              (< (abs (read (rtos (- end# start#) 2 10))) 0.0000011667))
      (alert (nth (atoi ptr) mylist))
             (setq ptr nil))
      (setq end# (getvar \"date\") ptr $value))"
Andrea
« Reply #8 on: September 09, 2009, 10:41:39 AM »
(action_tile "LB1"
             (setq ptr nil))
not sure to understand...
why (eq ptr $value) ?
$value and ptr always = nil ?
Keep smile...
« Reply #9 on: September 09, 2009, 10:42:35 AM »
$value is the value of the tile when the action_tile is triggered  :-)
Andrea
« Reply #10 on: September 09, 2009, 10:48:21 AM »
oh ! I see... :?
nice...!!  thanks !
Keep smile...
GDF
« Reply #11 on: September 09, 2009, 12:16:22 PM »
;;;double clicking on image tile
(defun ARCH:SET_X (a) (setq x a))
(defun ARCH:READ_X  (a)
  (if (= x a)
    (done_dialog)))
(action_tile
    "S1"
    "(ARCH:READ_X 1)(RESETNO-OFF)(ARCH:PLAY-SYM \"S1\" \"North\" \"Arrow\")(ARCH:SET_X 1)")
This is what I do for double clicking on button in a dialog box.
In the SYMS dialog box image below, a single click changes the image and a double click does the action.
The S1 image is in the upper left (north arrow) button.
jbuzbee
« Reply #12 on: September 09, 2009, 01:00:21 PM »
. . . psst: OpenDCL.com
all the cool kids are doing it . . .  8-)
James Buzbee
Windows 8
Andrea
« Reply #13 on: September 09, 2009, 01:03:30 PM »
I prefer ObjectDCL.com   :pissed:
Keep smile...
« Reply #14 on: September 09, 2009, 01:13:19 PM »
I haven't tried either tbh...
Andrea, is ObjectDCL part of your company?
JBuz >  I have had a look at OpenDCL.com - may look into getting into it... not sure how easy it is to get to grips with though...   :|
