Author Topic: To make a poly on the fly  (Read 3763 times)
DEVITG
« on: August 31, 2009, 03:51:10 PM »
What is the way to make a polyline on the fly by lisp
I remember some like comandactive or so on but I can not find it.
(command "_pline"  then allow me to pick as many point as I want.
Re: To make a poly on the fly
« Reply #1 on: August 31, 2009, 03:54:48 PM »
(command "_.pline")
(while (> (getvar "CMDACTIVE") 0)
  (command pause))
(command)
DEVITG
« Reply #2 on: August 31, 2009, 03:55:51 PM »
(command "_.pline")
  (command pause))
(command)
That was
« Reply #3 on: August 31, 2009, 03:57:07 PM »
No probs dude  8-)
DEVITG
« Reply #4 on: August 31, 2009, 04:05:18 PM »
There is any way to sum the distance between points while in the WHILE?
I want to know the polyline length, on the fly too.
Of course It can be get after doing the poly by (entlast)
and by the vlax-curvexxx
« Reply #5 on: August 31, 2009, 04:07:57 PM »
You could just use the distance function to calculate the distance between successive points, but you may need to rework the while loop you are using.
DEVITG
« Reply #6 on: August 31, 2009, 04:13:33 PM »
I try it so
(setvar "cmdecho" 1)
(setq distancia 0)
 (setq pt1 (getpoint "\nInicio: "))
(command "_.pline")
  (command pause)
  (setq pt2 (getvar 'lastpoint ))
  (setq dist (distance pt1 pt2))
(setq pt1 pt2)
(setq distancia ( + distancia dist))
(command)
But do not work
neither it
(setq distancia 0)
(command "_.pline" )
(setq pt1 pt2)
  (command pause)
(command)
gile
  • Marseille, France
« Reply #7 on: August 31, 2009, 04:18:40 PM »
Hi
Something like this ?
(setq tot 0)
(command "_.pline" pause)
(setq pt (getvar 'lastpoint))
(while (/= 0 (getvar 'cmdactive))
  (command pause)
  (setq tot (+ tot (distance pt (setq pt (getvar 'lastpoint)))))
  (princ (strcat "\nDistencia = " (rtos tot)))
DEVITG
« Reply #8 on: August 31, 2009, 04:22:25 PM »
Hi Lee MAc and gile , I did it work so, thanks both.
(defun C:CAUCE (/
;;; pt1 pt2 distancia
  (setvar 'OSMODE 1)
  (setq DISTANCIA 0)
  (setq PT1 (getpoint "\nInicio: "))
  (command "_.pline")
  (command PT1)
    (setq PT2 (getvar 'LASTPOINT))
    (setq DIST (distance PT1 PT2))
    (setq PT1 PT2)
    (setq DISTANCIA (+ DISTANCIA DIST))
    (princ DISTANCIA)
    (command PAUSE))
  (command)
  (setq TEXTO (strcat (rtos DISTANCIA 2 3) " Km"))
  (command "_text" "_c" PT2 12 0 TEXTO)
« Last Edit: August 31, 2009, 04:34:28 PM by DEVITG »
« Reply #9 on: September 01, 2009, 06:57:44 AM »
Glad you got it working in the end  :-)
You may want to add an IF statement, in case the user does not pick the first point  ;-)
curmudgeon
« Reply #10 on: September 02, 2009, 04:35:34 PM »
I really deeply prefer entmake to command.
it works programmatically like this:
(defun makepolyonthefly (/ pt pt_lst)
  (while (setq pt (getpoint "\nPick Vertex Point:  "))
    (setq pt_lst (append (list (cons 10 pt)) pt_lst)
  (entmake (append (list '(0 . "LWPOLYLINE")
'(100 . "AcDbEntity")
(cons 8 (getvar "CLAYER"))
'(100 . "AcDbPolyline")
(cons 90 (length pt_lst))
'(70 . 1)
;;closed polyline
   pt_lst
 8-)
or to get a rubber band line:
  (while
    (cond ((= pt nil)(setq pt (getpoint "\nPick Vertex Point:  ")))
  ( pt (setq pt (getpoint pt "\nPick Vertex Point:  ")))
'(70 . 1)
;;closed polyline
   pt_lst
« Last Edit: September 02, 2009, 04:43:33 PM by curmudgeon »
Never express yourself more clearly than you are able to think.
« Reply #11 on: September 03, 2009, 06:05:27 AM »
Nice idea Curmudgeon,
As an extension of that:
(defun mkpoly  (/ pt pt_lst flag gr_lst)
  (while
      (initget "C")
      (cond (pt (setq pt (getpoint pt "\nPick Vertex Point: ")))
            ((setq pt (getpoint "\nPick Vertex Point: "))))
      (cond ((null pt) nil)
            ((eq "C" pt) (setq flag 1) nil)
            ((setq pt_lst (append pt_lst (list (cons 10 pt)))
                   gr_lst
                    (if (> (length gr_lst) 1)
                      (append gr_lst (list (last gr_lst) pt))
                        (append gr_lst (list pt)))))))
      (grvecs (append '(-3) gr_lst))))
  (redraw)
  (entmake
    (append
      (list (cons 0 "LWPOLYLINE")
            (cons 100 "AcDbEntity")
            (cons 100 "AcDbPolyline")
            (cons 70 (if flag flag 0))) pt_lst)))
efernal
« Reply #12 on: September 03, 2009, 09:10:53 PM »
;; good...
;; I made a change for my use...
(DEFUN mkpoly (/ pt pt_lst flag gr_lst cn)
  (SETQ cn 1)
  (WHILE
    (PROGN (INITGET "C")
      (COND (pt (SETQ
             pt (GETPOINT pt
                (STRCAT
                  "\rPick Vertex Point < "
                  (IF (> cn 2)
               (STRCAT   (ITOA (SETQ cn (1+ cn)))
                  " > or C to close : "
       ((SETQ pt (GETPOINT "\nPick Vertex Point < 1 > :\n")))
      (COND ((NULL pt) nil)
       ((EQ "C" pt) (SETQ flag 1) nil)
       ((SETQ   pt_lst (APPEND pt_lst (LIST (CONS 10 pt)))
         gr_lst (IF (> (LENGTH gr_lst) 1)
             (APPEND gr_lst (LIST (LAST gr_lst) pt))
             (APPEND gr_lst (LIST pt))
       (GRVECS (APPEND '(-3) gr_lst))
  (REDRAW)
  (ENTMAKE (APPEND (LIST (CONS 0 "LWPOLYLINE")
          (CONS 100 "AcDbEntity")
          (CONS 100 "AcDbPolyline")
          (CONS 90 (LENGTH pt_lst))
          (CONS 70
                (IF flag
             flag
             0
         pt_lst
  (PRINC)
e.fernal
« Reply #13 on: September 04, 2009, 06:23:58 AM »
Glad you could make use of it  8-)
curmudgeon
« Reply #14 on: September 04, 2009, 09:35:30 AM »
I LIKE THAT!
I knew I had neglected the open polyline, I had forced it closed.
I like the way your cond flows - although I want to study it a bit more.
Thanks.
roy
