Author Topic: Enhanced chamfer needed  (Read 2387 times)
Aerdvark
« on: August 28, 2009, 02:33:30 AM »
Hello,
I have read this topic but is did not solve my problem: http://www.theswamp.org/index.php?topic=17392.0
When drawing polylines, sometimes they need to be chamfered. That can only be done when exploding the polyline.
Or not drawing polylines but drawing just plain and simple lines.
What I was searching for (and I have done a lot searching) is a routine that would be able to:
1. prompt for the polyline to be chamfered
2. prompt for the remaining polyline
3. promt the side of chamfer
In the routine itself (or 4.) the chamfer distance A and B can be given.
See image for what I mean.
I have tried several routines like this:
; Chamfers first line to second line and leaves second line unchanged.
; In other words, does not trim second line to chamfer.
(DEFUN C:CHAMFER2 (/ A B AN BN AE BE AN1
            AN2 TN1 TN2 TN3 NS RS R C)
  (SETVAR "CMDECHO" 0)
(SETQ B (ENTSEL "LINE TO CHAMFER: ")
BN (OSNAP (CADR B) "NEAR")
BE (OSNAP (CADR B) "END")
A (ENTSEL "UNCHANGING LINE: ")
AN (OSNAP (CADR A) "NEAR")
AE (OSNAP (CADR A) "END")
NS (INTERS AN AE BN BE NIL)
RS (STRCAT "CHAMFER <" (RTOS
   (GETVAR "CHAMFERA")) ">: ")
R (GETREAL RS))
(IF R (SETVAR "CHAMFERA" R)
(SETQ R (GETVAR "CHAMFERA"))
(SETQ AN1 (ANGLE NS AN)
      AN2 (ANGLE NS BN)
        C (- AN2 AN1))
(IF (> C PI)
    (SETQ C (- C (* 2.0 PI))))
(IF (< C (- PI))
      (SETQ C (+ C (* 2.0 PI))))
(SETQ TN3 (ABS (/ (* R (COS
   (/ C 2.0 ))) (SIN (/ C 2.0))))
TN1 (POLAR NS AN1 TN3)
TN2 (POLAR NS AN2 TN3))
(IF (MINUSP C)
   (COMMAND "LINE" TN1 TN2 "")
   (COMMAND "LINE" TN2 TN1 "")
  (COMMAND "CHANGE" (CAR B) "" TN2)
  (SETVAR "CMDECHO" 1)
But this given routine only works with lines, not polylines.
Also it does not work constant: half the time it does create zero length lines.
Anyway... does anybody have a routine that does the trick?
Or maybe kick me in the right direction?
Thanks already.
GDF
Re: Enhanced chamfer needed
« Reply #1 on: August 28, 2009, 10:44:50 AM »
Here is one that I use. It is not a standalone routine, but hopefully it will give you some ideas.
GDF
« Reply #2 on: August 28, 2009, 10:56:14 AM »
And fillet routine...
« Reply #3 on: August 28, 2009, 11:51:15 AM »
Gary,
What does the Cnotch  button do?
GDF
« Reply #4 on: August 28, 2009, 12:04:44 PM »
Gary,
DEVITG
« Reply #5 on: August 30, 2009, 04:17:02 PM »
Could it be possible to have the main and other defun's??
like
; error: no function definition: ARCH:DIALOG_SETUP
thanks in advance
GDF
« Reply #6 on: August 31, 2009, 10:51:37 AM »
like
thanks in advance
http://www.theswamp.org/index.php?topic=8749.15
Aerdvark
« Reply #7 on: October 20, 2009, 05:58:30 PM »
Hello there again,
Still can't let go...
I played with the routines in this threat:
If one of the 2 codes below (thanks to CAB and A_LOTA_NOTA) would work with chamfer and polylines it would be great.
But I have no clue why it don't work.
Maybe you guys can help me out?
In the end the result is the same as it is now but only I have polylines and the arc's can be straight lines...
(defun c:efillet (/ e1 e2 elst OldRad Entz)
  (if (not (zerop (getvar "filletrad")))
      (while (not e1)
(initget 1 "Radius")
(setq e1 (entsel "Select first object or [Radius]:"))
(if (or (= e1 "Radius") (= e1 "R"))
    (setq OldRad (rtos (getvar "filletrad")))
    (setq NewRad (getreal (strcat "\nSpecify fillet radius < " OldRad " > : ")))
    (if (/= NewRad nil)
      (setvar "filletrad" NewRad)
    (setq e1 nil)
      (setq Entz (car e1))
      (redraw Entz 3)
      (while (not e2)
(setq e2 (entsel "\nSelect line to keep"))
      (setq elst (entget (car e2)))
      (not (command "_fillet" e1 e2))
      (equal (assoc 0 (entget (entlast))) '(0 . "ARC"))
      (entmod elst)
      (prompt "\nRadius must be > 0.")
or...
;;  CAB 07.09.07
(defun c:efillet1 (/ e1 e2 elst rad)
  (defun set_radius (/ NewRad)
      (and
        (not (initget 6))
        (setq NewRad (getdist (strcat "\nSpecify fillet radius < "
    nil
  (if (zerop (getvar "filletrad"))
    (set_radius)
  (while
      (initget "Radius")
      (setq e1 (entsel "\nSelect line to fillet or [Radius]:"))
      (if (= e1 "Radius")
        (set_radius)
      (/= (type e1) 'list)
  (while (not (setq e2 (entsel "\nSelect line to keep"))))
  (if (> (getvar "CMDACTIVE") 0)
      (command)
      (princ "\nCannot fillet between these two entities.")
    (if (equal (assoc 0 (entget (entlast))) '(0 . "ARC"))
      (entmod elst)
