Author Topic: Slide Library Manager  (Read 4975 times)
Esen
« on: August 28, 2009, 04:18:51 PM »
This Slide Library Manager written with C# and using slide.ocx.
Program allows:
  • Create a new library
  • Add a slide to a library
  • Delete a slide from library
  • Extract slides from library
neyton
Re: Slide Library Manager
« Reply #1 on: August 28, 2009, 06:26:54 PM »
see this post:
http://tbn2.blogspot.com/2007/07/slideviewer.html
a time ago I wrote a viewer slide also, try using it, is not required any other dll
Visit my website: http://tbn2.blogspot.com
« Reply #2 on: August 28, 2009, 10:42:05 PM »
see this post:
OOPS ..
« Reply #3 on: August 28, 2009, 10:42:56 PM »
Esen, Thanks for sharing.
.. and welcome to the Swamp :)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: August 29, 2009, 07:14:59 AM »
@ Esen , Nice work and welcome to TheSwamp  : )
@ neyton, interesting that you were able to decode .sld files, nice work!
neyton
« Reply #5 on: August 29, 2009, 08:50:17 AM »
some older slides do not decode properly
this program when I was learning to use .NET, hehehe
I had more time to fix these bugs
It's Alive!
  • Retired
  • AKA Daniel
« Reply #6 on: August 29, 2009, 09:15:27 AM »
Maybe someday you can post your code, It might be useful to others who might need a slide view control.
neyton
« Reply #7 on: August 30, 2009, 10:55:15 AM »
ok, see this:
http://tbn2.blogspot.com/2009/08/slideviewer-source-code.html
I appreciate comments!!
(the comments of the code are brazilian portuguese)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #8 on: August 31, 2009, 03:32:21 AM »
Great! Thank you for sharing!  8-)
I will have a read through the code and report back!
hermanm
« Reply #9 on: August 31, 2009, 09:04:17 AM »
There was a slide file format change at some point in Adesk history.
I do recall hearing from Chad Wanless on this topic when he was still developing Object DCL.
Same problem, &  IIRC he said he was unsuccessful in decoding the earlier format.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #10 on: September 03, 2009, 08:50:49 PM »
I think there is a marker in the sld format that flags if it's the new version or not.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #11 on: September 03, 2009, 08:56:13 PM »
ok, see this:
Seems it's easier for me to read Portuguese than VB.net.  :-D
Your programming skills are really quite good! As soon as I get a little time, I will try and add a few extension methods to System.Drawing.Image to handle .sld files.
Again thanks for sharing.
neyton
« Reply #12 on: September 04, 2009, 11:57:35 AM »
Muito Obrigado!!!
