Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
Files with extension SKF
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Files with extension SKF (Read 1891 times)
Yoland
Guest
on:
September 09, 2009, 08:21:50 AM »
Hello,
I received a files with extension SKF (Autosketch), Do you know a convert program between this files and DWG or DXF.
I don't know if this post must be here, if not move it....
Thanks a lot
Yolanda
Logged
architecture68-raff
Swamp Rat
Strange things are afoot at the Circle-K.
Re: Files with extension SKF
Reply #1 on:
September 09, 2009, 08:28:40 AM »
The only way I know to convert from .skf to .dwg is from within Autosketch.
I have an old copy of Autosketch 9 installed and wouldn't mind converting a file or two for you if you have no other options.
Logged
Chicago, Illinois
ADT 2005, Revit Architecture 2009, Sketchup 7
Matt__W
Seagull
I like my water diluted.
Reply #2 on:
September 09, 2009, 08:28:47 AM »
I'm guessing it would have to be done in Autosketch. I have to believe there's some sort of export to DXF functionality in that program.
Logged
Autodesk Expert Elite
Owner/FAA sUAS Pilot @
http://skyviz.io
Global Moderator
Seagull
Reply #3 on:
September 09, 2009, 10:45:26 AM »
Look here:
SKF converters
Logged
Yoland
Guest
Reply #4 on:
September 10, 2009, 02:27:33 AM »
Thanks a lot!!!
I said to the client tha send me the files in DXF or DWG format.
CAB, I don't found SKF converters ...
Bye,
Yolanda
Logged
Global Moderator
Seagull
Reply #5 on:
September 10, 2009, 03:13:58 PM »
http://www.xnview.com/en/xnview.html
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
