see this post:http://tbn2.blogspot.com/2007/07/slideviewer.htmla time ago I wrote a viewer slide also, try using it, is not required any other dll
some older slides do not decode properly
Quote from: neyton on August 29, 2009, 08:50:17 AMsome older slides do not decode properlyThere was a slide file format change at some point in Adesk history.I do recall hearing from Chad Wanless on this topic when he was still developing Object DCL.Same problem, & IIRC he said he was unsuccessful in decoding the earlier format.
ok, see this:http://tbn2.blogspot.com/2009/08/slideviewer-source-code.htmlI appreciate comments!!(the comments of the code are brazilian portuguese)
